Question on persistence of Enumeration data types using CDO [message #588] |
Fri, 14 October 2005 22:03 |
Originally posted by: tvalence1.cox.net
Greetings Eike,
I am trying to use CDO to persist an object that has an attribute that is an
Enumeration data type.
I've attached a detailed stack trace and the generated code for the datatype
in question for reference.
Unfortuntately, when I try to persist the object to a CDO resource, I
receive the following exception:
[DEBUG] common.connector-channel-1:
[DEBUG]
common.connector-channel-1: ------------------------------------------------------------ ---------
[DEBUG] common.connector-channel-1: Transmitting request CommitTransaction
[DEBUG] common.connector-channel-1: commitObjectsToDetach()
[DEBUG] common.connector-channel-1: commitObjectsToAttach(30 objects)
[DEBUG] common.connector-channel-1: Transmitting object to attach: oid=1:-1,
cid=10, isContent=true
[DEBUG] common.connector-channel-1: Transmitting object to attach: oid=1:-3,
cid=5, isContent=false
[DEBUG] common.connector-channel-1: Transmitting attributeSegment
mymodel.Process
[DEBUG] common.connector-channel-1: Transmitting attribute description
[DEBUG] common.connector-channel-1: Transmitting attribute priority
[DEBUG] common.connector-channel-1: Transmitting attribute validFrom
[DEBUG] common.connector-channel-1: Transmitting attribute validTo
[DEBUG] common.connector-channel-1: Transmitting attribute timeEstimation
[DEBUG] common.connector-channel-1: Transmitting attribute durationUnit
[DEBUG] com.mycompany.myapp.correlator.InterpreterCorrelator: The datatype
'DurationUnit' is not a valid classifier
Am I missing something in the genmodel settings for CDO that are required to
properly handle the serialization of enumerated data types?
Any assistance would be greatly appreciated.
Thanks!
= Ted Valencia
Re: Question on persistence of Enumeration data types using CDO [message #603 is a reply to message #588] |
Sat, 15 October 2005 06:31 |
Originally posted by: stepper.sympedia.de
Hi Ted,
I remember that a similar issue has been fixed some time ago.
Please try to update the sources from HEAD.
Does it do the trick?
Cheers
/Eike
p.s. As soon as EMFT Bugzilla is available for CDO, I will start
tracking issues and proper releases, so that it will be
easier to detect the need of CVS updates...
TVal schrieb:
> Greetings Eike,
> [DEBUG]
> mymodel.Process
> Thanks!
> = Ted Valencia
Re: Question on persistence of Enumeration data types using CDO [message #616 is a reply to message #603] |
Mon, 17 October 2005 22:36 |
Hi Eike,
The code update fixed the issue.
Thanks!
- Ted
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:diq7j5$bou$1@news.eclipse.org...
> Hi Ted,
> Cheers
> /Eike
> TVal schrieb:
>> Greetings Eike,
>> an Enumeration data type.
>> datatype in question for reference.
>> [DEBUG]
>> CommitTransaction
>> oid=1:-1, cid=10, isContent=true
>> oid=1:-3, cid=5, isContent=false
>> mymodel.Process
>> datatype 'DurationUnit' is not a valid classifier
>> to properly handle the serialization of enumerated data types?
>> Thanks!
>> = Ted Valencia
Re: Question on persistence of Enumeration data types using CDO [message #560982 is a reply to message #588] |
Hi Ted,
Cheers
/Eike
TVal schrieb:
> Greetings Eike,
> [DEBUG]
> mymodel.Process
> Thanks!
> = Ted Valencia
Cheers
/Eike
http://www.esc-net.de
Re: Question on persistence of Enumeration data types using CDO [message #560996 is a reply to message #603] |
Hi Eike,
Thanks!
- Ted
> Hi Ted,
> Cheers
> /Eike
> TVal schrieb:
>> Greetings Eike,
>> [DEBUG]
>> CommitTransaction
>> mymodel.Process
>> Thanks!
>> = Ted Valencia
FUDForum. Page generated in 0.03771 seconds
