Home » Language IDEs » PHP Development Tools (PDT) » Problems after upgrade
Problems after upgrade [message #73382] Fri, 13 June 2008 04:54 Go to next message
Originally posted by: peter.hopfgartner.r3-gis.com
Dear PDT community,
I upgraded PDT to 1.0.3 yesterday. PDT runs in:
Version: 3.3.2
Build id: M20080221-1800
on an Ubuntu 7.10, 64 bit Linux.
Since the upgrade some things do not work anymore. Code formatting, as
started with CRTL-SHIFT-F alignes everything to the first column and auto
completion seems to have stopped working.
Code coloring etc. is fine.
I did not change the PDT preferences. Even when looking at them, they look
ok.
Can I do anything to help identifying the cause?
Peter Hopfgartner
R3 GIS
http://www.r3-gis.com
Re: Problems after upgrade [message #73450 is a reply to message #73382] Sun, 15 June 2008 09:01 Go to previous messageGo to next message
Please try to use clean workspace, and tell me whether it works.
Thanks!
Peter Hopfgartner wrote:
> Dear PDT community,
> Version: 3.3.2
> auto completion seems to have stopped working.
> look ok.
> Best regards,
> Peter Hopfgartner
> R3 GIS
Re: Problems after upgrade [message #73485 is a reply to message #73450] Mon, 16 June 2008 04:17 Go to previous messageGo to next message
Bingo,
I've created a new workspace and it looks good: indentation in fine, code
completion works.
Even if I import an existing PHP project with the new workspace everything
indents fine.
Thanks a lot! Would you need any further info for this issue. Should I
file a bug report?
Peter Hopfgartner
R3 GIS
Re: Problems after upgrade [message #73503 is a reply to message #73485] Mon, 16 June 2008 08:31 Go to previous messageGo to next message
If you have more information, e.g. reproduction scenario or exception
logs - yes, please file a bug report.
Thanks!
> Bingo,
> code completion works.
> everything indents fine.
> file a bug report?
> Regards,
> Peter Hopfgartner
> R3 GIS
Re: Problems after upgrade [message #73681 is a reply to message #73503] Wed, 18 June 2008 03:56 Go to previous messageGo to next message
Too bad, while experimenting with the different workspaces I must have
overwritten the original one, so I am not able to reproduce the problem
any more. As far as I remember there were no exceptions thrown, simply
indentation/autocompletion/error checking did not work.
Thank you,again.
Peter
Re: Problems after upgrade [message #73698 is a reply to message #73681] Wed, 18 June 2008 10:03 Go to previous message
Originally posted by: codeslave.ca.ibm.com
If you run with these flags you'll capture extra output to the console,
just in case:
-consolelog -clean -debug -console -noexit
You can also use that to interact w/ the OSGi console, should you ever
need to diagnose plugins that fail to load, etc.
FYI:
-noexit prevents the console from closing down w/o your explicit request
(typing 'exit' or CTRL-C);
-console launches the OSGi console;
-consolelog ensures that everything captured in workspace/.metadata/.log
is also routed to the local console where you ran ./eclipse or eclipse.exe;
-clean forces Eclipse to reload its plugin registry so it finds anything
recently added / removed;
-debug provides more debug info in the console
> Thank you,again.
> Regards,
> Peter
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Previous Topic:PDT 1.0.3 and Eclipse 3.4 (Ganymede)
Next Topic:PDT (1.0.3) with X-Debug (2.0): Variables view
Current Time: Sat Nov 08 23:32:16 EST 2025
Powered by FUDForum. Page generated in 0.04186 seconds
