Re: localization file [message #717267 is a reply to message #715249] |
Fri, 19 August 2011 19:11 |
JulioC Missing name Messages: 33 Registered: March 2011 Location: Ottawa, Canada |
Member |
Hi Jason Thanks for the link
I was able to do it as this :
1 . this.URI = "file:///C:/eclipsework/myreports/myimage.png";
That was on a windows box, however I couldn't get it working on a linux box, is there any syntax rule for Linux? I tried
this.URI = "report/images/myimage.png" and it does not work (we have birt runtime on a tomcat servlet)
I tried
2. this.URI="http://myhost/report/images/myimage.png" and it worked as expected
We prefer the number 1 idea, it is more flexible when you have the same report for several clients with a different logo, so you can have symlink to myimage.png
Idea number 2 will be great if BIRT can retrieve the hostname of the box so we could have something like this
this.URI="http://${hostname}/report/images/myimage.png"
We want to have only one report design for several clients where the hostname is different.
Thanks in advance for any idea for this.
JulioC.
[Updated on: Fri, 19 August 2011 19:13] Report message to a moderator
Re: localization file [message #717284 is a reply to message #717267] |
Fri, 19 August 2011 20:18 |
Can you try a linux uri like:
http://en.wikipedia.org/wiki/File_URI_scheme
Jason
> 1 . this.URI = "file:///C:/eclipsework/myreports/myimage.png"; That was
> there any syntax rule for Linux? I tried this.URI =
> I tried 2. this.URI="http://myhost/report/images/myimage.png" and it
> worked as expected
> JulioC.
Re: localization file [message #718225 is a reply to message #718212] |
Tue, 23 August 2011 16:14 |
You can do this with client side script. Just add a text element to the
report, set its type to html and enter this code:
<script language="JavaScript">
alert( navigator.appVersion );
</script>
Jason
On 8/23/2011 11:51 AM, JulioC wrote:
> Hi Jason
> I got the report working using birt viewer on tomcat.
> However I have a question, it is possible using javascript to guess the
> OS of the browser in BIRT?
> I was trying to use a normal javascript tool
> navigator.appVersion.indexOf("Win")
> is there any similar way to do that in BIRT?
> Thanks
Re: localization file [message #718226 is a reply to message #718225] |
Tue, 23 August 2011 16:19 |
You can always get the user agent header from the request before the
report runs as well:
brw = reportContext.getHttpServletRequest().getHeader("User-Agent");
Jason
> </script>
> Jason
>> Hi Jason
>> Thanks
FUDForum. Page generated in 0.04096 seconds
