Home » Modeling » Modeling (top-level project) » Visual model of struts-config.xml(where to find)
Visual model of struts-config.xml [message #695822] Tue, 12 July 2011 15:40 Go to next message
Ed Missing name is currently offline Ed Missing nameFriend
I used to use MyEclipse, but due to compatability issues with other developers, have moved on the standard Eclipse web platform. The one thing i really miss that I can't seem to find a replacement for was the struts flow modeller. Is there a plugin available that will create a visual model (diagram) with boxes, lines, arrows and labels from the struts-config.xml file?
Having a visual map to follow makes things so much easier in a large project. Struts 1.1 btw, not struts 2.
Thanks.
And if this isn't the right place for this question will someone please direct me to the proper forum? Thanks again.
Re: Visual model of struts-config.xml [message #695860 is a reply to message #695822] Tue, 12 July 2011 16:37 Go to previous messageGo to next message
No, I don't think there's such a thing hosted at Eclipse.
> Thanks.
Ed Merks
Re: Visual model of struts-config.xml [message #695884 is a reply to message #695860] Tue, 12 July 2011 18:21 Go to previous messageGo to next message
Might there be such a thing on a third party site (stand alone, not bundled as with MyEclipse)?
Re: Visual model of struts-config.xml [message #696018 is a reply to message #695884] Wed, 13 July 2011 05:04 Go to previous messageGo to next message
It's hard to speculate what might all be out there, but I don't know of
one... Google is more likely to turn up an answer than me...
Ed Merks
Re: Visual model of struts-config.xml [message #696224 is a reply to message #696018] Wed, 13 July 2011 14:24 Go to previous message
Ok, thanks. I came here because Google failed to turn up anything useful. Thanks for the input.
Previous Topic:how to use uuid as data type in a classs
Next Topic:How does eclipse resolve model URI's?
Current Time: Sat Aug 13 16:39:45 GMT 2022
Powered by FUDForum. Page generated in 0.02330 seconds
