Home » Archived » M2M (model-to-model transformation) » BPMN DIAGRAM ECORE METAMODEL(Does anybody have the metamodel?)
BPMN DIAGRAM ECORE METAMODEL [message #689732] Tue, 28 June 2011 09:03 Go to next message
Yulia B is currently offline Yulia BFriend
Hi all,
I need to implement an ATL transformation of a BPMN model. So I have two files as input: file.bpmn and file.bpmn_diagram, I need both of them for the transformation. I need also the metamodels of these two files correspondingly. I've found the BPMN metamodel, but can't find the BPMN_DIAGRAM metamodel. Does anybody have? Could you please share with me?
Thanks in advance!
Re: BPMN DIAGRAM ECORE METAMODEL [message #690220 is a reply to message #689732] Wed, 29 June 2011 07:56 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
did you take a look in the BPMN_DIAGRAM file? There should be written which meta model is used. Maybe the GMF Notation model?
Ralph
Re: BPMN DIAGRAM ECORE METAMODEL [message #690361 is a reply to message #690220] Wed, 29 June 2011 12:42 Go to previous messageGo to next message
Oh.. Sorry, I can't use links until I've posted more than 5 messages. It's the fourth..
[Updated on: Wed, 29 June 2011 12:42]
Report message to a moderator
Re: BPMN DIAGRAM ECORE METAMODEL [message #690363 is a reply to message #690361] Wed, 29 June 2011 12:42 Go to previous messageGo to next message
It's the fifth..
Re: BPMN DIAGRAM ECORE METAMODEL [message #690365 is a reply to message #690220] Wed, 29 June 2011 12:43 Go to previous messageGo to next message
Ralph, thank you very much for your reply!
Could you tell me please, if the first line (after XML declaration) in my .bpmn_diagram file is
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:bpmn="http://stp.eclipse.org/bpmn" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.2/notation" xmi:id="_wBWLAGsqEd-yl7_INOeaMQ" type="Bpmn" name="MyBPMNDiagramFile.bpmn_diagram" measurementUnit="Pixel">
it means the metamodel of this model is GMF notation, or more concrete,
(because of the name space definition), right? I've found this metamodel (in my eclipse\plugins\org.eclipse.gmf.runtime.notation_1.5.0.v20110309-2159.jar\model\notation.ecore), but actually my model doesn't conform to it.
My file looks like:
  <children xmi:type="notation:Node" xmi:id="_wCid0GsqEd-yl7_INOeaMQ" type="1001">
    <children xmi:type="notation:Node" xmi:id="_wCid1msqEd-yl7_INOeaMQ" type="4008"/>
    <children xmi:type="notation:Node" xmi:id="_wCid12sqEd-yl7_INOeaMQ" type="5001">
      <children xmi:type="notation:Node" xmi:id="_R85DcmsrEd-yl7_INOeaMQ" type="2007">
        <children xmi:type="notation:Node" xmi:id="_R85DeGsrEd-yl7_INOeaMQ" type="4007"/>
        <styles xmi:type="notation:FontStyle" xmi:id="_R85Dc2srEd-yl7_INOeaMQ" fontName="Arial"/>
        <styles xmi:type="notation:DescriptionStyle" xmi:id="_R85DdGsrEd-yl7_INOeaMQ"/>
        <styles xmi:type="notation:FillStyle" xmi:id="_R85DdWsrEd-yl7_INOeaMQ" fillColor="16771304"/>
        <styles xmi:type="notation:LineStyle" xmi:id="_R85DdmsrEd-yl7_INOeaMQ" lineColor="0"/>
        <element xmi:type="bpmn:Lane" href="MyBPMNFile.bpmn#_R85DcWsrEd-yl7_INOeaMQ"/>
        <layoutConstraint xmi:type="notation:Bounds" xmi:id="_R85Dd2srEd-yl7_INOeaMQ" y="5" height="200"/>
      </children>
  </children>
  <styles xmi:type="notation:PageStyle" xmi:id="_wBWLAWsqEd-yl7_INOeaMQ"/>
  <edges xmi:type="notation:Edge" xmi:id="_c4zXYmsrEd-yl7_INOeaMQ" type="3001" source="_VaLCoGsrEd-yl7_INOeaMQ" target="_XmZCkmsrEd-yl7_INOeaMQ">
    <children xmi:type="notation:Node" xmi:id="_c4zXZ2srEd-yl7_INOeaMQ" type="4012">
      <styles xmi:type="notation:FillStyle" xmi:id="_c4zXaGsrEd-yl7_INOeaMQ" fillColor="16776959"/>
      <styles xmi:type="notation:LineStyle" xmi:id="_c4zXaWsrEd-yl7_INOeaMQ" lineColor="16776959"/>
      <layoutConstraint xmi:type="notation:Location" xmi:id="_c4zXamsrEd-yl7_INOeaMQ" y="-10"/>
    </children>
    <styles xmi:type="notation:RoutingStyle" xmi:id="_c4zXY2srEd-yl7_INOeaMQ" routing="Rectilinear" smoothness="Normal" closestDistance="true"/>
    <styles xmi:type="notation:FontStyle" xmi:id="_c4zXZGsrEd-yl7_INOeaMQ" fontName="Arial"/>
    <styles xmi:type="notation:LineStyle" xmi:id="_c4zXZWsrEd-yl7_INOeaMQ" lineColor="0"/>
    <element xmi:type="bpmn:SequenceEdge" href="MyBPMNFile.bpmn#_c4zXYWsrEd-yl7_INOeaMQ"/>
    <bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_c4zXZmsrEd-yl7_INOeaMQ" points="[20, -2, -101, -6]$[162, 14, 41, 10]"/>
  </edges>
</notation:Diagram>
The notation.ecore (PFA) doesn't contain any "Children" EClass.. It seems that all file is an instance of the "Diagram" EClass of the notation.ecore, but it isn't declared. But even in this case "Diagram" EClass contains only "persistedChildren" and "transientChildren" attributes (inherited from "View" EClass), not "children". I'm totally confused..
Any thoughts will be highly appreciated! Thank you!
[Updated on: Wed, 29 June 2011 12:43]
Re: BPMN DIAGRAM ECORE METAMODEL [message #690366 is a reply to message #690365] Wed, 29 June 2011 12:46 Go to previous messageGo to next message
at first you found the right meta model. To browse meta models you should consider using the meta model explorer view provided by the QVT plugin. Your model conforms to the notation model as <children> is an reference with containment set to true and no EClass.
Ralph
Re: BPMN DIAGRAM ECORE METAMODEL [message #692468 is a reply to message #690366] Mon, 04 July 2011 13:51 Go to previous messageGo to next message
Hi, Ralph,
Could you please explain the last sentense of the previous message? I've installed the QVT plugin and I opened the Metamodel Explorer view, but I didn't understand how it could help me.
I just need .bpmn_diagram file to conform to some metamodel, like model A:
<?xml version="1.0" encoding="ASCII"?>
<tpA:RootA xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:tpA="platform:/resource/ListMetamodelRefactoring/Metamodel/TypeA.ecore" name="la racine">
  <elms name="elm1"/>
  <elms name="elm2"/>
</tpA:RootA>
conforms to metamodel MetaA:
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="typeA"
    nsURI="platform:/resource/ListMetamodelRefactoring/Metamodel/TypeA.ecore" nsPrefix="tpA">
  <eClassifiers xsi:type="ecore:EClass" name="RootA">
    <eStructuralFeatures xsi:type="ecore:EReference" name="elms" upperBound="-1" eType="#//ElementA"
        containment="true"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="ElementA">
  </eClassifiers>
</ecore:EPackage>
Thank you very much for your time!
Re: BPMN DIAGRAM ECORE METAMODEL [message #692478 is a reply to message #692468] Mon, 04 July 2011 14:11 Go to previous messageGo to next message
the meta model explorer enables you to browse any registered meta model without the need to search it in plug-ins. This can be very helpful when working with meta models you do not know very well.
What is you precise problem when writing the transformation? You can ignore the notation model as long as you do not need to store any layout information.
Ralph
Re: BPMN DIAGRAM ECORE METAMODEL [message #695781 is a reply to message #692478] Tue, 12 July 2011 14:39 Go to previous messageGo to next message
Thank you, Ralph!
I've got it.. But I had to improve the notation.ecore. I've downloaded the GMF Notation 1.5.0 from here:
http://www.eclipse.org/modeling/gmp/downloads/index.php?project=gmf-notation&showAll=1&showMax=5
I found there org.eclipse.gmf.runtime.notation_1.5.0.v20110309-2159.jar, the "model" folder inside, and notation.ecore inside. Inspite of the number "1.5.0" of GMF Notation, "nsURI="http://www.eclipse.org/gmf/runtime/1.0.2/notation" is declared in notation.ecore.
Then I opened the notation.ecore with text editor and replaced string "../../org.eclipse.emf.ecore/model/Ecore.ecore#" with "http://www.eclipse.org/emf/2002/Ecore#" (It couldn't find the Ecore model otherwise).
Then I opened the notation.ecore with Sample Ecore Model Editor and added the following references:
- I added "children", EType = "Node", Upper Bound = "-1", to EClass "View";
- "edges", EType = "Edge", Upper Bound = "-1", to EClass "Diagram".
Then a simple BPMN diagram conformed to the notation.ecore and could be processed. But if there were curved connectors in the diagram, the following error occured:
Error loading platform:/resource/TestATL/default.bpmn_diagram: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '[0, 0, -119, 0]$[119, 0, 0, 0]' is not legal.
The Instance Type Name of the RelativeBendpointList is set to "java.util.List", but the presentation "[0, 0, -119, 0]$[119, 0, 0, 0]" is not the toString() presentation of ordinary Java list (it is "[0, 0, -119, 0]"). This is the cause of the error. If you change the Instance Type Name, the .bmpn_digram can be processed, but you can do nothing with connectors coordinates.
How to access coordinates is still open question for me. It's a general question of using "Instance Type Name" I try to understand here:
http://www.eclipse.org/forums/index.php/t/216440/
Re: BPMN DIAGRAM ECORE METAMODEL [message #696045 is a reply to message #695781] Wed, 13 July 2011 07:14 Go to previous messageGo to next message
I personally would not recommend to modify meta models provided by any plugin. But maybe for your use case it is the best. If you want to the code of any plugin that is running in your eclipse you can also use the eclipse import function and choose "Plugins and Fragments" to import. This way you do not need to download and search any jar files.
Ralph
Re: BPMN DIAGRAM ECORE METAMODEL [message #719059 is a reply to message #696045] Thu, 25 August 2011 23:11 Go to previous message
IvannalFriend
Hi all,
I'm defnining a transformation in ATL, which uses the BPMN2 metamodel as target.
how can I generate the namespace for bpmn2 in the target diagram ?
Thanks in advance!
Previous Topic:How to solve ATL references?
Next Topic:org.eclipse.m2m.internal.qvt.oml.emf.util.EmfException
Current Time: Tue Feb 25 13:54:46 GMT 2020
Powered by FUDForum. Page generated in 0.09190 seconds
