Home » Eclipse Projects » EGit / JGit » Old EGit versions
Old EGit versions [message #691584] Fri, 01 July 2011 19:18 Go to next message
Mike Haney is currently offline Mike HaneyFriend
Is there a site where I can still access a .11 or .12 release of EGit?
We are using Indigo and EGit 1.0 for our main development, but that is giving us problems with Buckminster. So I want to setup a Helios environment solely for working on build and provisioning scripts. But whenever I try to add EGit through either the main update site or the marketplace, all that is available is 1.0, which is incompatible with the older version of Buckminster.
Even the main egit/updates aggregated site is only aggregating the 1.0 release site, and I can't find any references to the older site.
Re: Old EGit versions [message #691869 is a reply to message #691584] Sat, 02 July 2011 16:47 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris AniszczykFriend
You should be able to find old releases under this pattern...
http://download.eclipse.org/egit/updates-0.12
http://download.eclipse.org/egit/updates-0.11
etc...
Is there a bug open for your problem? It's unfortunate you can't use 1.0 since it's the latest and greatest.
We are planning to release 1.1 in late September...
Re: Old EGit versions [message #691940 is a reply to message #691869] Sat, 02 July 2011 21:52 Go to previous messageGo to next message
Thanks for the links. I'll search through Bugzilla to see if there is already a bug for the Buckminster problem, and if not will open one. I'm pretty sure this is all on the Buckminster side, not EGit.
Re: Old EGit versions [message #691951 is a reply to message #691940] Sat, 02 July 2011 22:57 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
All old releases and their p2 repositories are listed here http://wiki.eclipse.org/EGit/FAQ#Where_can_I_find_older_releases_of_EGit.3F
Previous Topic:New commit dialog
Next Topic:[JGIT] How to get started
Current Time: Sun Nov 27 01:37:15 GMT 2022
Powered by FUDForum. Page generated in 0.02501 seconds
