Home » Archived » Memory Analyzer (MAT) » MAT error on AIX 64-bit(Getting invalid magic number libjvm.so on AIX 64bit)
MAT error on AIX 64-bit [message #699053] Wed, 20 July 2011 18:08 Go to next message
Samira  is currently offline Samira Friend
I downloaded the MemoryAnalyzer-1.1.0.20110523-aix.motif.ppc.zip and installed it on AIX 6.1, which is 64-bit, running WAS 6.1.0.35 64-bit as well. We need to parse a 4.5 GB heap dump from 64-bit WAS jvm.
I tried to use MAT with the IBM JDK that came with WAS and I get the below error:
Could not load module /usr/WebSphere64/AppServer/java/jre/bin/j9vm/libjvm.so.
The module has an invalid magic number.
Is the MAT for aix.motif 32-bit only? If not then how do I configure MAT to get past this error?
Samira
Re: MAT error on AIX 64-bit [message #703983 is a reply to message #699053] Thu, 28 July 2011 06:36 Go to previous message
Krum Tsvetkov is currently offline Krum TsvetkovFriend
You can try using the <mat>/ParseHeapDump.sh script to parse the heap dump. Just call it like this:
./ParseHeapDump.sh <heap_dump>
Once it is parsed you should be able to work on it with the memory you can get from a 32bit jdk.
BTW, this forum has been moved about one year ago (as MAT moved to a different parent project at Eclipse). It should be impossible to post here Smile ... but obviously it was...
Please use http://www.eclipse.org/forums/eclipse.memory-analyzer for further questions.
Krum
Previous Topic:MAT on Solaris: SWT not found
Next Topic:Forum Move.
Current Time: Tue Apr 07 17:10:32 GMT 2020
Powered by FUDForum. Page generated in 0.01844 seconds
