Home » Modeling » TMF (Xtext) » StackOverFlowError
StackOverFlowError [message #707059] Mon, 01 August 2011 07:37 Go to next message
Arun  is currently offline Arun Friend
A huge StackOverFlowError is shown for my grammar. What could be the reason?
51295 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher -
java.lang.StackOverflowError
at org.eclipse.xtext.parsetree.NodeContentAdapter.updateCompositeNode(NodeContentAdapter.java:121)
at org.eclipse.xtext.parsetree.NodeContentAdapter.updateCompositeNode(NodeContentAdapter.java:132)
Arun
Re: StackOverFlowError [message #707067 is a reply to message #707059] Mon, 01 August 2011 07:48 Go to previous messageGo to next message
Adding to that,
The error occurs for unordered group,
CProperty1:
"property" name=ID "{"
("mappedTo" mappedTo=STRING)?
("type" mappedType=MappedType)?
("repository" repository=STRING)?
&("queryable" queryableOP=TrueFalseOption)?
&("readable" readableOP=TrueFalseOption)?
&("writable" writableOP=TrueFalseOption)?
&("required" requiredOP=FalseTrueOption)?
&("hidden" hiddenOP=FalseTrueOption)?
&("expert" expertOP=FalseTrueOption)?
&("cascade" cascade=CascadeType)?
&("cache-mode" cachMode=CacheType)?
&("group" group=ID)?
&("description" description=STRING)?
&("description-resource" descriptionResource=STRING)?
&("displayname" displayName=STRING)?
&("displayname-resource" displayNameResource=STRING)?
&("category" category=STRING)?
&("category-resource" categoryResource=STRING)?
If i remove the '&' no error is reported. But my requirement is unordered group.
Arun
Re: StackOverFlowError [message #707083 is a reply to message #707067] Mon, 01 August 2011 08:00 Go to previous message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Arun,
did you consider to upgrade to Xtext 2.0? There were fixes in this field.
Another thing that seems suspicious to me is the first part of your
unordered group:
("repository" repository=STRING)? &("queryable"
&("readable" readableOP=TrueFalseOption)? ..
is essentially the same as
I'm not sure about your syntax but I guess it should more look like this:
Hope that helps,
Sebastian
On 01.08.11 09:48, Arun wrote:
> Adding to that,
> CProperty1:
> &("hidden" hiddenOP=FalseTrueOption)? &("expert" expertOP=FalseTrueOption)?
> unordered group.
> Arun
Previous Topic:[Xtend] Increase a postfix in a for loop
Next Topic:(no subject)
Current Time: Thu May 13 19:00:13 GMT 2021
Powered by FUDForum. Page generated in 0.01980 seconds
