Home » Eclipse Projects » Rich Client Platform (RCP) » Need help on how to disable scrolling of text values in Nebula table combo(Need help on how to disable scrolling of text values in Nebula table combo)
Need help on how to disable scrolling of text values in Nebula table combo [message #710027] Thu, 04 August 2011 15:48 Go to next message
eclipsefan  is currently offline eclipsefan Friend
Hello Teachers,
I am using the nebula table combo widget for my current work (org.eclipse.nebula.widgets.tablecombo.TableCombo). Assuming that the table combo has list of values, here is my use case:
1. I select one value from the table combo.
2. The selected value goes in the text control of the table combo and is in focus.
3. I scroll my mouse wheel and the text value in the table combo's text control also changes. (This is the default behavior).
Is there a way to change the default behavior where after the text has been selected, the scrolling of the mouse wheel should not change the value in the text control.
Thanks and Regards.
(no subject) [message #711944 is a reply to message #710027] Sat, 06 August 2011 20:48 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Try the Nebula group.
> Hello Teachers,
focus.
text control.
> Thanks and Regards.
(no subject) [message #711945 is a reply to message #710027] Sat, 06 August 2011 20:51 Go to previous message
Pls do not post your question in different newsgroup without telling that you
crossposted.
> Hello Teachers,
focus.
text control.
> Thanks and Regards.
Previous Topic:Change perspective bar size?
Next Topic:Update RCP without UpdateManager
Current Time: Fri Jan 21 11:30:21 GMT 2022
Powered by FUDForum. Page generated in 0.02028 seconds
