Home » Language IDEs » Java Development Tools (JDT) » Programatically setting Javadoc and Source
Re: Programatically setting Javadoc and Source [message #712568 is a reply to message #712334] |
Sun, 07 August 2011 12:46 |
Phil Messages: 6 Registered: August 2011 |
Thanks I am doing that. The Plugin spy is very helpful, I didn't know about it, and its very helpful
I have successfully located where the data is held:
IJavaElement element = binding.getJavaElement();
IJavaProject javaProject = element.getJavaProject();
IPackageFragmentRoot packageFragmentRoot = javaProject.findPackageFragmentRoot(element.getPath());
IClasspathEntry classpathEntry = packageFragmentRoot.getResolvedClasspathEntry();
IClasspathAttribute[] extraAttributes = classpathEntry.getExtraAttributes();
One of the class path attributes has name javadoc_location and the value is the path for the javadoc. The classpathEntry has a sourceAttachmentPath, and this is where the source code is attached.
Hurrah! Half the problem solved. With a bit of luck, those urls you posted should help me track down how to set them.
[Updated on: Sun, 07 August 2011 12:48] Report message to a moderator
Re: Programatically setting Javadoc and Source [message #713442 is a reply to message #712702] |
Mon, 08 August 2011 13:29 |
OK I have it. Thank you for the help.
I have only made it work for jars in libraries, but I suspect the same approach will work.
In essence you need to make a new container that is just like the container that holds the classpathentry representing your jar, except that the class path entry needs to be changed to have an extra attribute with name (IClasspathAttribute.JAVADOC_LOCATION_ATTRIBUTE_NAME which has to point to a legitimate url.
You then find the ClasspathContainerInitializer that corresponds to this classpath container, and request it to update the class path container.
I have tried adding to the JRE rt.jar using this approach and it now appears in the property page, and persists across sessions.
/**The IClassPathEntry is the one found in the code snippet above. */
private void setJavadocLocationAttribute(IJavaProject project, IClasspathEntry entry, String text) {
assert ripped != null;
FoundClassPathEntry found = JavaProjects.findClassPathEntry(project, entry);
System.out.println("Setting. Found: " + found);
JavaProjects.updateFoundClassPath(found, new IFunction1<IClasspathEntry, IClasspathEntry>() {
public IClasspathEntry apply(IClasspathEntry from) throws Exception {
IClasspathAttribute[] extraAttributes = from.getExtraAttributes();
List<IClasspathAttribute> newAttributes = new ArrayList<IClasspathAttribute>();
boolean found = false;
IClasspathAttribute newClasspathAttribute = JavaCore.newClasspathAttribute(IClasspathAttribute.JAVADOC_LOCATION_ATTRIBUTE_NAME, text);
for (IClasspathAttribute oldAttribute : extraAttributes)
if (oldAttribute.getName().equals(IClasspathAttribute.JAVADOC_LOCATION_ATTRIBUTE_NAME)) {
newAttributes.add(newClasspathAttribute);
found = true;
} else
newAttributes.add(oldAttribute);
if (!found)
IClasspathEntry newLibraryEntry = JavaCore.newLibraryEntry(from.getPath(), from.getSourceAttachmentPath(), from.getSourceAttachmentRootPath(), from.getAccessRules(), newAttributes.toArray(new IClasspathAttribute[0]), from.isExported());
return newLibraryEntry;
public class FoundClassPathEntry {
public static enum FoundIn {
NOT_FOUND, FOUND_IN_RAW, FOUND_IN_LIBRARY
public final IJavaProject javaProject;
public final FoundIn foundIn;
public final IClasspathEntry rawClassPath;
public final IClasspathEntry classPathEntry;
public final IClasspathContainer container;
public FoundClassPathEntry(IJavaProject javaProject, FoundIn foundIn, IClasspathEntry classPathEntry) {
this.javaProject = javaProject;
this.foundIn = foundIn;
this.rawClassPath = classPathEntry;
this.container = null;
this.classPathEntry = classPathEntry;
public FoundClassPathEntry(IJavaProject javaProject, FoundIn foundIn, IClasspathEntry rawClassPath, IClasspathContainer container, IClasspathEntry classPathEntry) {
this.rawClassPath = rawClassPath;
this.container = container;
public String toString() {
return "FoundClassPathEntry [project=" + javaProject.getElementName() + ", foundIn=" + foundIn + "]";
public class JavaProjects {
public static FoundClassPathEntry findClassPathEntry(IJavaProject project, IClasspathEntry entry) {
try {
IClasspathEntry[] rawClasspaths = project.getRawClasspath();
for (IClasspathEntry rawClassPath : rawClasspaths) {
if (rawClassPath == entry)
return new FoundClassPathEntry(project, FoundIn.FOUND_IN_RAW, entry);
else if (rawClassPath.getEntryKind() == IClasspathEntry.CPE_CONTAINER) {
IClasspathContainer container = JavaCore.getClasspathContainer(rawClassPath.getPath(), project);
for (IClasspathEntry contained : container.getClasspathEntries()) {
if (contained == entry)
return new FoundClassPathEntry(project, FoundIn.FOUND_IN_LIBRARY, rawClassPath, container, entry);
return new FoundClassPathEntry(project, FoundIn.NOT_FOUND, entry);
} catch (JavaModelException e) {
throw WrappedException.wrap(e);
public static void updateFoundClassPath(final FoundClassPathEntry found, final IFunction1<IClasspathEntry, IClasspathEntry> mutator) {
try {
switch (found.foundIn) {
case FOUND_IN_LIBRARY:
ClasspathContainerInitializer initializer = JavaCore.getClasspathContainerInitializer(found.container.getPath().segment(0));
final IClasspathEntry[] newEntries = ArrayHelper.map(IClasspathEntry.class, found.container.getClasspathEntries(), new IFunction1<IClasspathEntry, IClasspathEntry>() {
if (from == found.classPathEntry)
return mutator.apply(from);
else
return from;
IClasspathContainer containerSuggestion = new IClasspathContainer() {
public IPath getPath() {
return found.container.getPath();
public int getKind() {
return found.container.getKind();
public String getDescription() {
return found.container.getDescription();
public IClasspathEntry[] getClasspathEntries() {
return newEntries;
initializer.requestClasspathContainerUpdate(found.container.getPath(), found.javaProject, containerSuggestion);
break;
default:
throw new IllegalStateException(found.toString());
} catch (Exception e) {
public class ArrayHelper {
public static <From, To> To[] map(Class<To> clazz, From[] old, IFunction1<From, To> mutator) {
try {
@SuppressWarnings({ "unchecked" })
To[] result = (To[]) Array.newInstance(clazz, old.length);
for (int i = 0; i < old.length; i++)
result[i] = mutator.apply(old[i]);
return result;
[Updated on: Mon, 08 August 2011 13:33] Report message to a moderator
Current Time: Thu Apr 25 22:21:04 GMT 2024
Powered by FUDForum. Page generated in 0.03283 seconds
