Hi [message #72816] |
Thu, 22 June 2006 21:42 |
Originally posted by: mperalta8.hotmail.com
I need help, I try to use ant in eclipse sdk but whend I send a
compilation, in the console apears these message:
and cannot see what is the fail, I have install sdk1.4.2_12 and I use
eclipse 3.1.2
BUILD FAILED
C:\fixj\quickfixj\build.xml:129: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Total time: 3 seconds
Re: Hi [message #72832 is a reply to message #72816] |
Fri, 23 June 2006 08:04 |
Originally posted by: eclipse.bettsockentraeger.de
Have you added the jdk under Preferences -> Java -> Installed JRE's? Is
it selected? If not add it there and check it so that eclipse actually
uses the jdk and not the jre.
Next check if the ant runtime is setup. Preferences -> Ant -> Runtime It
should point to the ant plugin distributed with eclispe (this is as far
as I know default). If it doesn't point to the ant plugin or an ant
installation. Look in the plugin folder in your eclipse installation for
a plugin org.apache.ant_xxx where xxx is the version It should be 1.6.5
or so for Eclipse 3.1.2
Stefan
> eclipse 3.1.2
> Regards
> BUILD FAILED
FUDForum. Page generated in 0.02223 seconds
