Home » Archived » XML Schema Definition (XSD) » import resolution and namespaces
import resolution and namespaces [message #72435] |
Tue, 19 June 2007 18:39 |
Originally posted by: t.agnoloni.gmail.com
hi,
we are having problems in the resolution of imported schemas.
I enclose here an ultrasimplified version of the schema we are dealing
with.
nirstrict.xsd:
_________________________________________________
<xsd:schema
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:h="http://www.w3.org/HTML/1998/html4"
targetNamespace="http://www.normeinrete.it/nir/2.2/"
xmlns="http://www.normeinrete.it/nir/2.2/"
xmlns:dsp="http://www.normeinrete.it/nir/disposizioni/2.2/"
elementFormDefault="qualified"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
<xsd:import namespace="http://www.w3.org/HTML/1998/html4"
schemaLocation="./h.xsd"/>
<!--<xsd:group name="elblocchi">
<xsd:choice>
<xsd:element ref="h:div"/>
<xsd:element ref="h:p"/>
<xsd:element ref="h:img"/>
<xsd:element ref="h:table"/>
</xsd:choice>
</xsd:group>-->
<xsd:element name="Legge" type="xsd:string" />
</xsd:schema>
_____________________________________________________
h.xsd :
<xsd:schema targetNamespace="http://www.w3.org/HTML/1998/html4"
xmlns:h="http://www.w3.org/HTML/1998/html4" elementFormDefault="qualified"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:import namespace="http://www.normeinrete.it/nir/2.2/"
schemaLocation="./nirstrict.xsd"/>
<xsd:element name="p" type="xsd:string" />
</xsd:schema>
The problem is in the resolution of the imported schema h.xsd from the
main schema nirstrict.xsd
The code we are using is the following
* @param schemaURL
* @return
* @throws Exception
public static XSDSchema loadSchemaUsingResourceSet(String schemaURL)
throws Exception{
System.out.println("--> Loading Schema Using Resource Set @ url
"+schemaURL);
XSDResourceFactoryImpl resourceFactory = new XSDResourceFactoryImpl();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",resourceFactory);
// prende il path assoluto di schemaURL
File file = new File(schemaURL);
if (file.isFile())
schemaURL =
URI.createFileURI(file.getCanonicalFile().toString()).toStri ng();
// Create a resource set and load the main schema file into it.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./xlink.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/xlink.xsd "));//,URI.createURI("./xlink.xsd"));
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./h.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/h.xsd "));//,URI.createURI("./h.xsd"));
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./dsp.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/dsp.xsd "));//,URI.createURI("./dsp.xsd"));
System.err.println("URIMAP:
" +resourceSet.getURIConverter().getURIMap().entrySet().toStri ng());
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdSchemaResource = null;
try
xsdSchemaResource =
(XSDResourceImpl)resourceSet.getResource(URI.createURI(schem aURL),true);
catch(Exception e)
System.err.println("Exception caught in method 'load schema using
ResourceSet' message = " + e.getMessage() + " xsdSchemaResource: " +
xsdSchemaResource);
Resource resource = (Resource)xsdSchemaResource;
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
// Iterate over the schema's content's looking for directives.
XSDSchema xsdSchema = xsdResource.getSchema();
for (Iterator contents = xsdSchema.getContents().iterator();
contents.hasNext(); )
XSDSchemaContent xsdSchemaContent =
(XSDSchemaContent)contents.next();
if (xsdSchemaContent instanceof XSDSchemaDirective)
XSDSchemaDirective xsdSchemaDirective =
(XSDSchemaDirective)xsdSchemaContent;
if (xsdSchemaDirective.getResolvedSchema() == null){
System.err.println("Unresolved schema "+
xsdSchemaDirective.getSchemaLocation() +" in " + xsdResource.getURI());
if(xsdSchemaDirective instanceof XSDImport){
XSDImport xsdSchemaImport = (XSDImport)xsdSchemaDirective;
System.err.println(" IMPORT: namespace -->
"+xsdSchemaImport.getNamespace());
System.err.println(" IMPORT: location -->
"+xsdSchemaImport.getSchemaLocation());
else {
System.err.println("Resolved schema "+
return xsdResource.getSchema();
System.err.println("loadSchemaUsingResourceSet(" + schemaURL + ") did
not contain any schemas!");
return null;
What we noticed is that if elements of the imported xsd are referred in
the main schema like here:
<xsd:choice>
</xsd:choice>
</xsd:group>
i.e. commenting out such block in nirstrict.xsd,
the import is resolved otherwise it is not.
see here the results in the two cases:
with references to h: elements
Resolved schema ./h.xsd in
file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/XSD _Test_2/nirstrict.xsd
IMPORT: namespace --> http://www.w3.org/HTML/1998/html4
IMPORT: location --> ./h.xsd
loaded schema
or without
Unresolved schema ./h.xsd in
In the actual schemas we are using we have two different version, a light
and a strict version. The light version which refers imported elements in
the main schema is correctly resolved, in the strict, where the imported
elements are referred from other included xsd files and not in the main
one, the import resolution does not succeed.
Do you have any hint on what could be the reason? Do we need to perform a
recursive import resolution ove all the resources in the resourceSet ?
Notice that all works in cases of include instead of import.
We also tried various URI Mapping like
or
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "http://www.w3.org/HTML/1998/html4/"),URI.createURI("./h.xsd"));
but none solves the problem. Which is the correct URI mapping for a case
like our:
Notice that, in the for cycle over the resources of the resourceSet, the
imported resources correctly inherit the absolute path from the main
resource.
In case you need the complete schema we are using I can send it. Running
xsdMainExample load and validate on it gives the same Unresolved import
problems.
Any help is greatly appreciated,
thanks in advance
Tommaso
Re: import resolution and namespaces [message #72456 is a reply to message #72435] |
Tue, 19 June 2007 18:54 |
Tommaso,
Imports are resolved on demand, i.e., when a name from that namespace
needs to be resolved, so if there isn't such a need, it won't be
resolved. This type of approach would force the resolution:
for (Object content : xsdSchema.getContents())
if (content instanceof XSDImport)
XSDImport xsdImport = (XSDImport)content;
xsdImport.resolveTypeDefinition(xsdImport.getNamespace(), "");
Tommaso wrote:
> hi,
> with.
> nirstrict.xsd:
> <xsd:schema xmlns:xlink="http://www.w3.org/1999/xlink"
> <xsd:choice>
> </xsd:choice>
> </xsd:group>-->
> </xsd:schema>
> h.xsd :
> </xsd:schema>
> * * @param schemaURL
> * @return
> * @throws Exception
> schemaURL) throws Exception{
> Set @ url "+schemaURL);
> if (file.isFile())
> schemaURL =
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> schema using ResourceSet' message = " + e.getMessage() + "
> xsdSchemaResource);
> directives.
> xsdSchema.getContents().iterator(); contents.hasNext(); )
> { XSDSchemaDirective
> xsdSchemaDirective = (XSDSchemaDirective)xsdSchemaContent;
> namespace --> "+xsdSchemaImport.getNamespace());
> location --> "+xsdSchemaImport.getSchemaLocation());
> } else {
> IMPORT: namespace --> "+xsdSchemaImport.getNamespace());
> IMPORT: location --> "+xsdSchemaImport.getSchemaLocation());
> ") did not contain any schemas!");
> return null;
> in the main schema like here:
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> loaded schema
> or without
> light and a strict version. The light version which refers imported
> elements in the main schema is correctly resolved, in the strict,
> where the imported elements are referred from other included xsd files
> and not in the main one, the import resolution does not succeed.
> perform a recursive import resolution ove all the resources in the
> resourceSet ?
> or
> case like our:
> the imported resources correctly inherit the absolute path from the
> main resource.
> Running xsdMainExample load and validate on it gives the same
> Unresolved import problems.
> thanks in advance
> Tommaso
Re: import resolution and namespaces [message #72477 is a reply to message #72456] |
Wed, 20 June 2007 17:27 |
it works,
imports are now correctly resolved. However we are still experiencing some
odd behaviour which I presume is due to the policy described in the
documentation
"An unresolved instance is synthesized to hold the namespace and name if
an existing instance cannot be found"
Our aim is to extract ElementDeclaration and TypeDefinition from the main
schema to build related automata.
For example here we look for the definition of element "p" defined in
h.xsd of complex type "inlinefac" defined in globali.xsd
Running the same code of my previous post with the addition of your code
1) for nirstrict.xsd [main schema file]
file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/XSD _Test_5/nirstrict.xsd
Resolved schema ./globali.xsd in
ELEMENT from xsdResource.getSchema().getElementDeclarations();
org.eclipse.xsd.impl.XSDElementDeclarationImpl@53fb57 (element:
[xsd:element: null]) (name: p, targetNamespace:
http://www.w3.org/HTML/1998/html4) (value: null, constraint: <unset>,
form: qualified, lexicalValue: null) (nillable: <unset>,
disallowedSubstitutions: [], substitutionGroupExclusions: [], abstract:
<unset>, lexicalFinal: [], block: [])
Type
org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@19a32e0 (element: null)
(name: inlinefac, targetNamespace: http://www.normeinrete.it/nir/2.2/)
(variety: atomic, final: null, lexicalFinal: null, validFacets: null)
TYPE from xsdResource.getSchema().getTypeDefinitions();
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@1428ea (element:
[xsd:complexType: null]) (name: inlinefac, targetNamespace:
http://www.normeinrete.it/nir/2.2/) (derivationMethod: extension, final:
[], abstract: <unset>, contentTypeCategory: mixed,
prohibitedSubstitutions: [], lexicalFinal: null, block: null, mixed: true)
i.e. the element p is of simpleType inlinefac while inlinefac is
actually a complexType
2) for h.xsd [imported schema file]
Resolved schema ./nirstrict.xsd in
file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/XSD _Test_5/h.xsd
IMPORT: namespace --> http://www.normeinrete.it/nir/2.2/
IMPORT: location --> ./nirstrict.xsd
Type
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@19a32e0 (element:
i.e. correct result p is of complexType inlinefac which is actually a
complexType
I assume that for some reason in the 1st case the forced
resolveTypeDefinition() gets the empty default value which does not
correspond to the correct one.
How can we get the correct existing instance of the ComplexType starting
from the main schema ?
Do we have to specify localName different from the empty string in
, or call other methods like
resolveAttributeDeclaration()
resolveAttributeGroupDefinition() and so on ?
These are the xsd example
nirstrict.xsd
<xsd:schema
<xsd:include schemaLocation="./globali.xsd"/>
</xsd:schema>
_______________
h.xsd
_______________
<xsd:element name="p" type="inlinefac" />
</xsd:schema>
_______________
globali.xsd
_______________
<xsd:schema
<xsd:attributeGroup name="link">
<xsd:attribute ref="xlink:type" />
<xsd:attribute ref="xlink:href" />
</xsd:attributeGroup>
<xsd:attributeGroup name="nome">
<xsd:attribute name="nome" type="NIRnome" use="required"/>
<xsd:attributeGroup name="nomefac">
<xsd:attribute name="nome" type="NIRnome"/>
<xsd:attributeGroup name="tempi">
<xsd:attribute name="iniziovigore" type="uri"/>
<xsd:attribute name="finevigore" type="uri"/>
<xsd:attribute name="inizioefficacia" type="uri"/>
<xsd:attribute name="fineefficacia" type="uri"/>
<xsd:attributeGroup name="vigenza">
<xsd:attributeGroup ref="tempi"/>
<xsd:attribute name="rel" type="uri"/>
<xsd:attribute name="status" type="status"/>
<xsd:attributeGroup name="implicita">
<xsd:attribute name="implicita" type="sino" default="no" />
<xsd:attributeGroup name="css">
<xsd:attribute ref="h:style" />
<xsd:attribute ref="h:class" />
<xsd:attribute ref="h:title" />
<xsd:attributeGroup name="idreq">
<xsd:attribute name="id" type="id" use="required"/>
<xsd:attributeGroup name="idfac">
<xsd:attribute name="id" type="id"/>
<xsd:attributeGroup name="idnorma">
<xsd:attribute name="id" type="anytoken"/>
<xsd:attributeGroup name="globalireq">
<xsd:attributeGroup ref="css"/>
<xsd:attributeGroup ref="idreq"/>
<xsd:attributeGroup ref="vigenza"/>
<xsd:attributeGroup name="globalifac">
<xsd:attributeGroup ref="idfac"/>
<xsd:attributeGroup name="globalinorma">
<xsd:attributeGroup ref="idnorma"/>
<xsd:attributeGroup name="data">
<xsd:attribute name="norm" type="NIRdate" use="required"/>
<xsd:attributeGroup name="dove">
<xsd:attribute name="codice" type="NIRdove" use="required"/>
<xsd:attributeGroup name="codice">
<xsd:attribute name="codice" type="NIRcodice" use="required"/>
<xsd:attributeGroup name="val">
<xsd:attribute name="valore" type="anystring" use="required"/>
<xsd:annotation>
<xsd:documentation>
Entita': content model comuni ai vari tipi di elementi
</xsd:documentation>
</xsd:annotation>
<xsd:group name="liste">
<xsd:choice>
<xsd:element ref="h:ul"/>
<xsd:element ref="h:ol"/>
<xsd:element ref="h:dl"/>
</xsd:choice>
</xsd:group>
<xsd:group name="genvuoti">
<xsd:choice>
<xsd:element ref="vuoto"/>
<xsd:element ref="ndr"/>
</xsd:choice>
</xsd:group>
<xsd:group name="geninline">
<xsd:sequence>
<xsd:element ref="inlinea"/>
</xsd:sequence>
</xsd:group>
<xsd:group name="genblocchi">
<xsd:sequence>
<xsd:element ref="blocco"/>
</xsd:sequence>
</xsd:group>
<xsd:group name="genstruct">
<xsd:choice>
<xsd:element ref="contenitore"/>
<xsd:element ref="gerarchia"/>
<xsd:element ref="articolato"/>
</xsd:choice>
</xsd:group>
<xsd:group name="txtvuoti">
<xsd:choice>
<xsd:element ref="h:br"/>
<xsd:element ref="h:hr"/>
</xsd:choice>
</xsd:group>
<xsd:group name="txtinline">
<xsd:choice>
<xsd:element ref="h:span"/>
<xsd:element ref="h:i"/>
<xsd:element ref="h:u"/>
<xsd:element ref="h:b"/>
<xsd:element ref="h:sup"/>
<xsd:element ref="h:sub"/>
<xsd:element ref="h:a"/>
</xsd:choice>
</xsd:group>
<xsd:group name="txtblocchi">
<xsd:choice>
<xsd:element ref="h:form"/>
<xsd:element ref="h:object"/>
<xsd:group ref="liste" />
</xsd:choice>
</xsd:group>
<xsd:group name="nrminline">
<xsd:choice>
<xsd:element ref="rif"/>
<xsd:element ref="irif"/>
<xsd:element ref="mrif"/>
<xsd:element ref="mod"/>
<xsd:element ref="def"/>
<xsd:element ref="atto"/>
<xsd:element ref="soggetto"/>
<xsd:element ref="luogo"/>
<xsd:element ref="ente"/>
<xsd:element ref="data"/>
<xsd:element ref="importo"/>
</xsd:choice>
</xsd:group>
<xsd:group name="nrmstruct">
<xsd:choice>
<xsd:element ref="intestazione"/>
<xsd:element ref="formulainiziale"/>
<xsd:element ref="preambolo"/>
<xsd:element ref="formulafinale"/>
<xsd:element ref="conclusione"/>
<xsd:element ref="annessi"/>
</xsd:choice>
</xsd:group>
<xsd:group name="allvuoti">
<xsd:choice>
<xsd:group ref="genvuoti" />
<xsd:group ref="txtvuoti" />
</xsd:choice>
</xsd:group>
<xsd:group name="allinline">
<xsd:choice>
<xsd:group ref="geninline" />
<xsd:group ref="txtinline" />
<xsd:group ref="nrminline" />
</xsd:choice>
</xsd:group>
<xsd:group name="allblocchi">
<xsd:choice>
<xsd:group ref="genblocchi" />
<xsd:group ref="txtblocchi" />
</xsd:choice>
</xsd:group>
<xsd:group name="allstruct">
<xsd:choice>
<xsd:group ref="genstruct" />
<xsd:group ref="nrmstruct" />
</xsd:choice>
</xsd:group>
<xsd:group name="elinline">
<xsd:choice>
<xsd:group ref="allinline" />
<xsd:group ref="allvuoti" />
</xsd:choice>
</xsd:group>
<xsd:group name="strutture">
<xsd:sequence>
<xsd:group ref="allstruct" minOccurs="1" maxOccurs="unbounded" />
</xsd:sequence>
</xsd:group>
<xsd:complexType name="inline" mixed="true">
<xsd:choice minOccurs="0" maxOccurs="unbounded" >
<xsd:group ref="elinline" />
</xsd:choice>
</xsd:complexType>
<xsd:complexType name="blocchi" >
<xsd:sequence minOccurs="1" maxOccurs="unbounded" >
<xsd:group ref="allblocchi" />
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="ParaLevel" mixed="true">
</xsd:choice>
<xsd:attributeGroup ref="globalifac"/>
</xsd:complexType>
<xsd:complexType name="ParaLevelReq" mixed="true">
</xsd:choice>
<xsd:attributeGroup ref="globalireq"/>
</xsd:complexType>
<xsd:complexType name="valore" >
<xsd:attributeGroup ref="val"/>
</xsd:complexType>
<xsd:complexType name="empty" >
</xsd:complexType>
<xsd:complexType name="emptyfac" >
</xsd:complexType>
<xsd:complexType name="emptyreq" >
</xsd:complexType>
<xsd:complexType name="inlinefac" mixed="true">
<xsd:complexContent>
<xsd:extension base="inline">
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:complexType name="inlinereq" mixed="true">
</xsd:extension>
</xsd:complexType>
<xsd:complexType name="blocchireq" >
<xsd:extension base="blocchi">
</xsd:extension>
</xsd:complexType>
<xsd:complexType name="blocchifac" >
</xsd:extension>
</xsd:complexType>
</xsd:schema>
Re: import resolution and namespaces [message #72505 is a reply to message #72477] |
Wed, 20 June 2007 21:38 |
--------------000502040701020001030200
Tommaso,
What URI are you using to load the document? The reference resolves
fine for me when I load it in the editor like this:
Tommaso wrote:
> it works,
> some odd behaviour which I presume is due to the policy described in
> the documentation
> if an existing instance cannot be found"
> main schema to build related automata.
> abstract: <unset>, lexicalFinal: [], block: [])
> Type
> null) (name: inlinefac, targetNamespace:
> http://www.normeinrete.it/nir/2.2/) (variety: atomic, final: null,
> final: [], abstract: <unset>, contentTypeCategory: mixed,
> true)
> Type
> true)
> true)
> a complexType
> starting from the main schema ?
> nirstrict.xsd
> </xsd:schema>
> _______________
> h.xsd
> _______________
> </xsd:schema>
> _______________
> globali.xsd
> _______________
> <xsd:annotation>
> <xsd:documentation>
> </xsd:annotation>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> </xsd:choice>
> </xsd:complexType>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:choice>
> </xsd:complexType>
> </xsd:choice>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
Content-Type: multipart/related;
boundary="------------060208010200000509080808"
--------------060208010200000509080808
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Tommaso,<br>
<br>
Re: import resolution and namespaces [message #72521 is a reply to message #72505] |
Wed, 20 June 2007 22:11 |
Yes, the editor loads and resolves correctly the schema. But we are using
the org.eclipse.xsd library (version 2.2.3 to keep compatibility with java
1.4) as standalone in order to create and query the automata of schema
elements for validation. The code with which we load the xsd is the
following:
where schemaUrl is the location of the main schema nirstrict.xsd or,
alternatively, of the imported schema h.xsd in case 1 and 2 of previous
post
* @return
* @throws Exception
throws Exception{
System.out.println("--> Loading Schema Using Resource Set @ url "+schemaURL);
// absolute Path of schemaURL
if (file.isFile())
schemaURL =
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "http://www.w3.org/HTML/1998/html4/"),URI.createURI("./h.xsd"));//,URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/h.xsd "));//,URI.createURI("./h.xsd"));
//resourceSet.getURIConverter().getURIMap().put(URI.createUR I( "./dsp.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/dsp.xsd "));//,URI.createURI("./dsp.xsd"));
Boolean.TRUE);
try
xsdSchemaResource =
catch(Exception e)
xsdSchemaResource);
contents.hasNext(); ){
XSDSchemaContent xsdSchemaContent = (XSDSchemaContent)contents.next();
if (xsdSchemaContent instanceof XSDImport)
XSDImport xsdImport = (XSDImport)xsdSchemaContent;
xsdImport.resolveModelGroupDefinition(xsdImport.getNamespace (), "");
xsdImport.resolveElementDeclaration(xsdImport.getNamespace() , "");
xsdImport.resolveComplexTypeDefinition(xsdImport.getNamespac e(), "");
if (xsdSchemaContent instanceof XSDSchemaDirective){
else{
List allElements = xsdResource.getSchema().getElementDeclarations();
System.err.println("----------------------> elements found");
for(Iterator ite = allElements.iterator(); ite.hasNext();){
Object ob = ite.next();
System.err.println(ob.toString());
System.err.println(" Type
"+((XSDElementDeclaration)ob).getType().toString());
List allTypes = xsdResource.getSchema().getTypeDefinitions();
System.err.println("----------------------> types found");
for(Iterator ite = allTypes.iterator(); ite.hasNext();){
System.err.println(ite.next().toString());
return null;
Re: import resolution and namespaces [message #72539 is a reply to message #72521] |
Wed, 20 June 2007 22:17 |
Tommaso,
There should be no need for URI mappings to make this work (assuming
files are really in the correct relative locations, i.e, all in the same
folder). What's the actual value of schemaURL at the point when you
call getResource?
> using the org.eclipse.xsd library (version 2.2.3 to keep compatibility
> with java 1.4) as standalone in order to create and query the automata
> of schema elements for validation. The code with which we load the xsd
> is the following:
> previous post
> * @return
> * @throws Exception
> url "+schemaURL);
> if (file.isFile())
> schemaURL =
> ResourceSet resourceSet = new ResourceSetImpl(); //
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> xsdSchemaResource); }
> directives.
> xsdSchema.getContents().iterator(); contents.hasNext(); ){
> else{
> List allElements =
> List allTypes =
> return null;
Re: import resolution and namespaces [message #72557 is a reply to message #72539] |
Wed, 20 June 2007 22:38 |
Yes, adding or commenting the URI mapping does not have any effect as the
files are all in the same folder.
The value of the schemaURL when calling getResource is correctly set as
the absolute path of the xsd
The output follows; the problem here is that the element "p" of type
"inlinefac" turns out to be an XSDSympleType, while, listing
getTypeDefinitions(), "inlinefac" is actually a ComplexType.
The assignment of "p" as a SimpleType occurs when enforcing the import
resolution in
going inside this method with debugger shows that
XSDSchemaImpl.resolveTypeDefinition()
gives a null result and enforces
createUnresolvedTypeDefinition(namespace, localName);
which probably assumes an empty simpleType "inlinefac" with only name and
namespace set while the actual "inlinefac" type is complex.
How do I manage to associate "p" with its actual complexType ?
OUTPUT:
URIMAP: [http://www.w3.org/HTML/1998/html4/->./h.xsd]
org.eclipse.xsd.impl.XSDElementDeclarationImpl@113a53d (element:
[xsd:element: null]) (name: Legge, targetNamespace:
http://www.normeinrete.it/nir/2.2/) (value: null, constraint: <unset>,
Type
org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@c5495e (element:
[xs:simpleType: null]) (name: string, targetNamespace:
http://www.w3.org/2001/XMLSchema) (variety: atomic, final: [],
lexicalFinal: null, validFacets: [length, minLength, maxLength, pattern,
enumeration, whiteSpace])
Type
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@297ffb (element:
[xsd:complexType: null]) (name: blocchi, targetNamespace:
http://www.normeinrete.it/nir/2.2/) (derivationMethod: <unset>, final: [],
abstract: <unset>, contentTypeCategory: elementOnly,
<unset>)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@914f6a (element:
[xsd:complexType: null]) (name: blocchifac, targetNamespace:
[], abstract: <unset>, contentTypeCategory: elementOnly,
<unset>)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@1f4cbee (element:
[xsd:complexType: null]) (name: blocchireq, targetNamespace:
<unset>)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@787d6a (element:
[xsd:complexType: null]) (name: empty, targetNamespace:
abstract: <unset>, contentTypeCategory: empty, prohibitedSubstitutions:
[], lexicalFinal: null, block: null, mixed: <unset>)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@71dc3d (element:
[xsd:complexType: null]) (name: emptyfac, targetNamespace:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@1326484 (element:
[xsd:complexType: null]) (name: emptyreq, targetNamespace:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@16546ef (element:
[xsd:complexType: null]) (name: inline, targetNamespace:
abstract: <unset>, contentTypeCategory: mixed, prohibitedSubstitutions:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@18a49e0 (element:
[xsd:complexType: null]) (name: inlinereq, targetNamespace:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@1f82982 (element:
[xsd:complexType: null]) (name: ParaLevel, targetNamespace:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@16d2633 (element:
[xsd:complexType: null]) (name: ParaLevelReq, targetNamespace:
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@e70e30 (element:
[xsd:complexType: null]) (name: valore, targetNamespace:
loaded schema
TARGET NAMESPACE: http://www.normeinrete.it/nir/2.2/
********** AUTOMA simple DI Legge ************
Component: - [0, -1]
State: 0 *
********** AUTOMA simple DI h:p ************
State: 0 *
Creating Rules DONE
Re: import resolution and namespaces [message #72577 is a reply to message #72557] |
Thu, 21 June 2007 02:38 |
--------------020207070201070405030301
Tomamaso,
I think you are running into the problem fixed by 106098
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=106098> so it would be
good to try the latest 2.2.4 maintenance build.
> the files are all in the same folder.
> as the absolute path of the xsd
> resolution in
> and namespace set while the actual "inlinefac" type is complex.
> OUTPUT:
> Type
> pattern, enumeration, whiteSpace])
> Type
> <unset>)
> final: [], abstract: <unset>, contentTypeCategory: elementOnly,
> <unset>)
> <unset>)
> [], abstract: <unset>, contentTypeCategory: empty,
> <unset>)
> <unset>)
> <unset>)
> true)
> true)
> true)
> true)
> true)
> <unset>)
> loaded schema
> State: 0 *
> State: 0 *
> Creating Rules DONE
<html>
<head>
</head>
Tomamaso,<br>
<br>
I think you are running into the problem fixed by <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=106098">106098</a>
so it would be good to try the latest 2.2.4 maintenance build.<br>
<br>
<br>
tommaso wrote:
<blockquote
cite="mid:ae393ae25ff823af08524d193649f3bf$1@www.eclipse.org"
type="cite">Yes, adding or commenting the URI mapping does not have
any effect as the files are all in the same folder.
<br>
<br>
Re: import resolution and namespaces [message #72595 is a reply to message #72577] |
Thu, 21 June 2007 02:39 |
--------------080007070100000700030604
Tommaso,
Sorry for misspelling your name. It's late...
Ed Merks wrote:
> Tomamaso,
>> import resolution in
>> OUTPUT:
>> <unset>, form: qualified, lexicalValue: null) (nillable: <unset>,
>> Type
>> Type
>> <unset>)
>> <unset>)
>> <unset>)
>> final: [], abstract: <unset>, contentTypeCategory: empty,
>> <unset>)
>> <unset>)
>> <unset>)
>> true)
>> true)
>> true)
>> true)
>> true)
>> <unset>)
>> loaded schema
>> State: 0 *
>> State: 0 *
>> Creating Rules DONE
<html>
<head>
</head>
Tommaso,<br>
<br>
Re: import resolution and namespaces [message #602397 is a reply to message #72435] |
Ed Merks Messages: 33140 Registered: July 2009 |
Tommaso,
Tommaso wrote:
> hi,
> with.
> nirstrict.xsd:
> <xsd:choice>
> </xsd:choice>
> </xsd:group>-->
> </xsd:schema>
> h.xsd :
> </xsd:schema>
> * @return
> * @throws Exception
> if (file.isFile())
> schemaURL =
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> xsdSchemaResource);
> directives.
> } else {
> return null;
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> loaded schema
> or without
> resourceSet ?
> or
> case like our:
> main resource.
> thanks in advance
> Tommaso
Ed Merks
Re: import resolution and namespaces [message #602403 is a reply to message #72456] |
Tommaso Messages: 6 Registered: July 2009 |
it works,
documentation
Type
Type
complexType
nirstrict.xsd
<xsd:schema
</xsd:schema>
_______________
h.xsd
_______________
</xsd:schema>
_______________
globali.xsd
_______________
<xsd:schema
<xsd:annotation>
<xsd:documentation>
</xsd:annotation>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:sequence>
</xsd:sequence>
</xsd:group>
<xsd:sequence>
</xsd:sequence>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:choice>
</xsd:choice>
</xsd:group>
<xsd:sequence>
</xsd:sequence>
</xsd:group>
</xsd:choice>
</xsd:complexType>
</xsd:sequence>
</xsd:complexType>
</xsd:choice>
</xsd:complexType>
</xsd:choice>
</xsd:complexType>
</xsd:complexType>
</xsd:complexType>
</xsd:complexType>
</xsd:complexType>
</xsd:extension>
</xsd:complexType>
</xsd:extension>
</xsd:complexType>
</xsd:extension>
</xsd:complexType>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
Re: import resolution and namespaces [message #602411 is a reply to message #72477] |
Tommaso,
Tommaso wrote:
> it works,
> the documentation
> Type
> true)
> Type
> true)
> true)
> a complexType
> nirstrict.xsd
> </xsd:schema>
> _______________
> h.xsd
> _______________
> </xsd:schema>
> _______________
> globali.xsd
> _______________
> <xsd:annotation>
> <xsd:documentation>
> </xsd:annotation>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:choice>
> </xsd:choice>
> </xsd:group>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:group>
> </xsd:choice>
> </xsd:complexType>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:choice>
> </xsd:complexType>
> </xsd:choice>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
<html>
<head>
<title></title>
</head>
Tommaso,<br>
<br>
Ed Merks
Re: import resolution and namespaces [message #602417 is a reply to message #72505] |
following:
post
* @return
* @throws Exception
throws Exception{
if (file.isFile())
schemaURL =
Boolean.TRUE);
try
xsdSchemaResource =
catch(Exception e)
xsdSchemaResource);
else{
return null;
Re: import resolution and namespaces [message #602424 is a reply to message #72521] |
Tommaso,
call getResource?
> is the following:
> previous post
> * @return
> * @throws Exception
> url "+schemaURL);
> if (file.isFile())
> schemaURL =
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> directives.
> else{
> List allElements =
> List allTypes =
> return null;
Ed Merks
Re: import resolution and namespaces [message #602432 is a reply to message #72539] |
resolution in
OUTPUT:
Type
Type
<unset>)
<unset>)
<unset>)
loaded schema
State: 0 *
State: 0 *
Creating Rules DONE
Re: import resolution and namespaces [message #602438 is a reply to message #72557] |
Tomamaso,
> resolution in
> OUTPUT:
> Type
> Type
> <unset>)
> <unset>)
> <unset>)
> <unset>)
> <unset>)
> <unset>)
> true)
> true)
> true)
> true)
> true)
> <unset>)
> loaded schema
> State: 0 *
> State: 0 *
> Creating Rules DONE
<html>
<head>
</head>
Tomamaso,<br>
<br>
<br>
<br>
tommaso wrote:
<blockquote
<br>
<br>
Ed Merks
Re: import resolution and namespaces [message #602443 is a reply to message #72577] |
Tommaso,
Ed Merks wrote:
> Tomamaso,
>> OUTPUT:
>> Type
>> Type
>> <unset>)
>> <unset>)
>> <unset>)
>> <unset>)
>> <unset>)
>> <unset>)
>> true)
>> true)
>> true)
>> true)
>> true)
>> <unset>)
>> loaded schema
>> State: 0 *
>> State: 0 *
>> Creating Rules DONE
<html>
<head>
</head>
Tommaso,<br>
<br>
Ed Merks
Current Time: Thu Apr 25 14:42:38 GMT 2024
Powered by FUDForum. Page generated in 0.05080 seconds
