Home » Archived » M2M (model-to-model transformation) » Call atl ant script by java
Call atl ant script by java [message #73385] Fri, 25 January 2008 18:32 Go to next message
wong is currently offline wongFriend
Member
I use java code to call the atl ant script, but I got this error:
java.lang.Exception: Problem: failed to create task or type am3.loadModel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
How can I fix this.
I have read the post for how to run the transformation programmatically.
But I want call the ant script which is much easier.
Wong.
Re: Call atl ant script by java [message #73407 is a reply to message #73385] Sat, 26 January 2008 15:18 Go to previous messageGo to next message
Daniel van 't Oever is currently offline Daniel van 't OeverFriend
make sure you are running the ant script from within the same VM as
Eclipse is running (via Run as... -> runtime environment )
wong wrote:
> Hello,
> place.
> How can I fix this.
> Wong.
Re: Call atl ant script by java [message #73518 is a reply to message #73407] Mon, 28 January 2008 10:40 Go to previous messageGo to next message
Member
I had the setting you said. I have no problem with running the ant script
manually. The problem comes when I use a java code to call the ant script.
Wong.
Re: [AM3] Call atl ant script by java [message #74508 is a reply to message #73518] Tue, 05 February 2008 16:37 Go to previous message
Frédéric Jouault is currently offline Frédéric JouaultFriend
Because the question is more related to AM3 than to M2M, I am putting
the GMT newsgroup in copy.
> script manually. The problem comes when I use a java code to call the
> ant script.
You can find an example in:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /AM3/org.eclipse.am3.ui/src/org/eclipse/am3/ui/action/Action ANTAction.java?view=markup
Frédéric Jouault
Previous Topic:[ATL] Called Rules Parameter Passing
Next Topic:[ATL] AtlLaunch
Current Time: Tue May 18 18:37:31 GMT 2021
Powered by FUDForum. Page generated in 0.01517 seconds
