getting started with SWT Bot [message #695207] |
Mon, 11 July 2011 09:20 |
Originally posted by: robert julian chandradoss
I am pretty new to swt bot and i tried to create my first test
example using the tutorial video
http://download.eclipse.org/technology/swtbot/docs/videos/beginners/SWTBotGettingStartedIn5Minutes/
But, i get error=0 or failure=0. I only get " Runs 0/1 ". Any feed back
is most welcome.
Note: I am running java 1.5 with Junit 4.
/** This is the code I ran as a test in SWT Bot. */
import junit.framework.TestCase;
import org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot;
import org.junit.Test;
public class SWT_TEST extends TestCase {
private SWTWorkbenchBot bot;
public SWT_TEST() {
bot = new SWTWorkbenchBot();
@Test
public void runTest() throws Exception {
try {
bot.viewByTitle("Welcome").close();
catch(Exception e) {
throw new Exception();
Best regards. --robert julian
Re: getting started with SWT Bot [message #695660 is a reply to message #695645] |
Tue, 12 July 2011 08:44 |
On 7/12/2011 1:54 PM, Benjamin Ratiarisolo wrote:
> Hi Robert,
> It looks as if your test did not actually run. You did not mention how
> you are running your tests (within eclipse, from the command line,
> through an ANT task, etc.), but this could come from conflicting JUnit
> jars/plug-in versions.
> I faced a similar issue when I first started using SWTBot. If you dig a
> little bit I am pretty sure you'll find various threads about it in this
> forum or a corresponding FAQ/article in the SWTBot Wiki.
> Hope this helps,
dear benjamin,
thank a lot for the reply. yes, the link was very useful.
i have my first swtbot application up and running!. :).
best regards. --robert julian
FUDForum. Page generated in 0.02224 seconds
