Re: [Embedded Birt] : Migration to 3.7 [message #690452 is a reply to message #690269] |
Wed, 29 June 2011 14:29 |
Nicolas
There are more libs because the runtime jars are no longer in the
platform/plugins directory. All the birt functionality is one jar. The
only jars that I see that could be trimmed are the datatools jars, which
have jars for different data source types. You could also remove
derby.jar if you do not want to use the sample db.
Jason
On 6/29/2011 5:53 AM, miaou wrote:
> Hi everybody,
> I plan to migrate to Birt 3.7 version.
> We have embedded Birt engine into our application as many of you have done.
> According to the wiki migration page
> (htp://wiki.eclipse.org/Birt_3.7_Migration_Guide), external runtime is
> no more necessary, nor the following code :
> config.setBIRTHome("pathtoruntime");
> Only add all ReportEngine/lib jars to application classpath (WEB-INF/lib
> for example) is required.
> Comparing Birt 2.6.2 to 3.7 version, I note that there are many more
> libraries (24 vs 78).
> I can guess that some of them are optional, but is there any
> documentation about library requirement and feature ?
> The aim is :
> I want to avoid as much as possible library conflict.
> As Birt libraries are still not publish on any maven repository, I would
> like to create my own maven descriptor file and publish Birt libraries
> on my local maven proxy.
> Thanks you for any help.
> Best Regards,
> Nicolas
Re: [Embedded Birt] : Migration to 3.7 [message #690516 is a reply to message #690488] |
Wed, 29 June 2011 15:53 |
Nicolas
The batik libraries are used heavily when converting a chart (that is
set to svg format) to pdf etc. I believe they are also used in
processing some inline styles with pdf. I will need to check.
Jason
On 6/29/2011 11:22 AM, miaou wrote:
> Hi Jason,
> thanks for your answer.
> I will add commons-cli to the list you provided.
> Do you think that all batik libraries are needed ? Aren't they used only
> for svg generation ? (a feature I don't use, I think)
> Nicolas
Re: [Embedded Birt] : Migration to 3.7 [message #690558 is a reply to message #690524] |
Wed, 29 June 2011 16:55 |
Nicolas,
I think Scott Rosenbaum may be setting up a maven server at his site.
He will post on birtworld.blogspot.com if he does. If you set one up
please let me know.
Jason
On 6/29/2011 12:22 PM, miaou wrote:
> mmmh, do not check Jason
> as I (sometimes) used chart into my reports,
> so I need to keep them too.
> Once again, thx for your reply !!
> Nicolas
FUDForum. Page generated in 0.03396 seconds
