Re: PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73556 is a reply to message #73539] |
Mon, 16 June 2008 22:29 |
Originally posted by: codeslave.ca.ibm.com
AFAIK, PDT 1.0.x won't run on Eclipse 3.4. You want PDT 1.1.
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.4_.2F_Gan ymede_.2F_PDT_1.1
Nick
Shawn Clark wrote:
> Trying to get PDT 1.0.3 installed with the latest release of 3.4.
> 1. Downloaded eclipse-SDK-3.4RC4-win32.zip
> 2. Extracted and setup Eclipse
> 3. Downloaded org.eclipse.php_feature-R20080603.zip
> 4. Extraced 1.0.3 and noticed in the feature.xml under the features
> folder that the required components are:
> <requires>
> <import feature="org.eclipse.wst" version="2.0.0"
> match="compatible"/>
> <import feature="org.eclipse.platform" version="3.3.0"
> </requires>
> 5. The platform is already installed but is 3.4.0 (3.4.0.v20080606)
> 6. Installed the Web Standard Tools for 3.4 (3.0.0.v200806040035)
> At this point I tried to get the PDT running in Eclipse 3.4 but it won't
> enable itself for use. My main concerns are that the WST is now 3.0.0
> and the platform is 3.4.0. Will that work okay with PDT?
> I also checked the release web page about it needing EMF SDO XSD 2.3.2,
> GEF 3.3.2 and WTP 2.0.2 so I installed the complementing versions for
> the Ganymede release:
> EMF Runtime - 2.4.0.v200806091234
> XSD Runtime - 2.4.0.v200806091234
> EMF SDO Runtime - 2.4.0.v200806091234
> GEF - 3.4.0.v20080115
> Web Developer Tools - 3.0.0v200806040035 (I believe this is the
> replacement for WTP)
> Even after installing those add-ons I still can't get the PDT to run.
> Any suggestions???
> Shawn Clark
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PDT 1.0.3 and Eclipse 3.4 (Ganymede) [message #73591 is a reply to message #73574] |
Tue, 17 June 2008 02:11 |
Try it and see. 1.1 is due in September, along with Eclipse 3.4.1.
Here's hoping that the PDT guys decide next year to align with Io
(Eclipse 3.5's coordinated release). *Hint, hint!*
Nick
Shawn Clark wrote:
> Thanks for the link. From my understanding a release of 1.1 isn't going
> to be available until the middle of September while Eclipse 3.4 is
> available shortly. Is the 1.1 far enough along to be in a usable state
> for development work?
> Shawn Clark
>> Nick
>>> <requires>
>>> </requires>
>>> won't enable itself for use. My main concerns are that the WST is now
>>> 3.0.0 and the platform is 3.4.0. Will that work okay with PDT?
>>> 2.3.2, GEF 3.3.2 and WTP 2.0.2 so I installed the complementing
>>> versions for the Ganymede release:
>>> Any suggestions???
>>> Shawn Clark
FUDForum. Page generated in 0.02443 seconds
