Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [teneo] bidirectional OneToOne containment association - container not set in child object
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #70464 is a reply to message #70386] |
Mon, 05 February 2007 19:26 |
Hi Andre,
Did you use the option: DISABLE_ECONTAINER_MAPPING? If set to true then no econtainer information is
stored in the table and the econtainer is not set when reading one-to-one.
The HibernatePersistableEList is only used to one-to-many and not for one-to-one relations.
gr. Martin
Andre Pareis wrote:
> Hi alltogether,
> on CVS head version of teneo and previous versions:
> I can successfully save and load a containment hierarchy with a
> one-to-one association between a container and a child, and this
> hierarchy is displayed correctly in the editor tree. However, if I
> invoke a method on the child which navigates to the container, either
> via the named association or the eContainer() I found that the container
> reference is null. Only the container has a reference set to the child,
> but not vice-versa.
> I tried to play around with the code here in HibernatePersistableEList:
> // disabled for now as containers are persisted by hibernate anyway
> if (false && isContainment()) {
> final int featureID = getEStructuralFeature().getFeatureID();
> for (int i = 0; i < objs.length; i++) {
> if (objs[i] instanceof InternalEObject) {
> EContainerRepairControl.setContainer(owner,
> (InternalEObject) objs[i], getEStructuralFeature());
> I've set the constant to "true" but it did not have any positive effect.
> Any help? How or when do you expect hibernate to set both side of the
> association?
> Thanks
> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #70602 is a reply to message #70464] |
Tue, 06 February 2007 19:26 |
Andre Pareis Messages: 113 Registered: July 2009 |
Hi Martin,
no I don't set this. So I assumed it is all handled automatically. The result is
now that in one direction (from parent to child) the association is set, but not
in the other direction (from child to parent).
Is there something else I can do to achieve this but without enabling the
DISABLE_ECONTAINER_MAPPING option? Definitely I do not want to have these
container attributes in the DB.
Andre
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi alltogether,
>> container reference is null. Only the container has a reference set to
>> the child, but not vice-versa.
>> association?
>> Thanks
>> Andre
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #70669 is a reply to message #70602] |
Tue, 06 February 2007 22:56 |
Hi Andre,
I am not sure, do you explicitly set DISABLE_ECONTAINER_MAPPING to true? If not set (it's default is
false) then the econtainer fields should be present in the db (unless you have overridden HbDataStore).
If the econtainer info is not set in the db then when the child is read (without its parent) then it
won't know of its parent (as it has not been defined in the db).
So the relation can only be managed correctly if the parent has also been read. Although I need to
make a change to accomplish this as the current approach is completely based on the econtainer being
present in the db.
Would it work if the parent needs to be read also (with a tree view this will be the case most of
the time)?
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> result is now that in one direction (from parent to child) the
> association is set, but not in the other direction (from child to parent).
> the DISABLE_ECONTAINER_MAPPING option? Definitely I do not want to have
> these container attributes in the DB.
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> one-to-one.
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi alltogether,
>>> to the child, but not vice-versa.
>>> association?
>>> Thanks
>>> Andre
The Netherlands
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #602153 is a reply to message #70386] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi alltogether,
> but not vice-versa.
> association?
> Thanks
> Andre
The Netherlands
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #602233 is a reply to message #70464] |
Hi Martin,
Andre
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi alltogether,
>> association?
>> Thanks
>> Andre
Re: [teneo] bidirectional OneToOne containment association - container not set in child object [message #602255 is a reply to message #70602] |
Hi Andre,
present in the db.
the time)?
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> one-to-one.
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi alltogether,
>>> association?
>>> Thanks
>>> Andre
The Netherlands
Current Time: Wed Apr 24 23:51:54 GMT 2024
Powered by FUDForum. Page generated in 0.03172 seconds
