Home » Eclipse Projects » Equinox » SWTBot OSGi trouble...(my osgi does not init bundle .swtbot..headless...)
SWTBot OSGi trouble... [message #707047] |
Mon, 01 August 2011 07:06 |
Bernhard Anzeletti Messages: 17 Registered: July 2011 Location: Austria |
Dear friends of RCP,
Currently I am trying to get SWTBot headless tests running using my Windows7 / Indigo / x86 (32bit) installation. I have a nice .cmd file (which can actually start my product in the target), but when I try with swtbottestapplication, things go terribly awry. The clue seems to be that the headless plugin asks for import package org.eclipse.ui (NOT Required Bundle), which osgi obviously does not want to provide.
Any help highly appreciated.
Additional Info
When I keep the framework running and query the eclipse.ui bundle status, it is "LAZY" in the first place. When I manually activate it, it gets "ACTIVATED", but I still cannot activate the swtbot.headless plugin because of the missing package import. Looks as if I had to declare some additional "friendship" relations... or is this wrong kind of thinking?
Further question: simpleconfigurator
Examining the standard config.ini files, I came across a "simpleconfigurator". I suppose this is a vehicle for installing all bundles in a specific directory (kind of). Am I right?
Kind regards,
Bernhard
Start Command
C:\ANBInstall\Sun\jdk32_6_23\bin\java ^
-Xms256m -Xmx768m -XX:MaxPermSize=512m ^
-classpath c:\ANBWork\ANBERNCommander.wip\test\eclipse\plugins\org.eclipse.equinox.launcher_1.2.0.v20110502.jar ^
org.eclipse.core.launcher.Main ^
-install C:/ANBWork/ANBERNCommander.wip/test/eclipse ^
-application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication ^
-testApplication com.anbern.commander.application ^
-product com.anbern.commander.product ^
-data C:/ANBWork/ANBERNCommander.wip/test/workspace ^
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,C:/ANBWork/ANBERNCommander.wip/test/result/TestResult.xml ^
-testPluginName com.anbern.commander.test ^
-className com.anbern.commander.test.CommanderUITest ^
-arch x86 ^
-debug ^
-consoleLog
Config.ini
(located in eclipse/configuration)
#Product Runtime Configuration File
osgi.bundles.defaultStartLevel=4
osgi.install.area=C:\ANBWork\ANBERNCommander.wip\test\eclipse
osgi.bundles=com.anbern.commander,\
com.ibm.icu,\
org.eclipse.core.commands,\
org.eclipse.core.contenttype,\
org.eclipse.core.databinding,\
org.eclipse.core.databinding.beans,\
org.eclipse.core.databinding.observable,\
org.eclipse.core.databinding.property,\
org.eclipse.core.expressions,\
org.eclipse.core.jobs,\
org.eclipse.core.runtime@start,\
org.eclipse.core.runtime.compatibility.auth,\
org.eclipse.equinox.common@2:start,\
org.eclipse.equinox.preferences,\
org.eclipse.equinox.registry,\
org.eclipse.equinox.app,\
org.eclipse.equinox.ds,\
org.eclipse.equinox.launcher,\
org.eclipse.equinox.simpleconfigurator,\
org.eclipse.equinox.util,\
org.eclipse.rcp,\
org.eclipse.update.configurator,\
org.eclipse.jface,\
org.eclipse.jface.databinding,\
org.eclipse.osgi.services,\
org.eclipse.swt,\
org.eclipse.swt.win32.win32.x86,\
org.eclipse.ui,\
org.eclipse.ui.workbench,\
org.eclipse.help,\
org.eclipse.core.runtime.compatibility,\
org.apache.log4j,\
org.hamcrest,\
org.hamcrest.text,\
org.hamcrest.library,\
org.hamcrest.integration,\
org.hamcrest.core,\
org.apache.ant,\
org.junit,\
org.junit4,\
org.eclipse.jdt.junit.runtime,\
org.eclipse.swtbot.swt.finder,\
org.eclipse.swtbot.junit4_x,\
org.eclipse.swtbot.eclipse.finder,\
org.eclipse.swtbot.eclipse.core,\
org.eclipse.swtbot.ant.optional.junit4,\
Result
Sadly, when I run all this I receive:
!ENTRY org.eclipse.osgi 2 0 2011-07-29 16:54:55.249
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-07-29 16:54:55.249
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.swtbot.eclipse.junit4.headless_2.0.4.20110304_0338-e5aff47-dev-e36/ was not resolved.
!SUBENTRY 2 org.eclipse.swtbot.eclipse.junit4.headless 2 0 2011-07-29 16:54:55.249
!MESSAGE Missing imported package org.eclipse.ui_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2011-07-29 16:54:55.265
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-07-29 16:54:55.265
!MESSAGE Bundle org.eclipse.swtbot.eclipse.junit4.headless_2.0.4.20110304_0338-e5aff47-dev-e36 [141] was not resolved.
!SUBENTRY 2 org.eclipse.swtbot.eclipse.junit4.headless 2 0 2011-07-29 16:54:55.265
!ENTRY org.eclipse.osgi 4 0 2011-07-29 16:54:55.265
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" could not be found in the registry. The applications available are: com.anbern.commander.application, org.eclipse.equinox.app.error, org.eclipse.swtbot.eclipse.core.swtbottestapplication.
Current Time: Thu Apr 25 13:20:57 GMT 2024
Powered by FUDForum. Page generated in 0.02709 seconds
