Home » Modeling » EMF » [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690902 is a reply to message #690901] |
Thu, 30 June 2011 11:43   |
Hi Dan,
Hmm, it seems that you are missing plugins. You should install the CDO Hibernate feature from the teneo update site. The
plugins you need are:
org.eclipse.emf.teneo
org.eclipse.emf.teneo.annotations
org.eclipse.emf.teneo.hibernate.mapper
gr. Martin
On 06/30/2011 01:34 PM, Dan Pollitt wrote:
> Hi All,
> I'm trying to create a target platform definition file (*.target) to set as the target platform within my IDE so that I
> can experiment with CDO.
> I will be looking at CDO v3.0 (as opposed to 4.0) because the most likely Eclipse version to deploy my plugins into will
> be Eclipse 3.6.
> I tried to follow the instructions for getting hold of dependencies (i.e. p2 sites I should add to the target platform)
> from: http://wiki.eclipse.org/CDO/Hibernate_Store/Quick_Start however I had a couple of issues:
> 1. There are mixed messages as to which version of Teneo I should be using. For CDO v3.0 and EMF v2.6 is it 1.1.2 or 1.2.0?
> 2. Whichever Teneo I add in the target platform it is showing me errors, for example with Teneo 1.2.0, the target
> platform editor reports the following problem:
> "Cannot satisfy dependency:
> From: EMF Teneo Hibernate 1.2.0.v201104261907 (org.eclipse.emf.teneo.hibernate 1.2.0.v201104261907)
> To: bundle org.eclipse.emf.teneo.annotations [1.1.0,2.0.0)
> From: EMF Teneo Hibernate Runtime 1.2.0.v201104261907 (org.eclipse.emf.teneo.hibernate.feature.group 1.2.0.v201104261907)
> To: org.eclipse.emf.teneo.hibernate [1.2.0.v201104261907]
> I presume the second problem is just a knock-on to the first.
> Can anyone point me in the right direction to resolve this - or perhaps provide me an example target platform definition
> that works for them?
> For reference, the target definition I have at the moment is:
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <?pde version="3.6"?>
> <target name="cdotarget" sequenceNumber="2">
> <locations>
> <location path="C:\dev\eclipse\eclipse-modeling-helios-SR2-incubation-win32\eclipse" type="Profile"/>
> <location includeAllPlatforms="false" includeMode="planner" includeSource="true" type="InstallableUnit">
> <unit id="org.apache.commons.logging.feature.group" version="1.1.1.201005082216"/>
> <unit id="org.apache.log4j.feature.group" version="1.2.16.201005082216"/>
> <unit id="org.dom4j.feature.group" version="1.6.1.201005082216"/>
> <unit id="org.hibernate.feature.group" version="3.3.2.201005082216"/>
> <unit id="org.hsqldb.feature.group" version="1.8.1.201005082216"/>
> <unit id="javax.persistence.feature.group" version="1.99.0.201005082216"/>
> <unit id="com.mysql.jdbc.feature.group" version="5.1.11.201005082216"/>
> <repository location="http://www.elver.org/eclipse/update_1.1.2"/>
> </location>
> <unit id="org.eclipse.emf.teneo.hibernate.sdk.feature.group" version="1.2.0.v201104261907"/>
> <unit id="org.eclipse.emf.teneo.hibernate.feature.group" version="1.2.0.v201104261907"/>
> <repository location="http://download.eclipse.org/modeling/emf/teneo/updates/1.2.0/interim/"/>
> </location>
> </locations>
> </target>
> Dan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690910 is a reply to message #690902] |
Thu, 30 June 2011 12:03   |
Dan Pollitt Messages: 55 Registered: August 2010 |
Member |
Hi Martin,
Thanks for your quick response. I had not selected the feature: "EMF
Teneo CDO" from the /teneo/updates/1.2.0/interim site - after adding
that as well, all seemed happy.
As far as the Teneo version, I am looking to use CDO v3.0 with EMF v2.6
with the Hibernate Store backed with MySQL - am I ok with the following
versions:
Teneo CDO/Hibernate: 1.2.0
Hibernate 3.3.2 ?
Dan
On 30/06/2011 12:43, Martin Taal wrote:
> Hi Dan,
> Hibernate feature from the teneo update site. The plugins you need are:
> gr. Martin
>> Hi All,
>> be Eclipse 3.6.
>> <locations>
>> <location
>> type="Profile"/>
>> </location>
>> <repository
>> </location>
>> </locations>
>> </target>
>> Thanks,
>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690911 is a reply to message #690910] |
Thu, 30 June 2011 12:09   |
Yes these versions are fine, I am not sure in how far CDO 4.0 is backward compatible with 3.6, maybe it is... Eike
Stepper can tell this.
gr. Martin
On 06/30/2011 02:03 PM, Dan Pollitt wrote:
> Hi Martin,
> Thanks for your quick response. I had not selected the feature: "EMF Teneo CDO" from the /teneo/updates/1.2.0/interim
> site - after adding that as well, all seemed happy.
> As far as the Teneo version, I am looking to use CDO v3.0 with EMF v2.6 with the Hibernate Store backed with MySQL - am
> I ok with the following versions:
> Hibernate 3.3.2 ?
> Dan
>> Hi Dan,
>> gr. Martin
>>> Hi All,
>>> be Eclipse 3.6.
>>> <locations>
>>> <location
>>> type="Profile"/>
>>> </location>
>>> <repository
>>> </location>
>>> </locations>
>>> </target>
>>> Thanks,
>>> Dan
The Netherlands
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690935 is a reply to message #690901] |
Thu, 30 June 2011 12:39   |
Originally posted by:
Dan,
although it's not officially supported, we have CDO 4.0 running with a
Helios-based TP (Eclipse 3.6 + EMF 2.6). Not sure about Teneo...
HTH,
Víctor.
Dan Pollitt escribió:
> Hi All,
> as the target platform within my IDE so that I can experiment with CDO.
> likely Eclipse version to deploy my plugins into will be Eclipse 3.6.
> (i.e. p2 sites I should add to the target platform) from:
> couple of issues:
> for example with Teneo 1.2.0, the target platform editor reports the
> following problem:
> provide me an example target platform definition that works for them?
> <locations>
> <location
> type="Profile"/>
> </location>
> <repository
> </location>
> </locations>
> </target>
> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690936 is a reply to message #690935] |
Thu, 30 June 2011 12:45   |
If it is possible I would use 4.0, it is maintained and it works with Hibernate 3.6.0.
gr. Martin
On 06/30/2011 02:39 PM, Víctor Roldán Betancort wrote:
> Dan,
> although it's not officially supported, we have CDO 4.0 running with a Helios-based TP (Eclipse 3.6 + EMF 2.6). Not sure
> about Teneo...
> HTH,
> Víctor.
>> Hi All,
>> couple of issues:
>> following problem:
>> <locations>
>> <location
>> type="Profile"/>
>> </location>
>> <repository
>> </location>
>> </locations>
>> </target>
>> Thanks,
>> Dan
The Netherlands
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690955 is a reply to message #690935] |
Thu, 30 June 2011 12:50   |
Member |
Hi Víctor,
That's interesting - I guess it will come down to what the real
difference between CDO v4.0 and v3.0 is, whether it's enough of a pull
to run it in that configuration.
Dan
On 30/06/2011 13:39, Víctor Roldán Betancort wrote:
> Dan,
> HTH,
> Víctor.
>> Hi All,
>> couple of issues:
>> following problem:
>> <locations>
>> <location
>> type="Profile"/>
>> </location>
>> <repository
>> </location>
>> </locations>
>> </target>
>> Thanks,
>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690956 is a reply to message #690936] |
Thu, 30 June 2011 12:52   |
Member |
ok - being maintained is a strong reason to use it - although if v3.0 is
stable and well used I wouldn't expect to find any fundamental issues
with vanilla usage?
What would be your thoughts around CDO v4.0 ontop of Eclipse 3.6 EMF 2.6?
Dan
> Hibernate 3.6.0.
> gr. Martin
>> Dan,
>> about Teneo...
>> HTH,
>> Víctor.
>>> Hi All,
>>> couple of issues:
>>> following problem:
>>> <locations>
>>> <location
>>> type="Profile"/>
>>> </location>
>>> <repository
>>> </location>
>>> </locations>
>>> </target>
>>> Thanks,
>>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #690981 is a reply to message #690955] |
Thu, 30 June 2011 13:50   |
Dan,
I'd say you go with 4.0. Yes, there are plenty new features in 4.0
compared to 3.0, but it is also the current maintenance version, as
Martin said, and in my case, thats enough reason to stick to it. Having
more or less features could be determinating depending on the
application you are developing, but if it isn't the case, maintenance
support should ;)
Also, several dozens of bugs have been fixed. You'll have to think about
backport them, and in some cases backporting is not trivial.
The next CDO release will be 4.1, which means that if at some point you
are updating you TP to the latest Eclipse release, the migration will be
less painful in the 4.0 -> 4.1 scenario than in the 3.0 -> 4.1 one.
Of course, there is the scenario of having a problem derived from using
EMF 2.6 with CDO 4.0. So far we haven't seen such thing, and it is quite
unlikely, but it could happen. It's something you should take into
consideration, because (and as I actually do), using that runtime
configuration is an "use at your own risk".
If you want information of the 4.0 release new features, just let us
know, I'll do my best :P
Víctor.
> Hi Víctor,
> Dan
>> Dan,
>> HTH,
>> Víctor.
>>> Hi All,
>>> couple of issues:
>>> following problem:
>>> <locations>
>>> <location
>>> type="Profile"/>
>>> </location>
>>> <repository
>>> </location>
>>> </locations>
>>> </target>
>>> Thanks,
>>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #691008 is a reply to message #690981] |
Thu, 30 June 2011 14:31   |
Member |
Thanks Víctor that has been very helpful. I will start out with CDO 4.0.
For reference, the target platform definition I ams starting from is:
<target name="cdotarget" sequenceNumber="11">
<locations>
<location includeAllPlatforms="false" includeMode="slicer"
<unit id="org.apache.commons.logging.feature.group" version="1.1.1"/>
<unit id="org.apache.log4j.feature.group" version="1.2.16"/>
<unit id="org.dom4j.feature.group" version="1.6.1"/>
<unit id="org.hibernate.feature.group" version="3.6.0"/>
<unit id="org.hsqldb.feature.group" version="1.8.1"/>
<unit id="com.mysql.jdbc.feature.group" version="5.1.11"/>
<repository location="http://www.elver.org/eclipse/update"/>
</location>
<unit id="org.eclipse.emf.teneo.cdo.feature.group"
<unit id="org.eclipse.emf.teneo.cdo.sdk.feature.group"
<repository
</location>
<unit id="org.eclipse.emf.sdk.feature.group"
version="2.6.1.v20100914-1218"/>
<unit id="org.eclipse.emf.compare.sdk.feature.group"
version="1.1.2.v20110202-0936"/>
<repository location="http://download.eclipse.org/releases/helios"/>
</location>
<unit id="org.eclipse.emf.cdo.sdk.feature.group"
version="4.0.0.v20110608-1747"/>
<repository location="http://download.eclipse.org/releases/indigo"/>
</location>
<unit id="org.eclipse.platform.sdk" version="3.6.2.M20110210-1200"/>
</location>
</locations>
</target>
Dan
On 30/06/2011 14:50, Víctor Roldán Betancort wrote:
> Dan,
> support should ;)
> Cheers,
> Víctor.
>> Hi Víctor,
>> Thanks,
>> Dan
>>> Dan,
>>> HTH,
>>> Víctor.
>>>> Hi All,
>>>> set
>>>> couple of issues:
>>>> errors,
>>>> following problem:
>>>> <locations>
>>>> <location
>>>> type="Profile"/>
>>>> </location>
>>>> <repository
>>>> </location>
>>>> </locations>
>>>> </target>
>>>> Thanks,
>>>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #691049 is a reply to message #691008] |
Thu, 30 June 2011 15:37   |
Good luck with your project, Dan!
> <locations>
> </location>
> <repository
> </location>
> </location>
> </location>
> </location>
> </locations>
> </target>
> Dan
>> Dan,
>> support should ;)
>> Cheers,
>> Víctor.
>>> Hi Víctor,
>>> Thanks,
>>> Dan
>>>> Dan,
>>>> HTH,
>>>> Víctor.
>>>>> Hi All,
>>>>> set
>>>>> CDO.
>>>>> had a
>>>>> couple of issues:
>>>>> errors,
>>>>> following problem:
>>>>> perhaps
>>>>> <locations>
>>>>> <location
>>>>> type="Profile"/>
>>>>> </location>
>>>>> <repository
>>>>> </location>
>>>>> </locations>
>>>>> </target>
>>>>> Thanks,
>>>>> Dan
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #691742 is a reply to message #690911] |
Sat, 02 July 2011 07:48   |
Am 30.06.2011 14:09, schrieb Martin Taal:
> Yes these versions are fine, I am not sure in how far CDO 4.0 is backward compatible with 3.6, maybe it is... Eike Stepper can tell this.
Not really. Other users have reported that it works, but we run no tests on this combination and we do not officially support it. In case of problems you could be standing in the rain.
Cheers
/Eike
http://www.esc-net.de
> gr. Martin
>> Hi Martin,
>> Hibernate 3.3.2 ?
>> Thanks,
>> Dan
>>> Hi Dan,
>>> gr. Martin
>>>> Hi All,
>>>> be Eclipse 3.6.
>>>> <locations>
>>>> <location
>>>> type="Profile"/>
>>>> </location>
>>>> <repository
>>>> </location>
>>>> </locations>
>>>> </target>
>>>> Thanks,
>>>> Dan
Cheers
/Eike
Re: [CDO] Creating a target definition for an App to use CDO v3.0 / Hibernate Store [message #691743 is a reply to message #690956] |
Sat, 02 July 2011 07:49  |
Am 30.06.2011 14:52, schrieb Dan Pollitt:
> ok - being maintained is a strong reason to use it - although if v3.0 is stable and well used I wouldn't expect to find any fundamental issues with vanilla usage?
Please see my reply to Martin's most recent post to this thread.
Cheers
/Eike
> Dan
>> Hibernate 3.6.0.
>> gr. Martin
>>> Dan,
>>> about Teneo...
>>> HTH,
>>> Víctor.
>>>> Hi All,
>>>> couple of issues:
>>>> following problem:
>>>> <locations>
>>>> <location
>>>> type="Profile"/>
>>>> </location>
>>>> <repository
>>>> </location>
>>>> </locations>
>>>> </target>
>>>> Thanks,
>>>> Dan
Cheers
/Eike
Current Time: Sat Jan 16 09:44:50 GMT 2021
Powered by FUDForum. Page generated in 0.02863 seconds
