Home » Archived » Buckminster » No component named ... is known to Buckminster
Re: No component named ... is known to Buckminster [message #735001 is a reply to message #734913] |
Mon, 10 October 2011 15:23 |
Hi Jesper,
I have no clue what causes this problem. Is there anything special about the com.iar.ide.common.doc component? What type
of component is it? How is it referenced and from where? If it's a bundle, does the bundle manifest look correct?
- thomas
On 2011-10-10 13:33, Jesper Eskilson wrote:
> I can still reproduce this problem, simply by rebuilding my headless Buckminster against the latest P2 repo. I would be
> very happy if someone could take a look at what might be broken.
> Please let me know if you need anymore info.
> /Jesper
Re: No component named ... is known to Buckminster [message #735277 is a reply to message #735001] |
Tue, 11 October 2011 11:39 |
Jesper Eskilson Messages: 134 Registered: July 2009 |
Thomas Hallgren skrev 2011-10-10 17:23:
Weirdly enough, when I try the same thing now, I also get a bunch of
errors about other plugins as well. These errors I did not get before.
> [echo] Running buckminster script file: scripts/build.bmscript (workspace /home/jesperes/hubble-build-tmp)
> [java] INFO: resolve '-P' 'buckminster.properties' 'hubble.cquery'
> [java] INFO: Resetting target platform Buckminster Default TP
> [java] INFO: Import complete.
> [java] INFO: build
> [java] ERROR: Problems during metadata refresh
> [java] ERROR: E No component named org.eclipse.ui.intro.universal:osgi.bundle is known to Buckminster
> [java] ERROR: E No component named org.eclipse.core.databinding.property:osgi.bundle/[1.2.0,2.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.compare.core:osgi.bundle/[3.5.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.search:osgi.bundle/[3.2.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.cdt.debug.core:osgi.bundle/7.0.0 is known to Buckminster
> [java] ERROR: E No component named org.eclipse.equinox.p2.core:osgi.bundle/[2.0.0,2.1.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.ui.views:osgi.bundle/[3.2.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.core.databinding.observable:osgi.bundle/[1.3.0,2.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.ltk.ui.refactoring:osgi.bundle/[3.5.0,4.0.0) is known to Buckminster
> [java] ERROR: E No component named org.eclipse.cdt.launch:osgi.bundle/6.1.0 is known to Buckminster
> [java] INFO: perform '-P' 'buckminster.properties' 'com.iar.ide.common.doc#generate.knownissues'
> [java] No component named com.iar.ide.common.doc is known to Buckminster
> BUILD FAILED
There is really nothing special about the com.iar.ide.common.doc
component. It is a regular Eclipse plug-in. The "generate.knownissues"
action is a custom action on the com.iar.ide.common.doc component which
simply invokes the "ant" actor on a build.xml file in the component.
See attached file with output from running Buckminster with DEBUG
logging. As far as I can see, the com.iar.ide.common.doc component is
being resolved correctly.
/Jesper
clean-workspace:
[delete] Deleting directory /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[delete] Deleting directory /home/jesperes/hubble-build-tmp/helios/workspace
[unzip] Expanding: /home/jesperes/dev/eclipse/com.iar.ide.buckminster/buckminster-headless.zip into /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[unzip] Expanding: /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-workspace-template.zip into /home/jesperes/hubble-build-tmp/helios/workspace
[echo] org.eclipse.buckminster.cmdline_1.0.350.v20110910-0906.jar
[echo] org.eclipse.buckminster.core_1.3.0.v20110915-1108.jar
[echo] org.eclipse.buckminster.pde_1.3.0.v20110910-0906/pde.jar
setup:
run-buckminster:
[mkdir] Created dir: /home/jesperes/hubble-build-tmp/helios/workspace/junit
[echo] Running buckminster script file: scripts/setup.bmscript (workspace /home/jesperes/hubble-build-tmp)
[java] importtargetdefinition '-A' 'file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/helios/helios.target'
[java] Doing full workspace refresh
[java] Waiting for jobs to end
[java] setpref 'org.eclipse.buckminster.jdt.complianceLevel=1.6'
[java] Preference 'org.eclipse.buckminster.jdt.complianceLevel' set to the value '1.6'
build:
run-buckminster:
[java] resolve '-P' 'buckminster.properties' 'hubble.cquery'
[java] Platform install location: /home/jesperes/dev/eclipse/features/com.iar.hubble.releng/buckminster-headless
[java] Target platform provided by class org.eclipse.buckminster.pde.internal.PDETargetPlatform
[java] com.iar.hubble.product.feature:eclipse.feature: Using resolver rmap
[java] com.iar.hubble.product.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble.product.feature:eclipse.feature
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.hubble.product.feature:eclipse.feature
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.hubble.product.feature): No component match was found
[java] com.iar.hubble.product.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble.product.feature:eclipse.feature: Using search path default
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Found match
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble.product.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.feature])
[java] com.iar.hubble.product.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature]) is producing a better match
[java] com.iar.hubble.product.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.feature])
[java] com.iar.branding:osgi.bundle: Using resolver Local resolver
[java] com.iar.branding:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.branding:osgi.bundle
[java] com.iar.hubble:osgi.bundle: Using resolver Local resolver
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble.product.arm.feature:eclipse.feature
[java] com.iar.hubble:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.hubble:osgi.bundle
[java] com.iar.branding:osgi.bundle: Trying provider local(workspace)
[java] com.iar.hubble:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.branding:osgi.bundle
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.hubble:osgi.bundle
[java] com.iar.branding:osgi.bundle: Trying provider local(target)
[java] No open workspace project found that corresponds to com.iar.hubble.product.arm.feature:eclipse.feature
[java] com.iar.hubble:osgi.bundle: Trying provider local(target)
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.hubble.product.arm.feature): No component match was found
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.branding:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.branding): No component match was found
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using search path default
[java] com.iar.hubble:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.hubble): No component match was found
[java] com.iar.hubble:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble:osgi.bundle: Using search path default
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble.product.arm.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Using search path default
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Found match
[java] com.iar.hubble:osgi.bundle: Found match
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble.product.arm.feature]): Components of type eclipse.feature are not supported
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble]): Components of type osgi.bundle are not supported
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Found match
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble])
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble.product.arm.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature]) is producing a better match
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.branding]): Components of type osgi.bundle are not supported
[java] com.iar.hubble.product.arm.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.hubble.product.arm.feature])
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.hubble]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble]) is producing a better match
[java] com.iar.hubble:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble])
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.branding]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding]) is producing a better match
[java] com.iar.hubble:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.hubble]): Components of type osgi.bundle are not supported
[java] com.iar.branding:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.branding])
[java] com.iar.hubble:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.hubble])
[java] com.iar.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.branding]): Components of type osgi.bundle are not supported
[java] com.iar.branding:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.branding])
[java] org.eclipse.core.runtime:osgi.bundle: Using resolver Local resolver
[java] org.eclipse.ui:osgi.bundle: Using resolver Local resolver
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.runtime:osgi.bundle
[java] org.eclipse.ui:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for org.eclipse.ui:osgi.bundle
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(workspace)
[java] org.eclipse.ui:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.runtime:osgi.bundle
[java] No open workspace project found that corresponds to org.eclipse.ui:osgi.bundle
[java] org.eclipse.core.runtime:osgi.bundle: Trying provider local(target)
[java] org.eclipse.ui:osgi.bundle: Trying provider local(target)
[java] org.eclipse.core.runtime:osgi.bundle: Found match 3.6.0.v20100505
[java] org.eclipse.ui:osgi.bundle: Found match 3.6.2.M20110203-1100
[java] org.eclipse.core.runtime:osgi.bundle: Found match org.eclipse.core.runtime:osgi.bundle$3.6.0.v20100505
[java] org.eclipse.ui:osgi.bundle: Found match org.eclipse.ui:osgi.bundle$3.6.2.M20110203-1100
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.sdk.feature:eclipse.feature
[java] com.iar.cdt.common.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(materialized)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.sdk.feature:eclipse.feature
[java] No materialization found for com.iar.cdt.common.feature:eclipse.feature
[java] com.iar.common.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider local(target)
[java] No open workspace project found that corresponds to com.iar.cdt.common.feature:eclipse.feature
[java] com.iar.common.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.common.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.sdk.feature): No component match was found
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.ide.debugger.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.common.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.common.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.ide.debugger.feature:eclipse.feature
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.common.feature): No component match was found
[java] com.iar.cdt.common.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.common.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.ide.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.ide.debugger.feature): No component match was found
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.common.feature): No component match was found
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Found match
[java] com.iar.ide.debugger.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.ide.debugger.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.common.feature:eclipse.feature: Using search path default
[java] com.iar.ide.debugger.feature:eclipse.feature: Found match
[java] com.iar.cdt.common.feature:eclipse.feature: Found match
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.debugger.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.feature])
[java] com.iar.cdt.arm.sdk.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.debugger.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.debugger.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature])
[java] com.iar.ide.debugger.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.debugger.feature])
[java] com.iar.cdt.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.common.feature])
[java] com.iar.common.feature:eclipse.feature: Found match
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.feature])
[java] com.iar.cdt.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.common.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.common.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.common.feature])
[java] com.iar.common.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.feature])
[java] com.iar.common.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature]) is producing a better match
[java] com.iar.common.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.feature])
[java] com.iar.installer.arm:osgi.bundle: Using resolver Local resolver
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.installer.arm:osgi.bundle
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.installer.arm:osgi.bundle
[java] com.iar.installer.arm:osgi.bundle: Trying provider local(target)
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.installer.arm): No component match was found
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.ide.common.doc.feature:eclipse.feature
[java] com.iar.installer.arm:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(workspace)
[java] com.iar.installer.arm:osgi.bundle: Using search path default
[java] No open workspace project found that corresponds to com.iar.ide.common.doc.feature:eclipse.feature
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.installer.arm:osgi.bundle: Found match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.ide.common.doc.feature): No component match was found
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using search path default
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.installer.arm]): Components of type osgi.bundle are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.ide.common.doc.feature]): Components of type eclipse.feature are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.installer.arm]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm]) is producing a better match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Found match
[java] com.iar.installer.arm:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.common.doc.feature])
[java] com.iar.installer.arm:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.installer.arm]): Components of type osgi.bundle are not supported
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.ide.common.doc.feature]): Components of type eclipse.feature are not supported
[java] com.iar.installer.arm:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.installer.arm])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.common.doc.feature])
[java] com.iar.ide.common.doc.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.ide.common.doc.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature]) is producing a better match
[java] com.iar.ide.common.doc.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.ide.common.doc.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.common.projectimport.feature:eclipse.feature
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.common.projectimport.feature:eclipse.feature
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.common.projectimport.feature): No component match was found
[java] com.iar.common.projectimport.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.common.projectimport.feature:eclipse.feature: Using search path default
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.common.projectimport.feature]): Components of type eclipse.feature are not supported
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Found match
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.common.projectimport.feature]): Components of type eclipse.feature are not supported
[java] com.iar.common.projectimport.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.projectimport.feature])
[java] com.iar.common.projectimport.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.common.projectimport.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature]) is producing a better match
[java] com.iar.common.projectimport.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.common.projectimport.feature])
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(workspace)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0)
[java] No open workspace project found that corresponds to org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Trying provider local(target)
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Found match 3.5.0.v20100503
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.R36x_v20110210
[java] org.eclipse.equinox.registry:osgi.bundle/[3.4.0,4.0.0): Found match org.eclipse.equinox.registry:osgi.bundle$3.5.0.v20100503
[java] org.eclipse.osgi:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.osgi:osgi.bundle$3.6.2.R36x_v20110210
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Trying provider local(target)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.0.v20100503
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Using resolver Local resolver
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0)
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0)
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Found match 3.4.100.v20100505-1235
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Trying provider local(target)
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Found match 1.3.1.R36x_v20100803
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.equinox.common:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.equinox.common:osgi.bundle$3.6.0.v20100503
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.M20110210-1200
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Found match 3.6.0.v20100505
[java] org.eclipse.core.contenttype:osgi.bundle/[3.3.0,4.0.0): Found match org.eclipse.core.contenttype:osgi.bundle$3.4.100.v20100505-1235
[java] org.eclipse.equinox.app:osgi.bundle/[1.0.0,2.0.0): Found match org.eclipse.equinox.app:osgi.bundle$1.3.1.R36x_v20100803
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.core.runtime:osgi.bundle/[3.2.0,4.0.0): Found match org.eclipse.core.runtime:osgi.bundle$3.6.0.v20100505
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0)
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.M20110210-1200
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Trying provider local(target)
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Found match 3.6.2.v3659c
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Using resolver Local resolver
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(materialized)
[java] No materialization found for org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(workspace)
[java] No open workspace project found that corresponds to org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Trying provider local(target)
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Found match 3.4.200.v20100505
[java] org.eclipse.swt:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.swt:osgi.bundle$3.6.2.v3659c
[java] org.eclipse.core.expressions:osgi.bundle/[3.4.0,4.0.0): Found match org.eclipse.core.expressions:osgi.bundle$3.4.200.v20100505
[java] com.iar.cdt.arm.samples:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.samples:osgi.bundle
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.samples:osgi.bundle
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.toolchain.feature:eclipse.feature
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.toolchain.feature:eclipse.feature
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.arm.samples): No component match was found
[java] com.iar.cdt.arm.samples:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.samples:osgi.bundle: Using search path default
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.toolchain.feature): No component match was found
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.samples:osgi.bundle: Found match
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.samples]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.toolchain.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.samples]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples]) is producing a better match
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.samples:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Found match
[java] com.iar.cdt.arm.samples:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.samples]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.toolchain.feature])
[java] org.eclipse.jface:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.jface:osgi.bundle$3.6.2.M20110210-1200
[java] com.iar.cdt.arm.samples:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.samples])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.toolchain.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.toolchain.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature]) is producing a better match
[java] com.iar.cdt.arm.toolchain.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.toolchain.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using resolver Local resolver
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.debugger.feature:eclipse.feature
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider local(target)
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider eclipse.platform(feature/com.iar.cdt.arm.debugger.feature): No component match was found
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using search path default
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Found match
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.debugger.feature]): Components of type eclipse.feature are not supported
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.debugger.feature]): url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature]) is producing a better match
[java] com.iar.cdt.arm.debugger.feature:eclipse.feature: Using provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.debugger.feature])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.arm.sdk.branding:osgi.bundle
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.arm.sdk.branding:osgi.bundle
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.arm.sdk.branding): No component match was found
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using search path default
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Found match
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.arm.sdk.branding]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.arm.sdk.branding]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding]) is producing a better match
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.arm.sdk.branding]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.arm.sdk.branding:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.arm.sdk.branding])
[java] com.iar.cdt.project.utils:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.project.utils:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.project.utils:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.project.utils): No component match was found
[java] com.iar.cdt.project.utils:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.project.utils:osgi.bundle: Using search path default
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.generic.toolchain:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Found match
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.toolchain:osgi.bundle
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.project.utils]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.toolchain): No component match was found
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using search path default
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.project.utils]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils]) is producing a better match
[java] com.iar.cdt.project.utils:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.project.utils:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.project.utils]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Found match
[java] com.iar.cdt.project.utils:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.project.utils])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/features/{1}[file:/home/jesperes/dev/eclipse//features/com.iar.cdt.generic.toolchain]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/devel-plugins/{1}[file:/home/jesperes/dev/eclipse//devel-plugins/com.iar.cdt.generic.toolchain]): url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain]) is producing a better match
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Trying provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.generic.toolchain])
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Rejecting provider url.catalog({0}/devel-features/{1}[file:/home/jesperes/dev/eclipse//devel-features/com.iar.cdt.generic.toolchain]): Components of type osgi.bundle are not supported
[java] com.iar.cdt.generic.toolchain:osgi.bundle: Using provider url.catalog({0}/plugins/{1}[file:/home/jesperes/dev/eclipse//plugins/com.iar.cdt.generic.toolchain])
[java] org.eclipse.ui.workbench:osgi.bundle/[3.5.0,4.0.0): Found match org.eclipse.ui.workbench:osgi.bundle$3.6.2.M20110210-1200
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(materialized)
[java] No materialization found for com.iar.cdt.generic.wizardPages:osgi.bundle
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Using resolver Local resolver
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(workspace)
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(materialized)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.wizardPages:osgi.bundle
[java] No materialization found for com.iar.cdt.generic.toolchain.ui:osgi.bundle
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(workspace)
[java] No open workspace project found that corresponds to com.iar.cdt.generic.toolchain.ui:osgi.bundle
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.wizardPages): No component match was found
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Trying provider local(target)
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Rejecting provider eclipse.platform(plugin/com.iar.cdt.generic.toolchain.ui): No component match was found
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Using search path default
[java] com.iar.cdt.generic.toolchain.ui:osgi.bundle: Using resource map file:/home/jesperes/dev/eclipse/features/com.iar.hubble.releng/hubble.rmap
[java] com.iar.cdt.generic.wizardPages:osgi.bundle: Trying provider url.catalog({0}/plugins/{1}[file:/h
Re: No component named ... is known to Buckminster [message #735291 is a reply to message #735277] |
Tue, 11 October 2011 12:48 |
Hi Jesper,
Judging from the log it looks like the target platform that you import in the beginning is somehow forgotten when you
run the resolve which is a bit odd.
Another thing that strikes me is that you seem to use the url.catalog extensively. That's not very common. Why is that?
- thomas
> Weirdly enough, when I try the same thing now, I also get a bunch of errors about other plugins as well. These errors I
> did not get before.
>> [java] INFO: build
>> Buckminster
>> Buckminster
>> BUILD FAILED
> There is really nothing special about the com.iar.ide.common.doc component. It is a regular Eclipse plug-in. The
> "generate.knownissues" action is a custom action on the com.iar.ide.common.doc component which simply invokes the "ant"
> See attached file with output from running Buckminster with DEBUG logging. As far as I can see, the
> com.iar.ide.common.doc component is being resolved correctly.
> /Jesper
Current Time: Thu Apr 25 13:41:11 GMT 2024
Powered by FUDForum. Page generated in 0.04858 seconds
