Re: Survey: Do you use the built-in html-css tools? [message #71809 is a reply to message #71490] |
Fri, 23 May 2008 17:56 |
Originally posted by: dcarver.starstandard.org
Richard Geddes wrote:
> I'm new to eclipse webtools. I've been using bluefish for html and
> cssed for css. Before I invest time learning the ins & outs of the
> eclipse tools for html/css would you please give me some advice on using
> the eclipse tools for html/css vs other tools.
> Thanks
> R
It's hard to give you an exact answer with out knowing what you are
looking for. In regards to the editors, they provide all the standard
features including content assistance, syntax coloring, etc that you
would expect. You need to install the full WTP suite to get the Visual
Web Page Designer which gives you WYSIWYMG editing. They also provide
validation of all the content against the HTML 4.0 spec and dtd as well.
But again, it's hard to get specific without more detail.
Dave
Re: Survey: Do you use the built-in html-css tools? [message #71846 is a reply to message #71809] |
Fri, 23 May 2008 20:21 |
No real name Messages: 53 Registered: July 2009 |
Member |
Sorry, I was a little confused.. I thought that WST in the standard J2EE
install supplied the HTML/CSS/JS tools. Since I'm new to eclipse,
what's the easiest way to get the full WTP suite?
Anyway, because programming web apps usually involves a variety of tools
(and now a-days HTML/CSS/JS seems to be the min requirement), it looks
like eclipse can house a majority of them under one roof... that's
attractive to me. You don't have to relearn the different ways
development tools behave. The catch is... if the overhead (not code,
but people issues... learning, administration, etc.) for using eclipse
becomes the focus, I loose sight of what I originally wanted to complete.
R
>> using the eclipse tools for html/css vs other tools.
>> Thanks
>> R
> Dave
Re: Survey: Do you use the built-in html-css tools? [message #71903 is a reply to message #71846] |
Sat, 24 May 2008 00:46 |
Yes, it does supply it. Again, not sure what you are asking in regards
to the HTML/CSS and Javascript editor (btw, there is a much improved
Javascript editor in Web Tools 3.0).
As for your question, yes I use the built in HTML/CSS and XML tools
within eclipse.
Dave
Re: Survey: Do you use the built-in html-css tools? [message #71921 is a reply to message #71903] |
Sat, 24 May 2008 01:33 |
Member |
OK... right again... although I was expecting a perspective to go along
with each corresponding tool... for example the CSS capabilities in
eclipse seem to be syntax highlighting and features that help organize
the code... CSS isn't too complicated as far as code structure... what
is taxing when writing CSS is remembering all the CSS attributes, which
version they belong to, as well as things like the colors (there are
some std color names and when you want to create a custom color, etc)
I was hoping that eclipse would be comparable to cssed
(http://cssed.sourceforge.net/) and bluefish
(http://bluefish.openoffice.nl/index.html)
You mentioned installing the full WTP, but didn't say the easiest way to
install it... does the full WTP come in the J2EE install (ie do I
already have it?)
R
>> J2EE install supplied the HTML/CSS/JS tools. Since I'm new to
>> eclipse, what's the easiest way to get the full WTP suite?
> within eclipse.
> Dave
Re: Survey: Do you use the built-in html-css tools? [message #71978 is a reply to message #71921] |
Sat, 24 May 2008 23:40 |
> already have it?)
Yes, the full WTP is included in the J2EE install.
Dave
FUDForum. Page generated in 0.24413 seconds
