[solved] popupMenus on IMarker [message #696270] |
Wed, 13 July 2011 15:41 |
Christian Opitz Messages: 11 Registered: July 2009 |
Hi everyone,
I have an issue with a plugin i wrote a while ago (Eclipse 3.2 times I think) which does not work as I would expect anymore. It did in the past with the same code.
I create some IMarkers and would like to have a menu item in the popupMenu.
This is what I use as extension point:
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
id="de.test.consoleparser.objectContribution1"
objectClass="org.eclipse.core.resources.IMarker">
<action
class="de.test.consoleparser.ui.DeleteMarkerDelegate"
id="de.test.consoleparser.ui.DeleteMarker"
label="Delete Marker"
menubarPath="additions">
</action>
</objectContribution>
</extension>
The menu item just doesn't appear. The funny thing is that when changing the object class to use IFile as in the following line, the menu item appears (in the file context menu).
objectClass="org.eclipse.core.resources.IFile"
So I guess generally what I am doing seems to be not completely wrong, but something is not working the way think it is. As mentioned it did work previously.
Any suggestions or hints?
Thanks in advance!
[Updated on: Wed, 20 July 2011 13:06] Report message to a moderator
FUDForum. Page generated in 0.02694 seconds
