Start AUT has no effect [message #691520] |
Fri, 01 July 2011 16:19 |
Tatiana Messages: 5 Registered: July 2011 |
Starting test example Adder AUT has no effect.
I could find no log entry generated, no error shown - but AUT is not started.
AUT agent was started successfully.
I tried edit the cmd file to use my version of java. cmd file is executing fine from explorer, the application is shown - but still no effect in jubula.
Eclipse Indigo, java 1.6_26
[Updated on: Fri, 01 July 2011 16:20] Report message to a moderator
Re: Start AUT has no effect [message #691729 is a reply to message #691520] |
Sat, 02 July 2011 06:56 |
Francois Genolini Messages: 14 Registered: June 2011 Location: UK, Aberdeen |
Which operating system do you use?
Do you have a firewall?
In the Windows 7 (64-bit) that I have tried, the Windows firewall did ask me if I wanted to block port 60000 (used by the AUT agent).
You said that you have started the AUT agent, have you connected to it using the ITE?
In the PDF user manual there is a check list of everything that you need to do. For example:
download standalone ITE
start AUT agent
start standalone ITE
connect to AUT agent from ITE
open database (usually H2 by default)
open example project
edit AUT (change paths of JRE and AUT itself, as needed)
select test case and run test
[Updated on: Sat, 02 July 2011 07:00] Report message to a moderator
Re: Start AUT has no effect [message #692863 is a reply to message #692486] |
Tue, 05 July 2011 11:26 |
Did you click on the "Start AUT" button or did you use the small selector on its right side. Using the selector you'll see a drop down list of startable AUTs. The button itself just starts the last selection from the selector. If you've never actually selected an AUT it does nothing.
-Achim
FUDForum. Page generated in 0.03471 seconds
