Home » Modeling » M2T (model-to-text transformation) » [acceleo] mtl and emtl, what is the difference?
[acceleo] mtl and emtl, what is the difference? [message #708149] Tue, 02 August 2011 14:06 Go to next message
Leonardo Kenji Shikida is currently offline Leonardo Kenji ShikidaFriend
Member
acceleo generates a mtl file (model) but my deployed eclipse feature runtime asks for an emtl file.
java.io.IOException: '/br/com/spread/acceleo/presto/main/generate.emtl' not found
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:409)
at br.com.spread.acceleo.presto.main.Generate.<init>(Generate.java:90)
at br.com.spread.acceleo.presto.ui.common.GenerateAll.doGenerate(GenerateAll.java:90)
at br.com.spread.acceleo.presto.ui.popupMenus.AcceleoGeneratePrestoAction$1.run(AcceleoGeneratePrestoAction.java:76)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
what is the difference? how do I generate an emtl file?
TIA
Kenji
(no subject) [message #708284 is a reply to message #708149] Tue, 02 August 2011 16:14 Go to previous messageGo to next message
No. The Acceleo editor enables yoy to maintain the *.mtl file.
The Acceleo builder geneerates a relkated *.java and *.emtl files in
your bin tree.
Check that you have the Acceleo nature for your project and use the
Navigator to inspect your bin tree.
"/br/com" is really wierd. Looks like a typo.
Ed Willink
> at
> at
> at
> at
> TIA
> Kenji
Re: (no subject) [message #708317 is a reply to message #708284] Tue, 02 August 2011 17:22 Go to previous messageGo to next message
Member
I see
so, I suppose my plugin must export these compiled models as well, in order to make it work.
I´ve changed my acceleo project build.properties to include the /bin dir, but still my acceleo ui plugin is not exporting these files (they´re not in the generated jars).
Where do I configure my acceleo ui plugin to export these compiled models? Here is the sequence of steps I am using to export the generator
[1] acceleo project compiles the models into its /bin dir
[2] acceleo ui project plugin references acceleo project
[3] eclipse feature project includes {acceleo ui project, acceleo project, emf model project and generated emf edit and editor projects}
[4] eclipse update site project references eclipse feature project and deploys in a local dir
[5] another eclipse installs the feature via (local) update site
update: so I´ve just copied the emtl files from bin to src and then everything seems to be working now, but I feel a little stupid doing this. Is there anything I can set to make all these compiled models go to where they should in the plugin generation process?
TIA
Kenji
ps. "br" looks like a typo indeed Wink
[Updated on: Tue, 02 August 2011 19:58]
Report message to a moderator
Re: (no subject) [message #709716 is a reply to message #708317] Thu, 04 August 2011 08:15 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Kenji,
The "mtl" file is what you edit when you create an Acceleo module, the "emtl" is the "compiled" form of that file. Kind of what the ".class" is to a ".java". i.e : the Acceleo builder is in charge of creating the emtl file, you should never have to worry about that (and don't have to).
Make sure that :
- You have the Acceleo nature on your project (right-click the project > Properties > "Builders" and in that list, you should see the "Acceleo builder" activated).
- You have the automatic build activated (click the "Project" menu item at the top of the Eclipse window, from there, make sure that "Build automatically" is ticked. If it is not, make sure you always build your project before deploying it (the emtl is present in the "bin" folder))
With these steps, creating an update site for the project *should* export the "emtl" files along the "class" files (if you have some Java code in there, otherwise, only "emtl" files). If it does not, it is a bug :s. We had such a bug with the previous Acceleo version, and I do not remember whether it was fixed for 3.0.0 or one of the subsequent minor releases. The latest release is the 3.1.0; the latest release from the maintenance stream is the 3.0.5. Check the download page for the update site URLs.
Laurent Goubet
Obeo
Re: problem with Acceleo .emtl file [message #1754838 is a reply to message #709716] Thu, 23 February 2017 00:37 Go to previous message
Jakub Kitaj is currently offline Jakub KitajFriend
I had same problem like you (java.io.IOException: '/br/com/spread/acceleo/presto/main/generate.emtl' not found). I resolve it by two steps:
  1. exporte /bin folder into the update site: in acceleo project in MANIFEST.MF from the META-INF directory, in tab Build check the bin folder in the Binary Build list
  2. in acceleo project main java class change auto generated MODULE_FILE_NAME value (for example: "/br/com/spread/acceleo/presto/main"): add "/bin" at the beginning (for example: "/bin/br/com/spread/acceleo/presto/main")
Previous Topic:[Acceleo] Unable to see IFML metamodels - how to generate code from IFML?
Next Topic:[Acceleo standalone]
Current Time: Mon Dec 09 18:02:57 GMT 2019
Powered by FUDForum. Page generated in 0.02150 seconds
