Deploy Aspectj plugin/fragment as part of a feature [message #70467] |
Wed, 29 August 2007 15:01 |
Originally posted by: reto.urfer.logicacmg.com
I have a java plugin A and an aspectj fragment B extending plugin A. I would
like to deploy plugin A and fragment B together as a feature. Unfortunately
when I export the feature, the components A and B are both exported assimple
java plugins/fragments whith the result that all the aspects in fragment B
are not compiled.
Is there a way to specifiy that a plugin/fragment of a feature should be
built with aspectj support instead of simple java support?
cheers
Reto
Re: Deploy Aspectj plugin/fragment as part of a feature [message #70485 is a reply to message #70467] |
Fri, 31 August 2007 21:09 |
Originally posted by: gxquarel.txin.it
Maybe is the same export bug I submitted here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197394
If you think so, add your comments and vote it.
Ciao
Giovanni
"Reto Urfer" <reto.urfer@logicacmg.com> ha scritto nel messaggio
news:fb41o6$1q6$1@build.eclipse.org...
> Hi
> would like to deploy plugin A and fragment B together as a feature.
> Unfortunately when I export the feature, the components A and B are both
> exported assimple java plugins/fragments whith the result that all the
> aspects in fragment B are not compiled.
> cheers
> Reto
FUDForum. Page generated in 0.03152 seconds
