Home » Modeling » M2T (model-to-text transformation) » workflow.mwe resource refresh
workflow.mwe resource refresh [message #690815] Thu, 30 June 2011 09:10 Go to next message
Dennis Melzer is currently offline Dennis MelzerFriend
how can i disable the "resource refresh", which run automatically after the workflow.mwe?
Re: workflow.mwe resource refresh [message #690827 is a reply to message #690815] Thu, 30 June 2011 09:32 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i don't know of such a possibility. did you try to call the workflow from a java class / ant file instead directly from eclipse?
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: workflow.mwe resource refresh [message #690898 is a reply to message #690827] Thu, 30 June 2011 11:53 Go to previous messageGo to next message
i didn't try, because we use .mwe files. Mhm the refresh resources takes a lot of time. It annoying to wait 5-10 min.
Re: workflow.mwe resource refresh [message #690913 is a reply to message #690898] Thu, 30 June 2011 12:20 Go to previous messageGo to next message
So you could give it a try to call the mwe file from java/ant as i said ~Christian
Re: workflow.mwe resource refresh [message #690938 is a reply to message #690913] Thu, 30 June 2011 12:54 Go to previous message
ok thanks i will try
Previous Topic:Availability of Accleo version 3.1.x via update site
Next Topic:[Acceleo] Query overloadings
Current Time: Sat Feb 27 22:13:08 GMT 2021
Powered by FUDForum. Page generated in 0.02154 seconds
