Re: Validation through more model files. [message #692323 is a reply to message #690801] |
Mon, 04 July 2011 07:52 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
The easiest wa is to switch from importURI to importedNamespace and use
fragment = validation.JavaValidatorFragment {
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
in your grammar.
If you stick to importURIs not that all imported resources will be
loaded into the models ResourceSet, so you can use the plain EMF model
access techniques.
Am 30.06.11 10:52, schrieb Martin Novak:
> Hello Guys,
> we have this problem. We need to split a model to more files and
> validate uniqueness of some parameters, e.g. names of objects, through
> all imported files.
> Is it possible to get reference or even directly EObjects from another
> model in different file, by imports?
> Look at the example bellow which should describe the basic problem.
> MetaModel:
> name = ID
> ('import' importURI = STRING)*
> (a = A)?
> (b = B)?
> (c = C)?
> A:
> 'SectionA'
> name = ID
> 'index' index = INT
> B:
> 'SectionB'
> name = ID
> index = INT
> C:
> 'SectionC'
> name= ID
> aRef = [A]
> bRef = [B]
> arbitraryRef = [ecore::EObject]
> index = INT
> File1.dsl:
> Main
> import „File2.dsl"
> import „File3.dsl"
> SectionA nameA index 1
> SectionB nameB index 1
> SectionC nameC
> Model2.nameB
> Model3.nameC
> index 1
> File2.dsl:
> Model2
> File3.dsl:
> Model3
> Thank you for your ideas and help.
> M&M
Get professional support from the Xtext committers at www.typefox.io
FUDForum. Page generated in 0.03474 seconds
