Home » Archived » M2M (model-to-model transformation) » [ATL] atl launcher via command line
[ATL] atl launcher via command line [message #70562] Sun, 06 January 2008 22:36 Go to next message
Originally posted by: no.spam.stop
I try the atl command line from dennis wagelaar with the example
"families 2 persons" available on the atl website.
here is the command line :
--trans
" file:C:/Users/Nicolas/workspace-europa/WSAtlTransformation/t ransformations/Families2Persons.asm "
--in
IN=" file:C:/Users/Nicolas/workspace-europa/WSAtlTransformation/m odels/sample-Families.ecore "
Families=" file:C:/Users/Nicolas/workspace-europa/WSAtlTransformation/m etamodels/Families.ecore "
EMF --out
OUT=" file:C:/Users/Nicolas/workspace-europa/WSAtlTransformation/m odels/sample-Persons.ecore "
Persons=" file:C:/Users/Nicolas/workspace-europa/WSAtlTransformation/m etamodels/Persons.ecore "
EMF
and here is the output of the command :
--trans
--in
IN=file:C:/Users/Nicolas/workspace-europa/WSAtlTransformatio n/models/sample-Families.ecore
Families=file:C:/Users/Nicolas/workspace-europa/WSAtlTransfo rmation/metamodels/Families.ecore
EMF
Input metamodel Families @
org.atl.eclipse.engine.AtlEMFModelHandler@98ce7e not yet loaded -
loading from
Referenced extents: []
Using input metamodel Families : MOF
Loading input model IN from
Using input model IN : Families
--out
OUT=file:C:/Users/Nicolas/workspace-europa/WSAtlTransformati on/models/sample-Persons.ecore
Persons=file:C:/Users/Nicolas/workspace-europa/WSAtlTransfor mation/metamodels/Persons.ecore
EMF
Loading output metamodel Persons @
org.atl.eclipse.engine.AtlEMFModelHandler@98ce7e from
Using output metamodel Persons : MOF
Creating new model OUT for output
Starting model transformation
Model transformation done
java.net.UnknownServiceException: protocol doesn't support output
at java.net.URLConnection.getOutputStream(URLConnection.java:79 2)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createU RLOutputStream(URIConverterImpl.java:390)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createO utputStream(URIConverterImpl.java:310)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:810)
at
org.atl.eclipse.engine.AtlEMFModelHandler.saveModel(AtlEMFMo delHandler.java:79)
at
org.atl.eclipse.engine.AtlEMFModelHandler.saveModel(AtlEMFMo delHandler.java:43)
at Main.run(Main.java:324)
at Main.main(Main.java:90)
obviously the process stops on this line of the "run" method of "Main.class"
getDefaultHandler((String)handlers.get(mmName)).saveModel(cu rrentOutModel,
(String) paths.get(mName));
Any help would be appreciated
thanks in advance
Nicolas
Re: [ATL] atl launcher via command line [message #70584 is a reply to message #70562] Sun, 06 January 2008 22:44 Go to previous messageGo to next message
Nicolas a écrit :
> --trans
> --in
> EMF --out
> EMF
> --trans
> --in
> EMF
> loading from
> --out
> EMF
> at
> at
> at
> at
> at
> "Main.class"
> thanks in advance
> Nicolas
also I modified the method "loadmodel" of "Main.class" :
changed "URI absURI = URI.createURI(uri).resolve(cwd);"
in "URI absURI = URI.createURI(uri);"
because the command line :
--trans "transformations/Families2Persons.asm" --in
IN="models/sample-Families.ecore" Families="metamodels/Families.ecore"
EMF --out OUT="models/sample-Persons.ecore"
Persons="metamodels/Persons.ecore" EMF
caused the output :
--trans transformations/Families2Persons.asm
Usage: <this program> --trans <transformation url> [--in <id>=<model>
<id>=<metamodel> <MDR|EMF>] [--out <id>=<model> <id>=<metamodel>
<MDR|EMF>] [--lib <id>=<library url>] [--superimpose <transformation
url>] --next --trans ...java.net.MalformedURLException: no protocol:
transformations/Families2Persons.asmjava.net.MalformedURLExc eption: no
protocol: transformations/Families2Persons.asm
at java.net.URL.<init>(URL.java:567)
at java.net.URL.<init>(URL.java:464)
at java.net.URL.<init>(URL.java:413)
at Main.parseArgs(Main.java:156)
at Main.main(Main.java:88)
Re: [ATL] atl launcher via command line [message #71109 is a reply to message #70584] Wed, 09 January 2008 14:01 Go to previous message
Dennis Wagelaar is currently offline Dennis WagelaarFriend
Nicolas schreef:
> Nicolas a écrit :
>> Hi,
Hi Nicolas,
>> --trans
>> --in
>> EMF --out
>> EMF
>> --trans
>> --in
>> EMF
>> loading from
>> --out
>> EMF
>> at
>> at
>> at
>> at
>> at
>> "Main.class"
>> thanks in advance
>> Nicolas
> caused the output :
I used relative paths/URIs, so something like this:
--trans
" file:../../WSAtlTransformation/transformations/Families2Pers ons.asm "
--in IN="../../WSAtlTransformation/models/sample-Families.ecore"
Families="../../WSAtlTransformation/metamodels/Families.ecore " EMF --out
OUT="../../WSAtlTransformation/models/sample-Persons.ecore"
Persons="../../WSAtlTransformation/metamodels/Persons.ecore " EMF
Also note that I only used "file:" in the --trans argument. See also:
http://ssel.vub.ac.be/viewvc/UML1CaseStudies/uml1cs-instantm essenger-model/outmodels/test2mm/build.xml?revision=5387& ;view=markup
http://ssel.vub.ac.be/viewvc/UML1CaseStudies/uml1cs-instantm essenger-model/outmodels/common.xml?revision=3716&view=m arkup
Dennis
Previous Topic:[ATL] How to call a called rule.
Next Topic:[ATL] A problem about resolveTemp
Current Time: Tue Apr 16 13:23:53 GMT 2024
Powered by FUDForum. Page generated in 0.29811 seconds
