Home » Language IDEs » Java Development Tools (JDT) » How can I comment out a method?
How can I comment out a method? [message #708471] Tue, 02 August 2011 17:10 Go to next message
Hi there,
I have been looking through the jdt core api and the dom api also. I can't find out how to comment out a method from my source code programmatically. Can this be done? If so, how?
Many thanks for your help,
(no subject) [message #708829 is a reply to message #708471] Wed, 03 August 2011 03:31 Go to previous messageGo to next message
On 02.08.2011 23:10, john doe wrote:
> Hi there,
Change the source.
Dani
> Regards
Re: (no subject) [message #708970 is a reply to message #708829] Wed, 03 August 2011 06:51 Go to previous messageGo to next message
Why bother wasting resources to post such a condescending reply? I have a genuine question, which I thought would merit a genuine response. Anyway, I have reported your post to the mods.
[Updated on: Wed, 03 August 2011 07:15] by Moderator
Re: (no subject) [message #709051 is a reply to message #708970] Wed, 03 August 2011 08:56 Go to previous messageGo to next message
While this forum doesn't have moderators per se, I do agree that Dani's response is not helpful, and I wonder why one would even bother writing something like that.
Hopefully someone else will respond with a bit more insight.
Re: (no subject) [message #709111 is a reply to message #709051] Wed, 03 August 2011 09:56 Go to previous messageGo to next message
Because that is the right answer - though maybe a bit too short. There
is no API to comment code. You need to comment out the code by adding
the corresponding things to the source code. There are several API/ways
to change the source code in JDT Core.
Dani
Re: (no subject) [message #709157 is a reply to message #709111] Wed, 03 August 2011 10:22 Go to previous messageGo to next message
I guess looking on how CTRL+/ is implemented by guide the way how to do it.
Tom
Am 03.08.11 15:56, schrieb Daniel Megert:
> Dani
Re: (no subject) [message #709158 is a reply to message #709111] Wed, 03 August 2011 10:22 Go to previous messageGo to next message
Tom
> Dani
Re: (no subject) [message #709335 is a reply to message #709158] Wed, 03 August 2011 16:13 Go to previous messageGo to next message
Thanks for this Tom. Do you have a link for this?
Best Regards,
JD
Re: (no subject) [message #714216 is a reply to message #709335] Wed, 10 August 2011 00:32 Go to previous messageGo to next message
What do you mean by programmatically? As in, you want to disable a method during run-time from your program? I'm pretty sure that can't be done with a compiled language like Java. For that, you need an interpreted language. You may be able to achieve the same effect by setting a boolean value, and only executing that method if the boolean value is true...
[Updated on: Wed, 10 August 2011 00:32] by Moderator
Re: (no subject) [message #715400 is a reply to message #714216] Sat, 13 August 2011 14:53 Go to previous message
Is there a way, through the api (programatically) that I can assign a comment '//' to a line of code? No, I do not mean "disable a method".
[Updated on: Sat, 13 August 2011 14:53] by Moderator
Previous Topic:google app engine
Next Topic:How to apply change to source code?
Current Time: Mon Mar 17 06:29:52 EDT 2025
Powered by FUDForum. Page generated in 0.04207 seconds
