Re: [ATL] run configuration cannot select ATL file [message #70808 is a reply to message #70738] |
Tue, 08 January 2008 09:54 |
Originally posted by: r.c.ladan.tue.nl
Aram Hovsepyan wrote:
> When I'm configuring the Run of a given ATL file, the first time I do it it
> works all fine (see screenshot 1). However the second time I click on run I
> get an error that Path must include project and resource name. If I open
> the run configuration dialog I cannot select the ATL file anymore (see
> screenshot 2).
> Am I doing something wrong or is this a bug?
> Thanks
The screenshots didn't make it, but I had the same problem yesterday evening on my box.
I installed Eclipse 3.3.1 on it (from source), then the precompiled versions of
EMF 2.3.1 and ATL 2.0.0 (and some other stuff) via the update sites. This is on
FreeBSD 7.0-BETA4 and a natively compiled jdk 1.5. Maybe the native jdk1.6 works.
A workaround is to save the configuration to a launch file and edit that file
manually before running it via the right-click menu.
HTH,
Rene
FUDForum. Page generated in 0.02461 seconds
