JPA EclipseLink unknown entity type issue [message #704219] |
Thu, 28 July 2011 11:53 |
RameshDasari Messages: 4 Registered: July 2011 |
I am working with spring 3.0.3, JPA 2.0, EclipseLink 2.0 and JBOSS 6.0.
Stack Trace
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.dao.InvalidDataAccessApiUsageException: Object: User [id=0, userName=, email=] is not a known entity type.; nested exception is java.lang.IllegalArgumentException: Object: User [id=0, userName=, email=] is not a known entity type.
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:656)
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:560)
javax.servlet.http.HttpServlet.service(HttpServlet.java:754)
javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
root cause
org.springframework.orm.jpa.EntityManagerFactoryUtils.convertJpaAccessExceptionIfPossible(EntityManagerFactoryUtils.java:286)
org.springframework.orm.jpa.DefaultJpaDialect.translateExceptionIfPossible(DefaultJpaDialect.java:120)
org.springframework.dao.support.DataAccessUtils.translateIfNecessary(DataAccessUtils.java:213)
org.springframework.orm.jpa.JpaAccessor.translateIfNecessary(JpaAccessor.java:152)
org.springframework.orm.jpa.JpaTemplate.execute(JpaTemplate.java:188)
org.springframework.orm.jpa.JpaTemplate.persist(JpaTemplate.java:262)
com.chrysler.cvp.dao.impl.UserDAOImpl.addUser(UserDAOImpl.java:42)
com.chrysler.cvp.rdu.web.controller.VehicleListController.processMyUserForm(VehicleListController.java:92)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:175)
org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:421)
org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:409)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:774)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
root cause
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectForPersist(UnitOfWorkImpl.java:4147)
org.eclipse.persistence.internal.jpa.EntityManagerImpl.persist(EntityManagerImpl.java:368)
org.springframework.orm.jpa.ExtendedEntityManagerCreator$ExtendedEntityManagerInvocationHandler.invoke(ExtendedEntityManagerCreator.java:365)
$Proxy180.persist(Unknown Source)
org.springframework.orm.jpa.JpaTemplate$5.doInJpa(JpaTemplate.java:264)
org.springframework.orm.jpa.JpaTemplate.execute(JpaTemplate.java:183)
Entity class
package com.chrysler.cvp.dao.entity;
import java.io.Serializable;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.Table;
@Entity
@Table(name="data")
public class User implements Serializable{
private static final long serialVersionUID = 1L;
@Id
@GeneratedValue(strategy=GenerationType.AUTO)
private int id;
@Column(name="USER_NAME")
private String userName;
@Column(name="EMAIL")
private String email;
public int getId() {
return id;
public void setId(int id) {
this.id = id;
public String getUserName() {
return userName;
public void setUserName(String userName) {
this.userName = userName;
public String getEmail() {
return email;
public void setEmail(String email) {
this.email = email;
public String toString() {
return "User [id=" + id + ", userName=" + userName + ", email=" + email
Persistence.xml
<persistence-unit name="Sample" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<non-jta-data-source>java:/MySqlDS</non-jta-data-source>
<class>com.chrysler.cvp.dao.entity.User</class>
<properties>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<property name="javax.persistence.jdbc.url" value="url" />
<property name="javax.persistence.jdbc.user" value="as" />
<property name="javax.persistence.jdbc.password" value="" />
<property name="eclipselink.dialect"
value="org.springframework.orm.jpa.vendor.EclipseLinkJpaDialect" />
</properties>
</persistence-unit>
</persistence>
pom.xml
<repositories>
<repository>
<id>EclipseLink Repo</id>
<!-- note that ampersands in this URL are escaped because this is in an
xml file - un-escape them to use in browser -->
<url>&nf=1&file=/rt/eclipselink/maven.repo</url>
<!-- use this for javax.persistence <snapshots> <enabled>true</enabled>
</snapshots> -->
</repository>
</repositories>
<dependency>
<groupId>org.eclipse.persistence</groupId>
<artifactId>javax.persistence</artifactId>
<version>2.0.0</version>
</dependency>
<dependency>
<artifactId>eclipselink</artifactId>
</dependency>
Due to conflict problem i am removing the above jar files from my war file. And i kept those two in JBOSS_HOME/server/default/lib.
I am able to hit the database by passing JPA queries through JpaTemplate methods. When i am dealing with entity object i am getting this error. Please help me out.
Ramesh Dasari
FUDForum. Page generated in 0.02210 seconds
