Re: Embeddable report and CSS [message #708255 is a reply to message #708048] |
Tue, 02 August 2011 15:56 |
I just tried this in 3.7 and in 2.6.2 and both worked. What version are
you using 2.6.0 or 2.6.1.
Jason
On 8/2/2011 7:35 AM, Em wrote:
> I'm having an issue with the HTMLRenderOption.setEmbeddable option. I'm
> trying to embed a report in an existing web page and I'm using an
> external CSS style sheet in the report, the same CSS I'm using in the page.
> When the setEmbeddable property is set to false the report generates an
> HTML output with the classes that are defined in the style sheet,
> something like '<div class="name">Entry 1</div>', but if I set the
> setEmbeddable property to true all the imported classes are removed from
> the generated HTML and the previous example becomes '<div>Entry 1</div>'.
> Is this the normal behavior for BIRT? Shouldn't only the html and body
> tags be removed when I setEmbeddable to true?
> I'm using BIRT 2.6 and the code I'm using is this:
> ByteArrayOutputStream output = new ByteArrayOutputStream();
> IHTMLRenderOption options = new HTMLRenderOption();
> options.setOutputFormat(IHTMLRenderOption.OUTPUT_FORMAT_HTML);
> options.setEmitterID(HTMLRenderOption.OUTPUT_EMITTERID_HTML);
> options.setOutputStream(output);
> options.setEmbeddable(true);
> options.setBaseImageURL(getContext().getRequest().getContextPath() +
> "/images");
> options.setImageDirectory(getContext().getServletContext().getRealPath("/images"));
> options.setImageHandler(new HTMLServerImageHandler());
> options.setMasterPageContent(false);
Re: Embeddable report and CSS [message #708298 is a reply to message #708271] |
Tue, 02 August 2011 16:52 |
Here is my code. Attached is the report and css file.
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
public class RunAndRenderTask {
public void runReport() throws EngineException
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config = new EngineConfig( );
config.setLogConfig("c:/dwn", Level.INFO);
config.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY,
this.getClass().getClassLoader());
//config.getAppContext().put(EngineConstants.WEBAPP_CLASSPATH_KEY,
"C:\\work\\workspaces\\2.6.2workspaces\\BIRT
Metal\\APIs\\Reports\\eventjar.jar");
config.setBIRTHome("C:\\birt\\birt-runtime-2_6_2\\birt-runtime-2_6_2\\ReportEngine");
config.setLogConfig(null, Level.INFO);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/external.rptdesign");
task = engine.createRunAndRenderTask(design);
//task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
options.setImageDirectory("./");
options.setOutputFileName("output/resample/external.html");
options.setOutputFormat("html");
//PDFRenderOption options = new PDFRenderOption();
//options.setOutputFileName("output/resample/fonttest.pdf");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
//options.setOutputFormat("pdf");
//EXCELRenderOption options = new EXCELRenderOption();
//options.setOutputFormat("xls");
//options.setOutputFileName("output/resample/customers.xls");
//options.setWrappingText(true);
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
Jason
On 8/2/2011 12:21 PM, Em wrote:
> Jason Weathersby wrote on Tue, 02 August 2011 11:56
>> are you using 2.6.0 or 2.6.1.
>> Jason
> Jason, thank you for your reply, could you please show me the sample
> code you've used?
Re: Embeddable report and CSS [message #708342 is a reply to message #708298] |
Tue, 02 August 2011 18:03 |
Em Messages: 10 Registered: August 2011 Location: Portugal |
Jason, thank's again for your reply, I can't seem to find the problem and the only big difference I can find is that I'm using the report in a web application using ActionBean's and JSP's on JBOSS 6.0
The output HTML generated by BIRT is being embedded into a JSP.
I'm attaching the test project I'm working on together with a sample output HTML I'm getting in the browser. I've removed the jar's from BIRT to save size.
Could you be kind enough to take a look at it if you have the time.
Thank you.
Attachment: output.zip
(Size: 1.09MB, Downloaded 236 times)
[Updated on: Tue, 02 August 2011 18:08] Report message to a moderator
FUDForum. Page generated in 0.02629 seconds
