Home » Modeling » TMF (Xtext) » JavaValidator Xtext 2.0 Migration(Literals not found)
Re: JavaValidator Xtext 2.0 Migration [message #693029 is a reply to message #692969] |
Tue, 05 July 2011 16:31 |
JJ Mising name Messages: 12 Registered: November 2010 |
I just tried creating a blank project and it generates the class with the Literals interface. When I process my xtext file I get a long series of warnings all related to the same and last line in my InternalXXX.g file (see below): RULE_ANY_OTHER : .;
All the code generation happens properly (as far as I can tell) except that the Internals is not present in the XXXPackage file. Looks like I am going to have to fix these warnings.
As a result, token(s) T__41,T__42,RULE_ANY_OTHER were disabled for that input
error(208): ../com.canappi.metamodels.mdsl/src-gen/com/canappi/metamodels/mdsl/parser/antlr/internal/InternalMDsl.g:11830:1: The following token definitions can never be matched because prior tokens match the same input: T__27,T__31,T__41,T__42,T__45,T__46,T__47,T__48,T__51,T__54,T__55,T__57,T__58,T__59,T__60,T__61,T__63,T__64,T__65,T__67,T__68,T__70,T__71,T__72,T__73,T__74,T__75,T__76,T__77,T__78,T__79,T__80,T__81,T__82,T__83,T__84,T__85,T__86,T__87,T__88,T__89,T__90,T__91,T__92,T__93,T__94,T__95,T__96,T__97,T__98,T__99,T__100,T__101,T__102,T__103,T__104,T__105,T__106,T__107,T__108,T__109,T__110,T__111,T__112,T__113,T__114,T__115,T__117,T__118,T__119,T__120,T__121,T__122,T__123,T__124,T__125,T__126,T__127,T__128,T__129,T__130,T__132,T__133,T__134,T__135,T__137,T__139,T__140,T__141,T__142,T__143,T__144,T__145,T__146,T__147,T__148,T__149,T__150,T__151,T__152,T__153,T__154,T__155,T__156,T__157,T__158,T__159,T__161,T__162,T__163,T__164,T__165,T__166,T__167,T__168,T__169,T__171,T__172,T__173,T__174,T__175,T__176,T__177,T__178,T__179,T__180,T__181,T__182,T__183,T__184,T__185,T__186,T__187,T__188,T__189,T__190,T__191,T__192,T__193,T__194,T__195,T__196,T__197,T__198,T__199,T__200,T__201,T__203,T__205,T__206,T__207,T__208,T__209,T__210,T__211,T__212,T__213,T__214,T__215,T__216,T__217,T__218,T__220,T__221,T__222,T__223,T__224,T__225,T__226,T__227,T__228,T__229,T__230,T__231,T__232,T__233,T__234,T__235,T__236,T__237,T__238,T__239,T__240,T__241,T__242,T__243,T__244,T__248,T__249,T__250,T__251,T__252,T__253,T__258,T__259,T__260,T__261,T__262,T__263,T__264,T__265,T__266,T__268,T__269,T__271,T__273,T__274,T__275,T__276,T__277,T__278,T__279,T__280,T__281,T__283,T__284,T__285,T__286,T__287,T__288,T__289,T__290,T__291,T__292,T__293,T__294,T__295,T__296,T__297,T__298,T__300,T__301,T__302,T__303,T__304,T__305,T__306,T__309,T__310,T__311,T__312,T__313,T__314,T__315,T__316,T__317,T__318,T__319,T__320,T__321,T__322,T__323,T__324,T__325,RULE_INT,RULE_POSINTNUMBER,RULE_NEGINTNUMBER,RULE_SL_COMMENT
Re: JavaValidator Xtext 2.0 Migration [message #693067 is a reply to message #693029] |
Tue, 05 July 2011 17:58 |
Ok, I have corrected my warnings now. It is quite strange, all I had to do is replace ('0'..'9')+ with ('0'..'9')('0'..'9')* in all my terminal declarations.
However, I am now able to process the xtext file without warnings (or errors) and the XXXPackage class does not contain any Literals interface.
This is the output of the xtext file processing:
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri '/Users/jjdubray/Documents/moppr/releases/V1.1/workspace'
5136 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /Users/jjdubray/Documents/moppr/releases/V1.1/workspace/com.canappi.metamodels.mdsl/../com.canappi.metamodels.mdsl/src-gen
5545 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /Users/jjdubray/Documents/moppr/releases/V1.1/workspace/com.canappi.metamodels.mdsl/../com.canappi.metamodels.mdsl.ui/src-gen
6536 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for com.canappi.metamodels.mdsl.MDsl with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, GeneratorFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, Junit4Fragment, TypesGeneratorFragment, XbaseGeneratorFragment, CodetemplatesGeneratorFragment
32946 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.canappi.com/metamodels/mdsl/MDsl' from 'file:/Users/jjdubray/Documents/moppr/releases/V1.1/workspace/com.canappi.metamodels.mdsl/src-gen/com/canappi/metamodels/mdsl/MDsl.genmodel'
193469 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
277411 [main] INFO text.generator.junit.Junit4Fragment - generating Junit4 Test support classes
283476 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Current Time: Thu Mar 28 15:34:47 GMT 2024
Powered by FUDForum. Page generated in 0.03097 seconds
