Home » Modeling » Graphiti » IGaService.creatFont() ?
IGaService.creatFont() ? [message #709946] |
Thu, 04 August 2011 14:08 |
Hernan Gonzalez Messages: 188 Registered: October 2010 Location: Buenos Aires, Argentina |
I downloaded a sample ("Libray Example" from "Getting Started with Graphiti", Michael Wenz, slide linked in http://www.eclipse.org/graphiti/documentation/ ) and it gives some compilation error
IGaService gaService = Graphiti.getGaService();
gaService.createFont(libraryNameText, "Arial", 16);
Apparently some older api version had this method, it doesn't exists now (Graphiti 0.8) I changed it (by guessing) to:
libraryNameText.setFont(gaService.manageFont(diagram, "Arial", 16));
Does this sound right? It sounded to me, but when I try to run the sample project it throws some (apparently related) exception:
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object 'org.eclipse.graphiti.mm.algorithms.styles.impl.FontImpl@14adad2 (name: Arial, size: 16, italic: false, bold: false)' is not contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingHREF(XMLHelperImpl.java:760)
Any clues?
PS: I'm not terribly interested in making that sample work, more in making sure that that is the right way to set the font.
[Updated on: Thu, 04 August 2011 14:21] Report message to a moderator
Re: IGaService.creatFont() ? [message #710248 is a reply to message #709946] |
Thu, 04 August 2011 21:11 |
Joerg Reichert Messages: 80 Registered: July 2009 Location: Leipzig |
Member |
Hi Hernan,
this code is from org.eclipse.graphiti.tests.cases.GaServiceTest.deleteFont
Text text = gas.createDefaultText(d, s1);
Font font = gas.manageFont(d, FONTNAME, 10);
text.setFont(font);
assertEquals(font, text.getFont());
gas.deleteFont(font);
assertNull(text.getFont());
Be aware that you create your font only once, otherwise your diagram file will contain duplicate font entries. Although this causes no crash it is not intended.
<pi:Diagram ...>
<graphicsAlgorithm ... />
<children>
</children>
<connections>
</connections>
<fonts name="Arial" size="10"/>
</pi:Diagram>
So call aService.manageFont(diagram, "Arial", 16) only once and use the reference in the setFont method.
Joerg
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: IGaService.creatFont() ? [message #710357 is a reply to message #710248] |
Fri, 05 August 2011 00:04 |
Joerg Reichert wrote on Thu, 04 August 2011 18:11
Wow, thanks, that sounds somewhat scaring... First, I found a little strange that the service API has a deleteFont() method and not a createFont() method. I assumed that manageFont() was a "clever" createFont() version, in that it creates it if not found in the diagram, elsewhere finds and return it. From the javadocs, it "Provides a font instance by either creating a new one and aggregating it to the diagram or finding it in the diagrams list of fonts."
Doesn't this contradicts that ocurrence of duplicate fonts? Is this a bug?
Further, how can I make sure that I create the font only once?
Re: IGaService.creatFont() ? [message #710593 is a reply to message #710357] |
Fri, 05 August 2011 07:41 |
Member |
This is the actual implementation of manageFont in GaServiceImpl (manageFont(Diagram, String, int) delegates to it):
public Font manageFont(Diagram diagram, String name, int size, boolean isItalic, boolean isBold) {
EList<Font> fonts = diagram.getFonts();
for (Font font : fonts) {
if (font.getName().equals(name) && font.getSize() == size && font.isBold() == isBold && font.isItalic() == isItalic)
return font;
Font newFont = StylesFactory.eINSTANCE.createFont();
newFont.setName(name);
newFont.setSize(size);
newFont.setItalic(isItalic);
newFont.setBold(isBold);
fonts.add(newFont);
return newFont;
So actually this method does what JavaDocs says. So I had a look in my code now, why despite of that I have this behavior:
Text text = gaService.createDefaultText(getDiagram(), textShape);
createDefaultText Internally creates a font of type "Arial" in size 8.
But then I assign my own font attributes:
text.getFont().setName("Arial");
text.getFont().setSize(10);
text.getFont().setBold(false);
text.setHorizontalAlignment(Orientation.ALIGNMENT_RIGHT);
text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
text.setForeground(gaService.manageColor(diagram,ColorConstant.BLACK));
I have a helper method doing this and I call that in every add feature. So what happens: createDefaultText creates a font of type "Arial", 8, then I change it to Arial, 10. The next time I call createDefaultText, there is no font Arial, 8 anymore, so it creates a new one, then it is changed to Arial, 10 again. So the duplicate fonts are created. How to overcome that?: Use gaService.createText instead of gaService.createDefaultText.
Joerg
Re: IGaService.creatFont() ? [message #710793 is a reply to message #710593] |
Fri, 05 August 2011 12:16 |
Aha...
If I got it right, you could also change in your helper method the lines
to (as in the testcase posted earlier)
text.setFont(gaService.manageFont(getDiagram(), "Arial", 10,false,false));
It looks as if the Font.setXXX() methods should never called by the programmer.
Perhaps this should be explained in some wiki, or as a warning in the javadocs of the Font class.
[Updated on: Fri, 05 August 2011 13:28] Report message to a moderator
Current Time: Thu Apr 25 20:39:24 GMT 2024
Powered by FUDForum. Page generated in 0.04036 seconds
