Problem with for [message #72089] |
Wed, 16 January 2008 13:28 |
Originally posted by: luciananegri81.yahoo.it
Hi all,
I've following problem: when I run atl file
the FOR instruction is not performed.
Have anyone an idea for this problem?
Luciana
[ATL]Re: Problem with for [message #72148 is a reply to message #72089] |
Wed, 16 January 2008 15:55 |
Originally posted by: quentin.glineur.obeo.fr
--------------080306010106080705020809
First, please prefix the subject of you ATL related post with [ATL] as I
did for the answer. Thanks.
Can you give an excerpt of the transformation you are trying to launch
please ?
Quentin
Luciana a
Re: [ATL]Re: Problem with for [message #72897 is a reply to message #72148] |
Mon, 21 January 2008 08:25 |
Hi Quentin,
excuse me for the prefix ATL, I have forgotten him.
Here an excerpt of transformation:
helper def : allClassesUC : Set (UML!PAstep) = UML!PAstep.allInstances()
->select(e | e.subject.size() <> 0);
lazy rule actor2root {
from
a : UML!Actor(
(a.oclIsTypeOf(UML!Actor) and not a.useCase.isEmpty())
to
r : FT!Root (
name <- a.name,
description <- 'Reliability del sistema',
SystemReliability <- ' ',
port <- createPort
createPort : FT!Port (
name <- 'Port of ' + a.name,
type <- #OR,
outdegree <- 1
do {
for (e in thisModule.allClassesUC) {
createPort.event <-thisModule.uc2intermediate;
lazy rule uc2intermediate {
from
uc : UML!PAstep
(not uc.subject.isEmpty)
to
intermediate : FT!Intermediate (
name <- 'Reliability '+ uc.name,
composedProbability <- ' '
Thank you very much.
Luciana
Re: [ATL]Re: Problem with for [message #72932 is a reply to message #72897] |
Mon, 21 January 2008 09:16 |
--------------050207030903010206020206
Hi Luciana,
I am not sure but I can see you call a lazy rule without giving its
paramameter in the for statement. Therefore it could be why, having no
input, it cannot perform the item creation. Then it appears as if the
"for" loop does not do anything.
Please try the following:
createPort.event <-thisModule.uc2intermediate(e);
Quentin
Luciana a
Re: [ATL]Re: Problem with for [message #72982 is a reply to message #72932] |
Mon, 21 January 2008 09:55 |
Hi Quentin,
I've tried with your solution, but the output file is the same.
I think (but I not sure) that the part 'from' of the rule uc2intermediate
is not read. It is possible?
It this happens, what I can do?
Luciana
Re: [ATL]Re: Problem with for [message #72994 is a reply to message #72982] |
Mon, 21 January 2008 10:16 |
--------------050801050104050905010208
Hi again,
Luciana a
FUDForum. Page generated in 0.03113 seconds
