(no subject) [message #710004 is a reply to message #707977] |
Thu, 04 August 2011 15:02 |
Originally posted by:
Hi.
Though i cant really help you with your specific problem, i want to
mention two things:
- The "qooxdoo" in current RAP is heavily modified and most widgets are
RAP-specific implementations, i.e. you will most likely find no qx
simulator that will really work.
- That beeing said, there already have been discussions regarding RAP
and Selenium on this newsgroup that you could search for, though that
was way back, so the info may be outdated.
Greetings,
Tim
Am 02.08.2011 11:44, schrieb mrbazsee:
> Hi all,
> I am working with RAP 1.4 and try to implement some automated UI tests.
> I did some research and started to use qooxdoo's user extension with
> Selenium. Then I realized that RAP uses qooxdoo v0.7.4 which is
> incompatible with the latest version of the user extension. After that I
> switched to qooxdoo Simulator v0.1 (based on the release notes this is
> the only one which works fine with qooxdoo v0.7.x) but it has a very
> limited funcionality and I still got some errors.
> My question is if anyone can tell me which version of the qx Simulator
> should work properly?
> Thanks in advance!
> Balazs
FUDForum. Page generated in 0.03007 seconds
