Home » Archived » Test and Performance Tools Platform (TPTP) » determine line coverage after running recorded test for plugin UI(determine line coverage after running recorded test for plugin UI)
determine line coverage after running recorded test for plugin UI [message #690972] Thu, 30 June 2011 13:44 Go to next message
vinay  is currently offline vinay Friend
We want to automate the tests for eclipse plugin UI. So we record the UI steps in TPTP. And we also want to determine the line coverage of plugin source code after running those recorded test cases. But don't know how to achieve this.
Can anyone please provide some guidance?
Thanks in advance Smile
Re: determine line coverage after running recorded test for plugin UI [message #697442 is a reply to message #690972] Sat, 16 July 2011 18:56 Go to previous message
Torsten Stolpmann is currently offline Torsten StolpmannFriend
Member
Vinay,
there had been some Proof of Concept work done in the past which you may find interesting to look at. Although this was mainly targeted at testing TPTP itself it may contain some idea for an approach here:
http://wiki.eclipse.org/How_to_test_TPTP_with_line_level_code_coverage_enabled
Looking forward on hearing about your experiences.
Torsten
Previous Topic:No data available for display in Memory Analysis
Next Topic:Call Graph
Current Time: Fri Feb 21 10:59:01 GMT 2020
Powered by FUDForum. Page generated in 0.03089 seconds
