Home » Archived » ORMF » Proposal Comments
Proposal Comments [message #6234] |
Tue, 18 March 2008 14:00 |
Ben Garbers Messages: 4 Registered: July 2009 |
-I viewed your tutorial and noticed that you has a Useme server. How do
you set this up? This was the same thing that I ran into with my capstone
project where I created a Project Management Eclipse Plugin that would
store employee tasks / documents (like requirements, design documents,
etc) within a database. The problem I had with this is that if an
independent user wants to use your software they have to setup this
database server and point to it. To get around this I was going to treat
each task as a file or each requirement as a file of which the user can
check into a code repository like CVS or Subversion. I notice that within
the proposal their is a diagram of the functional architecture where web
services is used and a backend database. This again I think could instead
be CVS, etc. where a person using ORMF wouldn't be dependent on setting up
a server.
-Your requirements specification is use case centric where my requirements
specification is based off of IEEE 1988 Format. Additionally, within my
requirements editor I have the capability of measuring estimated time to
do development process tasks vs. actuals. For example, I require a user
to estimate from a specific requirement how long it is going to take an
individual to do design documentation, implementation and testing. I then
compare the individuals estimates to the different theoretical models such
as Function Point Analysis and DeMarcos Model. Additionally, during the
development process I also get actuals from implementation, testing, etc.
I then can compare these values to the estimates which gives the project
manager an idea of how the project is doing. I would not expect this in
ORMF. Just informing you what I did within the Napkins Requirements
Editor. You can actually download the Napkins Requirements Editor to see
what I am talking about. It is located at
http://www.napkins-development-tools.com/NapkinsDynamicWebsi te/napkinsR.do
-This is more an FYI but there is a company that created an eclipse
plug-in for work items
( http://www.polarion.org/index.php?page=features&project= fasttrack) These
work items are checked into CVS or Subversion then. There is no server
dependency at all.
-I think that 'smart links' may be confusing initally. After I read
them and saw the demo they made more sense.
-When I presented my napkins requirements editor a couple of things
everyone said were required when writing requirements; spell checker, a
subscription service to subscribe to a requirement that might change and a
way to view the requirements document in pdf or word format. Note that my
napkins requirements editor has a spell checker and a way to extract the
document to pdf and view it as an html file. Also screen shots can be
taken and placed within the document. This is key for requirements that
effect a GUI.
Re: Proposal Comments [message #7815 is a reply to message #6234] |
Thu, 27 March 2008 20:38 |
> do you set this up? This was the same thing that I ran into with my
> capstone project where I created a Project Management Eclipse Plugin
> that would store employee tasks / documents (like requirements, design
> documents, etc) within a database. The problem I had with this is that
> if an independent user wants to use your software they have to setup
> this database server and point to it. To get around this I was going
> to treat each task as a file or each requirement as a file of which the
> user can check into a code repository like CVS or Subversion. I notice
> that within the proposal their is a diagram of the functional
> architecture where web services is used and a backend database. This
> again I think could instead be CVS, etc. where a person using ORMF
> wouldn't be dependent on setting up a server.
We considered the CVS approach early on in the project and ended up
rejecting it because it would be too complex (if not impossible) to
keep fine grained document referencing in place, and because we do no
think that CVS/SVN is a suitable interface for non technical users. The
user profile for requirements tools clearly has many BA types who we
think would be scared off by CVS.
In the end one has to pick the audience they are addressing, make the
appropriate compromises and accept that no [useful] tool suits all.
Much of this is now changing. As you may have noticed (see thread on
newsgroup), this week we announced that we are forming a collaboration
with the OSEE project. This means that we will be re-architecting ORMF
to sit on top of their framework. This includes the OSEE server which
is a lightweight OSGI server built on top of Equinox and a database.
This is a much more approachable server option then a full J5EE server.
I had already been considering migrating to OSGI, so I very pleased
that is already part of the OSEE architecture.
> requirements specification is based off of IEEE 1988 Format.
> Additionally, within my requirements editor I have the capability of
> measuring estimated time to do development process tasks vs. actuals.
> For example, I require a user to estimate from a specific requirement
> how long it is going to take an individual to do design documentation,
> implementation and testing. I then compare the individuals estimates
> to the different theoretical models such as Function Point Analysis and
> DeMarcos Model. Additionally, during the development process I also
> get actuals from implementation, testing, etc. I then can compare
> these values to the estimates which gives the project manager an idea
> of how the project is doing. I would not expect this in ORMF. Just
> informing you what I did within the Napkins Requirements Editor. You
> can actually download the Napkins Requirements Editor to see what I am
The
work that you have done around measuring estimated time and
capture/comparison of actuals is one of the areas that really excited
Barbara and me. This is definitely part of the vision we have had, but
we have not even started considering what would be required. I beg to
differ with you that these features are not pertinent to use cases. The
type of estimation may be different, but the concepts are very much
relevant.
I would like to emphasise that handing use cases was only the starting
point for our vision. We envisioned a framework that could be easily
extended to handle a wide variety of document types and standards. I
should also mention that OSEE already handles unstructured
requirements. Take a look at their website
<http://www.eclipse.org/osee/> to get a feel for what they have
achieved to date.
> These work items are checked into CVS or Subversion then. There is no
> server dependency at all.
Thanks I will have a look.
Where was you initial confusion from? The proposal? I would like to
review the source to see of we can do a better job of describing it
upfront.
> and a way to view the requirements document in pdf or word format.
> Note that my napkins requirements editor has a spell checker and a way
> to extract the document to pdf and view it as an html file. Also
> screen shots can be taken and placed within the document. This is key
> for requirements that effect a GUI.
All very good points, thanks.
Thanks for all of the comments Ben the contribution is very much appreciated.
You said previously that you would like to participate in the project
starting in a couple of months. We would love to have you on board. May
I add you to the committer list on the proposal?
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Tool
====w=w==== [https://useme.dev.java.net]
Re: Proposal Comments [message #562678 is a reply to message #6234] |
The
relevant.
achieved to date.
upfront.
Joel
Joel Rosi-Schwartz
Current Time: Thu Apr 25 01:29:20 GMT 2024
Powered by FUDForum. Page generated in 0.03659 seconds
