Home » Archived » M2M (model-to-model transformation) » [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698404 is a reply to message #698018] |
Tue, 19 July 2011 12:32 |
Eszter Hofmann Messages: 16 Registered: July 2011 |
for launching the transformation I am using the main method generated by the New > ATL Plugin Wizard.
In the method loadModels I registered my packages:
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
ResourceSet resourceSet = factory.getResourceSet();
Registry registry = factory.getResourceSet().getPackageRegistry();
Map<String, Object> extMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
extMap.put("ecore", new EcoreResourceFactoryImpl()); //$NON-NLS-1$
extMap.put("cache", new CacheResourceFactoryImpl());
extMap.put("om", new OMResourceFactoryImpl());
CachePackage.eINSTANCE.eClass();
OmPackage.eINSTANCE.eClass();
registry.put(CachePackage.eNS_URI, CachePackage.eINSTANCE);
registry.put(OmPackage.eNS_URI, OmPackage.eINSTANCE);
// the generated code
IInjector injector = new EMFInjector();
IReferenceModel cacheMetamodel = factory.newReferenceModel();
injector.inject(cacheMetamodel, getMetamodelUri("cache"));
IReferenceModel omMetamodel = factory.newReferenceModel();
injector.inject(omMetamodel, getMetamodelUri("om"));
this.inModel = factory.newModel(cacheMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(omMetamodel);
Now loading works fine, but as result I still get DynamicEObjImpl instances.
I also tried to register my packages to the global package registry, but the result didn't change.
What else am I missing?
Eszter
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698537 is a reply to message #698404] |
Tue, 19 July 2011 16:08 |
Ed Merks Messages: 33141 Registered: July 2009 |
What's the nsURI of the model for which you're ending up with dynamic
instances, i.e., what's the value of
eObject.eClass().getEPackage().getNsURI() for the problematic
instance? Is that URI registered?
On 19/07/2011 5:32 AM, Eszter Hofmann wrote:
> instances.
> Eszter
Ed Merks
Current Time: Thu Apr 25 19:21:39 GMT 2024
Powered by FUDForum. Page generated in 0.03511 seconds
