Customize the pop-up message in BIRT viewer [message #694549] |
Fri, 08 July 2011 20:01 |
Scroon Messages: 28 Registered: June 2011 |
When the mouse hold on in BIRT viewer, it pop up a message with default context: BIRT Report Viewer
Is there a way to customize the pop up message on each element of the report please?
For example, when a user move his mouse arrow on an image with some hyperlink, it pops up a message click here to...., and when the mouse arrow on a column name, it pops up a message column name
Thanks in advance
[Updated on: Fri, 08 July 2011 20:09] Report message to a moderator
Re: Customize the pop-up message in BIRT viewer [message #694561 is a reply to message #694549] |
Fri, 08 July 2011 20:20 |
On most report items you can set the help text in the advanced
properties for the item.
Jason
On 7/8/2011 4:01 PM, Scroon wrote:
> Hello,
> E.g. When the mouse point on an image with some hyperlink, it pops up a message click here to...., and when the mouse point on a column name, it pops up a message column name...
Re: Customize the pop-up message in BIRT viewer [message #694578 is a reply to message #694570] |
Fri, 08 July 2011 21:20 |
Yes, just use an onCreate script like:
this.helpText = this.getRowData().getColumnValue("QUANTITYORDERED") + "
: Ordered";
Jason
On 7/8/2011 5:10 PM, Scroon wrote:
> Hello Jason,
> Thank you for reply. I tried and found it just display static texts.
> Is it possible to use JAVA scripts in those help text? For display some
> parameter value.
> Thanks
FUDForum. Page generated in 0.02964 seconds
