Home » Eclipse Projects » Rich Client Platform (RCP) » Conflict in keys shortcuts
Conflict in keys shortcuts [message #696158] Wed, 13 July 2011 11:41 Go to next message
Originally posted by: Martin Jedlicka
I have question on definition key binding. I have an RCP application
and in application two plugins 'poll.lsn.monitorvariable' and
'poll.lsn.recorddata'. I defined keys shortcuts CTRL+G in each plugin
this way:
Plugin 'poll.lsn.monitorvariable:
<command
categoryId="poll.lsn.monitorvariable.commands"
defaultHandler="poll.lsn.monitorvariable.actions.ChartPropertiesHandler"
id="poll.lsn.monitorvariable.command.chartproperties"
name="%poll.lsn.monitorvariable.command.chartproperties">
</command>
<key
commandId="poll.lsn.monitorvariable.command.chartproperties"
contextId="org.eclipse.ui.contexts.window"
schemeId="poll.lsn.scheme"
sequence="M1+G">
</key>
Plugin 'poll.lsn.recorddata':
<command
categoryId="poll.lsn.recorddata.commands"
defaultHandler="poll.lsn.recorddata.actions.ShowChartAndLogAnHandler"
id="poll.lsn.recorddata.command.showchartlogan"
name="%poll.lsn.recorddata.command.showchartlogan">
</command>
<key
commandId="poll.lsn.recorddata.command.showchartlogan"
sequence="M1+G">
</key>
After started my application occurred a conflict for CTRL+G:
!MESSAGE A conflict occurred for CTRL+G:
Binding(CTRL+G,
ParameterizedCommand(Command(poll.lsn.monitorvariable.command.chartproperties,Nastavení
grafu,
Category(poll.lsn.monitorvariable.commands,Sledování
proměnných,MonitorVariable commands,true),
poll.lsn.monitorvariable.actions.ChartPropertiesHandler,
,,true),null),
poll.lsn.scheme,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+G,
ParameterizedCommand(Command(poll.lsn.recorddata.command.showchartlogan,Zobrazení
analogového grafu / logického analyzátoru,
Category(poll.lsn.recorddata.commands,Záznamník
dat,RecordData commands,true),
poll.lsn.recorddata.actions.ShowChartAndLogAnHandler,
,,true),null),
poll.lsn.scheme,
Is it possible somehow to resolve this error or do I have in my
application a unique keys shortcuts (Ctrl+G only once)? I'd rather solve
it somehow, but I do not know how.
Thanks.
Martin
Re: Conflict in keys shortcuts [message #696494 is a reply to message #696158] Thu, 14 July 2011 05:59 Go to previous messageGo to next message
Note:
Plugins 'poll.lsn.monitorvariable' and 'poll.lsn.recorddata' are in
different perspectives.
It is possible to have the same keys shortcuts in a variety of perspectives?
Martin
Dne 13.7.2011 13:41, Martin Jedlicka napsal(a):
> I have question on definition key binding. I have an RCP application and
> this way:
> <command
> </command>
> <key
> sequence="M1+G">
> </key>
> <command
> </command>
> <key
> sequence="M1+G">
> </key>
> Binding(CTRL+G,
> grafu,
> ,,true),null),
> poll.lsn.scheme,
> Binding(CTRL+G,
> Category(poll.lsn.recorddata.commands,Záznamník dat,RecordData
> commands,true),
> ,,true),null),
> poll.lsn.scheme,
> Thanks.
> Martin
Re: Conflict in keys shortcuts [message #698066 is a reply to message #696494] Mon, 18 July 2011 17:53 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Your collision is happening because you've bound the same key to different commands in the window context (and you're in a window).
As an aside: Plugins aren't in any perspective, although they can provide one or more perspectives.
The 2 most common contexts that key shortcuts are defined in are "In Windows" or in a specific part.
You have 3 choices.
1) define the commands and keybindings as if they all exist at the window level. That way there's no conflict.
2) define one command and one keybinding, and different handlers per perspective (or part). That's how a common action like Refresh is defined (one command, one keybinding, multiple handlers).
3) define 2 different contexts, one for each perspective, and activate/deactivate them on perspective change.
PW
Re: Conflict in keys shortcuts [message #698076 is a reply to message #698066] Mon, 18 July 2011 18:11 Go to previous messageGo to next message
Thanks Paul!
I don't understand choice 1. What do you mean? It is possible to give an
example?
M.
Dne 18.7.2011 19:53, Paul Webster napsal(a):
> You have 3 choices.
> PW
Re: Conflict in keys shortcuts [message #698086 is a reply to message #698076] Mon, 18 July 2011 18:29 Go to previous messageGo to next message
For option 1, I mean picking non-conflicting keys for your commands. ex:
CTRL+5 G -> poll.lsn.monitorvariable.command.chartproperties
CTRL+4 G -> poll.lsn.recorddata.command.showchartlogan
Or another approach, why not have the chart properties tied to the already provided org.eclipse.ui.IWorkbenchCommandConstants.FILE_PROPERTIES command? Then you just provide a handler, and ALT+ENTER is the standard shortcut for Properties.
Later,
PW
Re: Conflict in keys shortcuts [message #698146 is a reply to message #698086] Mon, 18 July 2011 21:22 Go to previous messageGo to next message
Option 1: Ok, I see.
Option 2: How do I implement this? It is possible to give an example?
M.
Dne 18.7.2011 20:29, Paul Webster napsal(a):
> already provided
> Properties.
> Later,
> PW
Re: Conflict in keys shortcuts [message #698415 is a reply to message #698146] Tue, 19 July 2011 12:48 Go to previous messageGo to next message
Eclipse User wrote on Mon, 18 July 2011 17:22
That's just standard commands/handlers. See some of the links below:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/workbench.htm
Also check out the command contributions example:
http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/examples/org.eclipse.ui.examples.contributions
PW
Re: Conflict in keys shortcuts [message #698573 is a reply to message #698415] Tue, 19 July 2011 17:36 Go to previous message
Thank you very much Paul!
M.
Dne 19.7.2011 14:48, Paul Webster napsal(a):
> PW
Previous Topic:How to override plugin_customization.ini from a fragment
Next Topic:How to control view location when attaching (un-detached)it?
Current Time: Wed Jan 19 17:47:09 GMT 2022
Powered by FUDForum. Page generated in 0.02624 seconds
