Home » Eclipse Projects » GEF » Initail position of a node & palette changed at runtime
Initail position of a node & palette changed at runtime [message #697011] Fri, 15 July 2011 10:14
Mauro P. is currently offline Mauro P.Friend
Hi all.
I've got 2 problem with my editor.
First i would like to set initial position of a node in the diagram when the diagram is created and when the diagram is refreshed.
User must still be abele to move and resize nodes
I'v tryed diffrent solution like:
h**p://wiki.eclipse.org/Graphical_Modeling_Framework/Tips#Setting_Initial_Position_of_a_Node
and other post on the eclipse forum, but always without achive my goal.
When i try to set the node constraint, i still get the "cannot write in Read Only Transaction" also using editingDomain and command.
I need a hint on how solve this.
My second question ia about plaette. Is possible to change it at runtime? i need to hide/unide tool at runtime.
Tanks in advance.
Mauro P.
Previous Topic:Overriding of dragTracker objecting the selection of the Component
Next Topic:[Zest] anti-aliasing for edges
Current Time: Fri Nov 26 23:27:45 GMT 2021
Powered by FUDForum. Page generated in 0.01934 seconds
