Home » Eclipse Projects » EGit / JGit » EGit and no-fast-forward merges
EGit and no-fast-forward merges [message #698574] Tue, 19 July 2011 18:02 Go to next message
Mike Haney is currently offline Mike HaneyFriend
Is there a way in EGit to tell it to always create a commit after a merge instead of doing a fast-forward merge (i.e. the --no-ff flag)? I can't seem to find this option in the dialogs or the preferences. Am I just missing it, or has this feature not been implemented yet?
Re: EGit and no-fast-forward merges [message #698654 is a reply to message #698574] Tue, 19 July 2011 22:02 Go to previous messageGo to next message
R Shapiro is currently offline R ShapiroFriend
You can do this with the config option "merge.ff = false". Set it once and you're done. The "Properties" view in the "Git Repository" perspective provides a simple gui for showing and editing your configuration settings at each level. The only caveat is that you must restart eclipse after editing the configuration for jgit and/or egit to pick up the change. At least that's what I found in my tests.
Using the Git configuration mechanism seems cleaner than adding an option to the egit gui, which has plenty to do already.
Re: EGit and no-fast-forward merges [message #698712 is a reply to message #698654] Wed, 20 July 2011 04:22 Go to previous messageGo to next message
R Shapiro wrote on Tue, 19 July 2011 18:02
Thanks for the tip. I didn't realize there was a git config option for that.
Re: EGit and no-fast-forward merges [message #698789 is a reply to message #698574] Wed, 20 July 2011 08:29 Go to previous messageGo to next message
Christian Halstrick is currently offline Christian HalstrickFriend
did this really work for you? I was about to answer that we don't support that configuration parameter merge.ff yet - then I read the solution here. I checked it and I can't configure EGit to create a commit in fast-forward cases. What versio of EGit are your using
Ciao
Chris
Re: EGit and no-fast-forward merges [message #698825 is a reply to message #698789] Wed, 20 July 2011 10:21 Go to previous messageGo to next message
Hmm. The first few tests failed, then it worked when I restarted Eclipse. It's possible that by that time the branches were in a state that merge didn't use FF for other reasons. I'll run a simpler test again when I get a chance.
Right now I can't get at the machine I was testing on to find the exact egit version. I successfully updated from updates-nightly a couple of hours earlier, so I'm pretty sure it's 1.1.0.20110719xxxx. The jgit version had an earlier day tag, 0714 maybe.
Sorry about the vague reply, I should know more later today.
Re: EGit and no-fast-forward merges [message #698889 is a reply to message #698825] Wed, 20 July 2011 12:33 Go to previous messageGo to next message
I can't replicate the one seemingly successful result I had yesterday; I must have messed up the state of the branches being merged. Too bad, eagerly awaiting jgit/egit support for standard config options like merge.ff.
Not that it matters at this point but I'm running egit 1.1.0.201107190813 and jgit 1.1.0.201107141117.
Re: EGit and no-fast-forward merges [message #699667 is a reply to message #698889] Fri, 22 July 2011 03:45 Go to previous messageGo to next message
Bummer - I got excited when I saw the original reply. Should I enter a bug for this?
Re: EGit and no-fast-forward merges [message #699845 is a reply to message #699667] Fri, 22 July 2011 12:54 Go to previous message
Seems like this counts as a bug, though probably in jgit rather than egit. I assume the egit Merge action just fires off a jgit call to do the actual merging. If jgit is doing the merge, it should be respecting the Git configuration.
In the meantime, maybe an egit enhancement request would also be in order to add a no-ff option to the merge dialog.
Previous Topic:Push to Upstream with confirmation dialog ?
Next Topic:Local Terminal can be helpful for Git projects
Current Time: Tue Mar 02 06:15:37 GMT 2021
Powered by FUDForum. Page generated in 0.01607 seconds
