Re: "Out of Memory" issue in BIRT 3.6.2 [message #691602 is a reply to message #691561] |
Fri, 01 July 2011 19:48 |
Are you setting:
-XX:MaxPermSize=256m
I put mine in the JAVA_OPTS line in the catalina.bat file.
Jason
On 7/1/2011 2:05 PM, Atar Singh wrote:
> I have some- 12 BIRT Reports.Which are having both static and dynamic data.
> I am Frequently getting "Out of Memory" issue in BIRT 3.6.2.The report i
> am getting error is of 10 pages.
> After cleaning the tomcat,there is no error but again accessing same
> report.Getting this error.
> Could you please suggest,
> How to optimise it to avoid this error ?
> Is it due to a lot of plgins needed?
> Atar Singh
Re: "Out of Memory" issue in BIRT 3.6.2 [message #692121 is a reply to message #691799] |
Sun, 03 July 2011 16:24 |
Can you try something like:
set JAVA_OPTS=%JAVA_OPTS% -XX:MaxPermSize=256m
right before the execjava commands? somewhere around like 262?
Why did yo post the eclipse.ini? That should not be in the runtime.
Jason
On 7/2/2011 7:14 AM, Atar Singh wrote:
> Hi Jason,
> Thanks for your reply.
> I found "JAVA_OPTS" in catalina.bat of Tomcat 6.0.26 in many places.
> I set like below but still error encountered. :(
> set JAVA_OPTS = -XX:MaxPermSize=256m
> Am i doing something wrong in setting ?
> where excatly in catalina.bat file,i have to add this ?
> I have attached "eclipse.ini" and "catalina.bat" for your review.I have removed above setting from the attached "catalina.bat".
> Please help.
> Regards,
> Atar Singh
FUDForum. Page generated in 0.03290 seconds
