Home » Archived » BIRT » BIRT Integration(BIRT 3.7 integration with RAP runtime 1.4)
Re: BIRT Integration [message #695598 is a reply to message #694981] |
Tue, 12 July 2011 05:26 |
Sid,
You can still get the plugins in normal format from the allinone
download or framework download. If you use the runtime download you
would call BIRT by adding the jars to your classpath. My guess is you
are going to want to continue to use the plugins.
Jason
On 7/10/2011 9:57 AM, Sid Nepomuceno wrote:
> Can someone direct me on how to integrate the new BIRT 3.7 with RAP
> runtime 1.40.
> In the past I could integrate BIRT 2.3.2 with RAP 1.40M5 using some
> steps from some blog resources like
> "//blog.tim-pietrusky.de/2009/rich-ajax-platform-rap/integrating-birt-into-rap-applications/".
> I noticed that the BIRT runtime plugins are all bundled into one -
> "org.eclipse.birt.runtime_3.7.0.v20110615-1818" with restricted access.
> I would appreciate if someone has already came up with solution/steps to
> share so I would not dive in due to lack of time to do it. I've been
> using embedded Report Engine API and Open Data Access (ODA) extension
> API in my code.
> Sid
Re: BIRT Integration [message #696320 is a reply to message #696143] |
Wed, 13 July 2011 16:21 |
Sid
You should either use the framework or the runtime download, not both.
I know there where some RAP examples on Birt-exchange.org, but none that
i know of that show 3.7. I have a RCP app that I call the report engine
and the viewer that I built for 2.6 and I just opened the source in BIRT
3.7 allinone and ran the code and it worked fine. I did not need to
make any changes. If you want to look at the examples. Take a look at
this download.
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1344-eclipsecon-2011-api-examples/
Jason
On 7/13/2011 7:04 AM, Sid Nepomuceno wrote:
> Thanks Jason.
> I am able to add the BIRT plugins from the framework download to that of
> the runtime download.
> There are still a lot of unresolved dependencies when mixing the 2
> runtimes (BIRT 3.7 & RAP 1.4) though.
> Do you know of a group or individual who can already provide the right
> combination of plugins?
> I am just avoiding wasting too much time doing "trial and error" mixes
> if this is already available.
> - Sid
Re: BIRT Integration [message #697978 is a reply to message #697628] |
Mon, 18 July 2011 14:19 |
Sid,
Can you give some more details on how you are integrating the two? Do
you have a small app example that I could work with?
Jason
On 7/17/2011 10:04 AM, Sid Nepomuceno wrote:
> Hi Jason,
> I have found BIRT 2.6.2 still to be a better fit to RAP runtime 1.40
> having no incompatibility in mixing the plugins (all ACTIVE/RESOLVED
> status). However I'm getting this problem at runtime which you might
> have already encountered in your past codes -
> java.lang.NoClassDefFoundError: com/ibm/icu/util/ULocale
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
> at net.thmb.pmt.rap.Application.start(Application.java:23)
> at
> org.eclipse.rap.ui.internal.application.EntrypointApplicationWrapper.createUI(EntrypointApplicationWrapper.java:27)
> at
> org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:73)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:211)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:88)
> at java.lang.Thread.run(Unknown Source)
> at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
> Despite modifying the access rules for this plugin - com.ibm.icu, I'm
> still getting the same error when I run my app. Hope you could shed
> light on this.
> Sid
Re: BIRT Integration [message #699815 is a reply to message #697978] |
Fri, 22 July 2011 11:22 |
Sid Nepomuceno Messages: 7 Registered: July 2011 |
Hi Jason,
Below are the steps I used to integrate the two runtime plugins and a small app ...
A. Install a RAP runtime target platform with compatible BIRT runtime
1. Download RAP runtime v1.4
2. Download BIRT runtime 2.6.2
3. Remove older versions of conflicting plugins such as:
org.eclipse.core.contenttype
org.eclipse.core.expressions
org.eclipse.core.jobs
org.eclipse.core.runtime
org.eclipse.equinox.app
org.eclipse.equinox.common
org.eclipse.equinox.preferences
org.eclipse.equinox.registry
org.eclipse.osgi.services
org.eclipse.osgi
org.eclipse.update.configurator
4. All batik plugins and org.w3c.dom.svg plugin's manifest files should be fixed.
In the Manifest Require-bundle, change 'version' to 'bundle-version'
B. Create a new plug-in project using a demo wizard - RAP Application with a view
1. Under Dependencies tab of Manifest, add 'org.eclipse.birt.report.engine'
2. Update the Application class to include the following:
public Object start(IApplicationContext context) throws Exception {
if(ApplicationManager.getInstance().initialize() == 0) System.exit(0);
Display display = PlatformUI.createDisplay();
WorkbenchAdvisor advisor = new ApplicationWorkbenchAdvisor();
return PlatformUI.createAndRunWorkbench(display, advisor);
3. This will instantiate a singleton which will initially call the BIRT report engine. Create a class called ApplicationManager (see below)
import java.util.HashMap;
import java.util.Map;
import java.util.logging.Level;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
public class ApplicationManager {
private static final ApplicationManager INSTANCE = new ApplicationManager();
private static Map<String, Object> configMap;
private static IReportEngine rptEngine = null;
private static EngineConfig rptConfig = null;
private ApplicationManager(){
configMap = new HashMap<String, Object>();
public static ApplicationManager getInstance(){
return INSTANCE;
public int initialize(){
setReportConfig();
return 1;
public static Map<String, Object> getConfigMap() {
return configMap;
private void setReportConfig() {
try{
rptConfig = new EngineConfig( );
rptConfig.setBIRTHome("");
rptConfig.setLogConfig(null, Level.OFF);
//rConfig.setResourcePath(resourcePath)
org.eclipse.birt.core.framework.Platform.startup( rptConfig );
IReportEngineFactory factory = (IReportEngineFactory) org.eclipse.birt.core.framework.Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
rptEngine = factory.createReportEngine(rptConfig);
}catch( Exception e){
e.printStackTrace();
public static IReportEngine getReportEngine(){
return rptEngine;
public static void close(){
rptEngine.destroy();
org.eclipse.birt.core.framework.Platform.shutdown();
I only show the part of the app where the BIRT report engine is initially called.
The error kicks in immediately. This does not happen in BIRT 2.3.2 which is my working app. This happens in BIRT 2.5.2, 2.6.0, 2.6.2 which I tried.
Sid
Re: BIRT Integration [message #707354 is a reply to message #706742] |
Mon, 01 August 2011 14:22 |
Sid,
That class is in the com.ibm.icu_version.jar plugin. Is this plug-in
loaded? Also have you tried using the birt Framework download instead
of the runtime download?
Jason
On 7/31/2011 4:52 PM, Sid Nepomuceno wrote:
> Hi Jason,
> Hope the integration steps I have posted to you could recreate the issue
> on your side. Let me know if it does. So what do you think could
> possibly cause the 'ULocale class not found' problem?
> Regards,
> Sid
Re: BIRT Integration [message #730316 is a reply to message #694981] |
Wed, 28 September 2011 07:11 |
Beate M Messages: 6 Registered: September 2011 |
I'm having problems integrating BIRT 3.7 with RAP 1.4, too.
(I've also tested BIRT 3.7 with RCP, getting the same exception,
so I think it might be a bug in BIRT 3.7)
The reports were working with BIRT 2.6.2.
Platform.startup(config) leads to this exception:
org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:81)
at com.example.addressbook.maps.handlers.BirtTest.doTest(BirtTest.java:29)
at com.example.addressbook.maps.handlers.ShowMapsHandler.execute(ShowMapsHandler.java:20)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at com.example.addressbook.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: org.eclipse.birt.core.framework.FrameworkException: Cant register the ExtensionRegistry classpath
at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:99)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:75)
... 35 more
Caused by: org.eclipse.core.runtime.CoreException: Extension registry provider is already set.
at org.eclipse.core.internal.registry.RegistryProviderFactory.setDefault(RegistryProviderFactory.java:31)
at org.eclipse.core.runtime.RegistryFactory.setDefaultRegistryProvider(RegistryFactory.java:129)
at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:84)
... 36 more
Leaving the line (Platform.startup) out, because it's not needed in a RCP/RAP application
(mentioned here: www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.php#engineconfig),
results in a NullPointerException, because platform is null and the factory used to
create the report engine is therefore also null.
It doesn't matter if I call config.setEngineHome(...) or not.
If I start the application as a java application the report will be generated.
There is already a bug, which might have the same reason: bugs.eclipse.org/bugs/show_bug.cgi?id=351052
And a solved forum entry, but here the mistake was to start the report engine a second time:
www.eclipse.org/forums/index.php/m/727652/
But I'm not able to start it once, because the RAP or RCP platform is already running.
Does someone having the same problem?
Is it a bug in BIRT 3.7?
Or has someone successfully integrated BIRT 3.7 with RAP or RCP?
Hope someone has a solution for me.
Beate
[Updated on: Wed, 28 September 2011 07:20] Report message to a moderator
Re: BIRT Integration [message #730318 is a reply to message #694981] |
... 35 more
... 36 more
Beate
Re: BIRT Integration [message #730491 is a reply to message #730318] |
Wed, 28 September 2011 14:06 |
Beate,
Are you using the BIRT Framework plugins or are you using the POJO
runtime? How are you doing the integration?
Jason
On 9/28/2011 3:11 AM, Beate M wrote:
> Hello,
> (I've also tested BIRT 3.7 with RCP, getting the same exception, so I
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> ... 35 more
> at
> at
> at
> ... 36 more
> RCP/RAP application (mentioned here:
> factory used to create the report engine is therefore also null.
> engine a second time: www.eclipse.org/forums/index.php/m/727652/
> already running.
> Beate
Re: BIRT Integration [message #730831 is a reply to message #730491] |
Thu, 29 September 2011 09:57 |
Hello Jason,
I used the POJO runtime.
After your post I tried the BIRT Framework plugins. Now it is working.
But to get it working I had to include many plugins (RCP, EMF, etc.) in the target platform.
Most of the plugins aren't needed, if you only want to generate the report with the report engine.
Is there a collection of all plugins I need to do this, or do I have to figure
out myself which plugins are really necessary?
About the POJO runtime:
Is there a way to use the new BIRT 3.7 like the old Version?
So that I download the BIRT runtime, call it from my RAP application and the
report engine runs separately.
(e.g. to use one report engine for several applications)
Beate
Jason Weathersby wrote on Wed, 28 September 2011 10:06Beate,
Jason
Re: BIRT Integration [message #730942 is a reply to message #730831] |
Thu, 29 September 2011 15:07 |
Beate,
We do not have a list of plugins for this type of usage and mainly
because so many of the plugins are usage based. I would start with
removing any birt plugin that contains a ui tag. Also remove sample
reports plugin and sample database plugin. I also believe you can
remove all the designer plugins. Next remove emitters that you do not
need and remove data sources that you do not need.
If you want to use the POJO runtime, you will need to include the BIRT
runtime like any other set of jars that are not OSGi based and call the
APIs. In this fashion you will need to do a Platform.startup.
Jason
On 9/29/2011 5:57 AM, Beate M wrote:
> Hello Jason,
> the target platform. Most of the plugins aren't needed, if you only want
> figure out myself which plugins are really necessary?
> the report engine runs separately. (e.g. to use one report engine for
> Regards,
> Beate
>> Beate,
>> Jason
Re: BIRT Integration [message #731150 is a reply to message #730942] |
Fri, 30 September 2011 06:54 |
Hello Jason,
My first attempt was to use the POJO runtime, I also called Platform.startup,
which leads to the exception in my earlier post.
Right now the solution with the runtime plugins is ok for me,
so I won't investigate this any further until I need it.
Thanks for your help.
Beate
Jason Weathersby wrote on Thu, 29 September 2011 11:07Beate,
Jason
> Hello Jason,
> Regards,
> Beate
>> Beate,
>> Jason
Re: BIRT Integration [message #760194 is a reply to message #760057] |
Thu, 01 December 2011 15:06 |
Do you mean updating the viewer or the designer?
Jason
On 12/1/2011 1:26 AM, navnath.gajare wrote:
> currently i m using eclipse birt 2.3.2
> I want to upgrade it to birt 2.6.2
> which is the way...or which are d steps tht i should follow
Current Time: Fri Mar 29 11:19:05 GMT 2024
Powered by FUDForum. Page generated in 0.04846 seconds
