nested import declaration [message #69913] |
Tue, 17 October 2006 12:37 |
Sven Krause Messages: 64 Registered: July 2009 |
Member |
--------------080804050509030401010403
Hi Ed,
you are stated that imports within schemas are not transitive. Do you
have a source for the statement?
We have currently (dicussion-) problems on interpreting a set of schema
files created (by another company resource) using xml spy. xml spy does
not complain about missing declarations for prefixed defined within
schema documents that is referenced by include.
Please see attached a scenario where a missing type is complained within
the eclipse-xsd, but accepted by xml spy, stylus studio and some more.
Sven
Content-Type: text/xml;
name="doc1.xsd"
Content-Disposition: inline;
filename="doc1.xsd"
<?xml version="1.0"?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace="http://sample/base">
<xsd:simpleType name="base_Type">
<xsd:restriction base="xsd:string" />
</xsd:simpleType>
</xsd:schema>
name="doc2.xsd"
filename="doc2.xsd"
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace="http://sample/ext" xmlns:base="http://sample/base">
<xsd:import namespace="http://sample/base" schemaLocation="doc1.xsd" />
</xsd:schema>
name="doc3.xsd"
filename="doc3.xsd"
<xsd:include schemaLocation="doc2.xsd" />
<xsd:simpleType name="ext_Type">
<xsd:restriction base="base:base_Type" />
</xsd:simpleType>
</xsd:schema>
Content-Type: message/rfc822;
name="Nachricht als Anhang"
filename="Nachricht als Anhang"
Path: utils.eclipse.org!news.eclipse.org!localhost!not-for-mail
Newsgroups: eclipse.technology.xsd
Subject: Re: How to load Include/Redefine/Import Namespaces?
Date: Tue, 12 Oct 2004 08:24:50 -0400
Organization: EclipseCorner
Message-ID: <ckgi4u$vda$1@eclipse.org>
References: <ckfa47$rgp$1@eclipse.org>
NNTP-Posting-Host: cpe000d60240bb6-cm400045887339.cpe.net.cable.rogers.com
Mime-Version: 1.0
X-Trace: eclipse.org 1097583582 32170 65.48.236.22 (12 Oct 2004 12:19:42 GMT)
X-Complaints-To: news@eclipse.org
NNTP-Posting-Date: Tue, 12 Oct 2004 12:19:42 +0000 (UTC)
User-Agent: Mozilla Thunderbird 0.8 (Windows/20040913)
X-Accept-Language: en-us, en
In-Reply-To: <ckfa47$rgp$1@eclipse.org>
Xref: localhost eclipse.technology.xsd:1193
Anne,
Imports are not transitive, i.e., including a schema that contains an
import is not the same has having the import directly in the including
schema, so you likely need to add more direct imports.
Anne wrote:
>Hi folks,
>I have got three schema files, one of them includes another schema, while
>the another one import some other schema. However, when I load the main
>Schema the others seem not be visible or loaded. How do I make sure that
>the included/imporrtes Schemas are visible.
>Rgs
>Anne
--------------080804050509030401010403--
Re: nested import declaration [message #69935 is a reply to message #69913] |
Tue, 17 October 2006 12:51 |
--------------020706080709060109000903
Sven,
This definition in the XML Schema spec is relevant:
[Definition:] Whenever the word *resolve* in any form is used in
this chapter in connection with a
Re: nested import declaration [message #598819 is a reply to message #69913] |
Ed Merks Messages: 33141 Registered: July 2009 |
Sven,
Ed Merks
FUDForum. Page generated in 0.03254 seconds
