Re: Any experience with MKS integration [message #74728 is a reply to message #70427] |
Sun, 15 June 2003 12:41 |
Originally posted by: cecconae.ig.com.br
Kenneth Corbin wrote:
> Has anyone had any luck integrating MKS with the Eclipse 2.1 IDE? I've
tried
> the IBM WebSphere integration that comes with MKS with disapointing
> results. MKS has an newer Eclipse integration patch on their web page,
> but it requires patching the MKS server, which I can't do myself. I can
> try to make the case that our IT people should install that patch, but it
> would help if someone can confirm that that patch does make a substantial
> difference.
> Alas, it is a corporate policy that everyone use MKS, personally I'd
> rather switch to CVS.
Hi, Kenneth :
I don´t know what means "make a substantial difference" we use that new
MKS plugin with WSAD 5. It does the basic this like check-in check-out.
Its better than old WSAD 4.0 plugin, for sure. Its not as good as CVS
plugin yet.
Sincerely,
Antonio
FUDForum. Page generated in 0.02965 seconds
