Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Render HTML
Render HTML [message #692364] Mon, 04 July 2011 09:36 Go to next message
J.-P. Pellet is currently offline J.-P. PelletFriend
Member
I'm interested in displaying HTML text in an app I have that doesn't use
SWT. Is there a way I can use SWT's WebKit integration to ask it to
render the text in an image that I can reuse?
TIA,
J.-P.
Re: Render HTML [message #692959 is a reply to message #692364] Tue, 05 July 2011 14:41 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
I don't think there's a way to do this, the webkit natives that swt
binds to are those that are needed specifically for its provision of the
Browser control. You can investigate whether webkit provides the
natives that you need, and if so then bind directly to it (not through
swt). I don't remember seeing these, but it's possible that they're
there and I just ignored them if they weren't useful for the Browser
implementation.
Grant
On 7/4/2011 5:36 AM, J.-P. Pellet wrote:
> TIA,
> J.-P.
Re: Render HTML [message #693503 is a reply to message #692959] Wed, 06 July 2011 15:23 Go to previous message
Member
Hi Grant,
Thanks for your comments. I abandoned this track and went for Flying
Saucer instead: http://code.google.com/p/flying-saucer/
Granted, the capabilities are much more limited, but enough for my use case.
J.-P.
On 05.07.11 16:41, Grant Gayed wrote:
> Browser control. You can investigate whether webkit provides the natives
> that you need, and if so then bind directly to it (not through swt). I
> don't remember seeing these, but it's possible that they're there and I
> just ignored them if they weren't useful for the Browser implementation.
> Grant
Previous Topic:Pls help! How to add a checkbox on the tableheader?
Next Topic:Double Scale SWT
Current Time: Wed Sep 23 01:05:11 GMT 2020
Powered by FUDForum. Page generated in 0.01578 seconds
