Deploy modified plugin [message #696050] |
Wed, 13 July 2011 07:31  |
MarcoGT  Messages: 77 Registered: May 2011 |
Member |
Hi all,
I did some changes to org.eclipse.wst.xml.ui plug-in (I have downloaded sources from Eclipse CVS repository).
Now I would like to deploy it. I created a JAR file using Export Wizard.
Resulting JAR is: org.eclipse.wst.xml.ui_1.2.000.QUALIFIER.
My plug-in is not loaded, only the default one is loaded.
Probably because is the default one linked to a feature.xml?
Why?
[Updated on: Wed, 13 July 2011 07:57] Report message to a moderator
Re: Deploy modified plugin [message #697101 is a reply to message #696273] |
Fri, 15 July 2011 14:22   |
Larry Isaacs Messages: 1354 Registered: July 2009 |
On 7/13/2011 11:45 AM, MarcoGT wrote:
> Ok, I succeeded modifying a configuration files in configuration folder.
> Marco
For reference, it's typically the plug-in version listed in the
feature.xml of the appropriate feature that identifies the version of
plug-in to run. For org.eclipse.wst.xml.ui, you would find it in the
feature.xml under the
"eclipse\features\org.eclipse.wst.xml_ui.feature_<version>" folder.
When Eclipse "resolves" what plug-ins should run, it writes the results
to the configuration file you likely modified. If a "resolution" is
triggered in the future, possibly by adding or updating some feature,
you might lose your changes. In theory, it is better to update the
feature.xml to specify your version, or save a copy of the original
plug-in and build your plug-in to have the same version as the one it's
replacing.
Larry
FUDForum. Page generated in 0.01953 seconds
