Home » Archived » BIRT » Hide empty table
Hide empty table [message #692840] Tue, 05 July 2011 10:33 Go to next message
frank.dullweber is currently offline frank.dullweberFriend
How can I hide a complete table in a report if the data set is empty (number of rows = 0)?
Re: Hide empty table [message #692992 is a reply to message #692840] Tue, 05 July 2011 15:18 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Add a column to the table bindings that counts the number of rows. Use
this column in the visibility expression for the table. See attached
example.
for the parameter enter 111 to get no rows or 10101 to get values.
Jason
Re: Hide empty table [message #708047 is a reply to message #692992] Tue, 02 August 2011 11:34 Go to previous messageGo to next message
jeyinul  is currently offline jeyinul Friend
Member
Can you explain how to hide empty rows in cross tab.
Attached file is not supported.
Plz help me on this.
Re: Hide empty table [message #708207 is a reply to message #708047] Tue, 02 August 2011 15:12 Go to previous messageGo to next message
Empty crosstab rows should not display by default. Take a look at this
link:
http://www.eclipse.org/birt/phoenix/project/notable2.3.php#jump_4
Jason
Re: Hide empty table [message #890137 is a reply to message #692840] Thu, 21 June 2012 09:04 Go to previous message
Bluish Joe is currently offline Bluish JoeFriend
Another solution could be http://www.eclipse.org/forums/index.php/mv/msg/208014/890134/#msg_890134, which doesn't need additional columns/report objects.
[Updated on: Fri, 30 November 2012 08:20]
Report message to a moderator
Previous Topic:How to hide the table header when there is no content in the table ?
Next Topic:Can BIRT template accept images from an XML datasource
Current Time: Tue Jan 25 23:43:32 GMT 2022
Powered by FUDForum. Page generated in 0.02211 seconds
